dalemed
Posted: Thu Feb 28, 2008 6:54 am Post subject: 601 XL Empty Weight |
What can I expect the empty weight of my 601 XL will be when its done - less the weight of the engine and paint? Assume a stock build with minimal instruments and minimal corrosion proofing.
Thanks for info!
_________________ Dale
Zenith Zodiac CH650 |
rhodes1
Posted: Thu Feb 28, 2008 8:35 am Post subject: Re: 601 XL Empty Weight |
Hello
I was thinking about the same thing. What would the weight [approx] be with a 0200 engine installed?
Thanks Don
Gig Giacona
Posted: Thu Feb 28, 2008 9:06 am Post subject: Re: 601 XL Empty Weight |
Well that's what AMD puts in the S-LSA so looking at their specs 770 Lbs.
http://www.newplane.com/amd/amd/601_SLSA/specification.html
| rhodes1 wrote: | Hello
Thanks Don |
601XL Under Construction
psm(at)ATT.NET Guest
Posted: Thu Feb 28, 2008 10:09 am Post subject: 601 XL Empty Weight |
Hi Don,
The AMD web site shows 770 pounds empty weight for the factory built
XL. I believe this model includes the Continental O-200.
My informal examination of many LSA specs seems to indicate using an
O-200 or O-235 adds around 100 pounds to your empty weight compared
to a Rotax or Jabiru installation.
Paul
XL fuselage
At 08:35 AM 2/28/2008, you wrote:
| Quote: | Hello
Thanks Don
barcusc(at)comcast.net Guest
Posted: Thu Feb 28, 2008 11:20 am Post subject: 601 XL Empty Weight |
I am installing the Continental O-200 in my 601 XL, the people at Teledyne
Mattituck told me the O-200 is 215 pounds with accessories, the Jabiru is
listed at 180 with accessories.
Clyde Barcus
601 XL, Continental Powered
planecrazydld(at)yahoo.co Guest
Posted: Thu Feb 28, 2008 3:15 pm Post subject: 601 XL Empty Weight |
Were those weight wet or dry? How much oil does the Jab hold? (6+lb/gallon)
Clyde Barcus <barcusc(at)comcast.net> wrote:[quote] --> Zenith-List message posted by: "Clyde Barcus"
Clyde Barcus
tski0403(at)yahoo.com Guest
Posted: Fri Feb 29, 2008 12:44 pm Post subject: 601 XL Empty Weight |
Hi Dave, I did notice that Zenith does not have the empty weight of the 0-200, I am trying to find the best engine to useful load, the Jab just cost to much, and would like to know the empty weight on yours when it is installed. Thanks Tom
David Downey <planecrazydld(at)yahoo.com> wrote: [quote]Were those weight wet or dry? How much oil does the Jab hold? (6+lb/gallon)
Clyde Barcus <barcusc(at)comcast.net> wrote: [quote]--> Zenith-List message posted by: "Clyde Barcus"
Clyde Barcus
601 XL, Continental [quote][b]
gpjann1(at)netzero.net Guest
Posted: Fri Feb 29, 2008 5:01 pm Post subject: 601 XL Empty Weight |
The main difference between a Corvair and O-200 are:
.. starter, alternator, fuel pump
.. intake manifold
.. weight
_____________________________________________________________
Click now to find a divorce attorney near you!
John Bolding
Posted: Fri Feb 29, 2008 6:39 pm Post subject: 601 XL Empty Weight |
Not really John
KC7HFA
Joined: 05 Jul 2007 Posts: 11 Location: Southern Oregon
Posted: Sat Mar 01, 2008 9:59 am Post subject: Re: 601 XL Empty Weight |
The weight of my 601xl, Jabiru 3300 with paint and upholstery, ready to fly less fuel came in at 744 lbs. This includes the Dynon D180 and a Dynon D100 for instruments, and a Garmin transponder and Icom A200 radio. I hope this helps!
_________________ Ron Asbill
N601ZX - CH-601 XL
Jabiru 3300
Completed and Flying!~ 150 Plus hours |
dalemed
Posted: Sat Mar 01, 2008 11:42 am Post subject: Re: 601 XL Empty Weight |
Yes! Great information.
