duranberg(at)gmail.com Guest
Posted: Thu Feb 28, 2008 9:34 pm Post subject: Stainless Steel Fuel Line |
I am considering using stainless steel tubing for the rigid fuel lines on my 7. Yeah I know there are hundreds of RV's and thousands of other planes flying around out there with aluminum lines, but I thought it would be fun and educational to use SS, help my TIG welding skills, etc....
Anyway, can anyone come up with any negatives to doing so?
Michael Duran
mike109g6(at)insideconnec Guest
Posted: Thu Feb 28, 2008 10:17 pm Post subject: Stainless Steel Fuel Line |
2. I may be wrong but I believe that you can only use steel AN fittings with SS.
3. $$$$$
4. I could see doing the brake lines, ie pressure, but why the fuel lines? Have you looked at all of the bends that have to be made? If you have an IO engine = nightmare.
Good luck,
Mike H 9A/8A
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
skylor4(at)yahoo.com Guest
Posted: Fri Feb 29, 2008 3:08 pm Post subject: Stainless Steel Fuel Line |
If you did use stainless lines, you would most
certainly want to use AN flared tubing, and not mess
around with welded line.
Nevertheless, as others have already pointed out, this
is a good way to add weight and expense without
addning much real benefit.
Skylor
RV-8 QB
Under Construction
--- Michael Duran <duranberg(at)gmail.com> wrote:
| Quote: | I am considering using stainless steel tubing for
skills, etc....
doing so?
Michael Duran
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
robertrv607(at)yahoo.com Guest
Posted: Sat Mar 01, 2008 5:56 am Post subject: Stainless Steel Fuel Line |
Mike: the only thing is how you aare going to do all that bending, believe me it was
hard and tedious, even on all aluminum tubes...
bert
mike humphrey <mike109g6(at)insideconnect.net> wrote:
[quote] !. $$$$$
3. $$$$$
Good luck,
Mike H 9A/8A
aerokinetic(at)sbcglobal. Guest
Posted: Sat Mar 01, 2008 10:28 am Post subject: Stainless Steel Fuel Line |
BAD idea I think. In addition to being heavy, expensive and hard to work, stainless lines are notorious for cracking because stainless work hardens much more quickly than aluminum. It is best used in locations where heat is a factor and movement isn't -such as fuel lines on turbine engines themselves (which are formed by automated machines specially designed for the purpose and then stress-relieved). NASA can't keep stainless lines from cracking on the shuttles. It's a constant problem for them.
TIG welder? On fuel lines? Why? I own a TIG and have completed a flying RV and I can't think of why welding would be used in this application.
A fuel system is no place to screw around. Use the accepted techniques -they are in place because many people over many years have refined them, and determined them best.
Scott Spencer
RV-4 and A&P mechanic for 20 years.
davemader(at)bresnan.net Guest
Posted: Sun Mar 02, 2008 7:56 am Post subject: Stainless Steel Fuel Line |
Any comments on stainless fuel lines for my primer system? I have a primer set-up like vans sells where you T off the carburetor and run an 1/8 fuel line to a solenoid switch which in turn primes 2 cylinders. I had a bad situation a few years ago on my 6 in which I my fuel pressure was dropping, I turned on my electric fuel pump, and it helped the situation. What I didn’t realize was that the primer line had cracked, and I was pumping fuel right down on my exhaust. I noticed an increase in the fuel smell but the pressure was up and I continued on. Luckily, I was only a few miles from home. I have since bought stainless fuel lines and fittings to replace these lines but haven’t installed them yet. Would stainless be o.k. in this situation? Since my engine starts fine, should I just forget it?
Dave Mader
RV6-flying-
RV-4 90% done
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of SCOTT SPENCER
Sent: Saturday, March 01, 2008 10:43 AM
To: rv-list(at)matronics.com
Subject: Re: Stainless Steel Fuel Line
Scott Spencer
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234567
sheldonb(at)frontiernet.n Guest
Posted: Sun Mar 02, 2008 8:20 am Post subject: Stainless Steel Fuel Line |
I had copper lines on a primer system on my 6A... couple times the lines broke... FORGET that!... I then removed the entire system... Engine starts fine..(pump throttle while cranking)... Elimated a potential problem/system... On hot starts... learned to: leave throttle pulled shut, start cranking..slowly push mixture in... starts when the engine likes the mixture... every time...Otherwise, if I give it any prime (throttle) it'll flood..
Sheldon 6A 485 hours 0-360..
Posted: Sun Mar 02, 2008 8:32 am Post subject: Stainless Steel Fuel Line |
Dave,
Why not use SS braided fuel line instead of a hard line? It's already rated for high pressure, easier to work with, AN fittings, can readily get it in any size that you need-primer line is 4 I believe.
Mike H 9A/8A
Vanremog(at)aol.com Guest
Posted: Sun Mar 02, 2008 8:53 am Post subject: Stainless Steel Fuel Line |
In a message dated 3/2/2008 7:57:45 A.M. Pacific Standard Time, davemader(at)bresnan.net writes:
| Quote: | | Any comments on stainless fuel lines for my primer system? I have a primer set-up like vans sells where you T off the carburetor and run an 1/8 fuel line to a solenoid switch which in turn primes 2 cylinders. |
IMO this is a good use of SS and it makes the primer system more robust at the small diameter.
N1GV (RV-6A, Flying 887hrs, O-360-A1A, C/S, Silicon Valley)
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Sun Mar 02, 2008 8:51 pm Post subject: Stainless Steel Fuel Line |
In a message dated 03/02/2008 9:58:12 AM Central Standard Time, davemader(at)bresnan.net writes:
| Quote: | | Since my engine starts fine, should I just forget it? |
When this has come up before, the folks living in the Great White North tend to support primers. In areas where you normally don't have to shovel the airplane out of the hangar, it may not be necessary. My carbed -320 starts very easily even on frigid mornings (35-40 degrees in the hangar) by just giving the throttle a couple of shots of accelerator pump WHILE the engine is cranking. My used engine was liberated from a Cherokee and came with copper primer lines hooked to 3 cylinders. I plumbed them to my MAP sensor, which saved me plugging into the port on #3 and removing the old lines and plugging the holes. I must say I kinda prefer less gasoline arteries wrapped around the engine.
Now if you plan on visiting Lake Woebegon for ice-fishing and leave the plane tied down on the lake, ya might need a shot of pre-heat before firin' that muthu up...
From The PossumWorks in TN
Mark
_________________ From The PossumWorks... |
