dpremgood(at)aim.com Guest
Posted: Sun Mar 09, 2008 4:48 pm Post subject: ROTAX 912 Carb boots |
Good day all,
Has anyone got a carb heat box installed and have a solution fro
keeping the carbs in place on their boots? The vibration at idle is
enough to cause the carbs to come off from their boots.
thanks.
Doug Remoundos
kitfoxpilot(at)msn.com Guest
Posted: Sun Mar 09, 2008 5:52 pm Post subject: ROTAX 912 Carb boots |
You can use cable ties attached on the top and bottom of the carbs! a friend of mine has a CH701 abd cable ties were used in that manner! works great.
Ray
| Quote: | To: kitfox-list(at)matronics.com
Subject: Kitfox-List: ROTAX 912 Carb boots
Date: Sun, 9 Mar 2008 20:43:57 -0400
--> Kitfox-List message posted by: dpremgood(at)aim.com
Good day all,
thank===========
Need to know the score, the latest news, or you need your HotmailŪ-get your "fix". Check it out. [quote][b]
