		sdthatcher
  Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
				 Posted: Thu Mar 20, 2008 6:05 am    Post subject: Accident Prevention |
				Just for the record, be sure when making your 45 to downwind on a gusty day
 you don't try the bank and yank approach (60-70 degree hard bank maintaining
 level flight) then level out abeam the numbers on downwind. You just might
 find that you've exceeded 6 g's in your aircraft as you watch your wings
 embrace your cabin!
 Scott Thatcher, Palm Beach Gardens, FL
 601XL with Corvair, Registered as E-LSA
 N601EL
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Scott Thatcher, Port Saint Lucie, FL
N601EL, EAA203 140 hours and not flying currently. |
		cscsail(at)gmavt.net Guest
				 Posted: Thu Mar 20, 2008 8:13 am    Post subject: Accident Prevention |
				I'm not a 601 driver, but I would thing that the approach speed would we
 below the maneuvering speed (Va). Below this speed the wing can not produce
 enough lift to overstress the aircraft.
 Gordon
		david_a_g_johnson(at)btin Guest
				 Posted: Thu Mar 20, 2008 9:03 am    Post subject: Accident Prevention |
				This is not quite true - a rapid reversal of the controls can over-stress
 the airframe. This is thought to have caused the crash of a PA28 near my
 home. A large section of one wing broke off (about 1/3rd. I think)
 You can read the full AAIB report at:-
 http://www.aaib.dft.gov.uk/cms_resources/dft_avsafety_pdf_025533.pdf
 Dave Johnson
				 Posted: Thu Mar 20, 2008 9:50 am    Post subject: Accident Prevention |
				Amazing.  I owned a Cherokee and "thought" is was built like a tank..  Guess
 not.
 SW
		ernieth(at)gmail.com Guest
				 Posted: Thu Mar 20, 2008 10:15 am    Post subject: Accident Prevention |
 Very interesting.
 It does they state " the aircraft was flying at or just below VA of 118kt",
 Looks like Va, is more of a guideline  than a grantee in some cases.
 The recommedation.....
               training syllabus for private pilot should be reviewed...
 e.
 On Thu, Mar 20, 2008 at 9:59 AM, Dave Johnson <david_a_g_johnson(at)btinternet.com (david_a_g_johnson(at)btinternet.com)> wrote:
  [quote]--> Zenith-List message posted by: "Dave Johnson" <david_a_g_johnson(at)btinternet.com (david_a_g_johnson(at)btinternet.com)>
  Dave Johnson
		rtdin
  Joined: 16 Mar 2008 Posts: 46 Location: Florida panhandle
				 Posted: Thu Mar 20, 2008 12:04 pm    Post subject: Accident Prevention |
				Lets slow down here and take a breath. First, these bank angles at pattern altitude would be seriously bad judgment. Second, If the pilot's wife were on board, he might get slapped real hard. What we do know is that an aircraft with the wing and power loading of a CH601XL would barely be able maintain altitude beyond 60 degrees of bank. A bank angle of 40 Deg = 1.3 G, 60 Deg = 2 G, 70 Deg = about 3.2.
  http://pilotsweb.com/principle/load.htm We always slow down in the pattern, do we not?
  The more likely scenario would be that a greenhorn would let the ball slip out, stall and not recognize the spin entry. Few pilots have training in spins any more. Even CFI candidates don't have to demonstrate them anymore. A log book entry will do. BTW, some bank angles of more that 60 degrees can be done one handed while pouring a drink with the other hand. Watch this.  http://youtube.com/watch?v=Xp2Uc9XvmjY Slightly more than 1 G. Bob Hoover has always been my hero.
  Bob Dingley
  XL/Lyc Do not archive
 Create a Home Theater Like the Pros. Watch the video on AOL Home.
       (http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001)  [quote][b]
		bryanmmartin
				 Posted: Thu Mar 20, 2008 12:53 pm    Post subject: Accident Prevention |
				A 6G coordinated turn at a constant altitude would require slightly
 more than 80 Degrees of bank. It takes 76 degrees of bank to exceed
 the flight load limit of 4Gs.
  gusty day you don't try the bank and yank approach (60-70 degree
  hard bank maintaining level flight) then level out abeam the numbers
  on downwind. You just might find that you've exceeded 6 g's in your
  aircraft as you watch your wings embrace your cabin!
 Bryan Martin
 N61BM, CH 601 XL,
 RAM Subaru, Stratus redrive.
 do not archive.
  _________________ --
Bryan Martin
do not archive. |
		bryanmmartin
				 Posted: Thu Mar 20, 2008 1:05 pm    Post subject: Accident Prevention |
				The published Va for most aircraft is only valid at the aircraft's
 gross weight. You can exceed the airplane's flight load limit at lower
 weights at the published Va without stalling the airplane. At the
 lower weight, you probably won't over-stress the wing root attachment
 but you may over-stress other parts of the structure. Va should be
 decreased for weights less than gross weight.
 On Mar 20, 2008, at 1:55 PM, ernie wrote:
  	  | Quote: | 	 		   Thanks,
  Very interesting.
  118kt",
  reviewed...
 Bryan Martin
 N61BM, CH 601 XL,
 do not archive.
Bryan Martin
do not archive. |
		ashontz
				 Posted: Thu Mar 20, 2008 1:41 pm    Post subject: Re: Accident Prevention |
				Maybe this is the real problem. The 'in the pattern' accidents were the one's that disturbed me the most.
		n801bh(at)netzero.com Guest
				 Posted: Thu Mar 20, 2008 3:24 pm    Post subject: Accident Prevention |
				I saw Bob Hoover fly when I lived in Fla back in the 80's.. That video you gave a link to was a testimony to how damn good Bob Hoover really is. If you look up the word smooth in the dictionary there will be a color picture of him under the defination...
 Ben.
 Bob Dingley
 (http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001)  	  | Quote: |
 ">http://www.matronics.com/Navigator?Zenith-List
 tronics.com
 www.matronics.com/contribution
 _____________________________________________________________
 Put your loved ones in good hands with quality senior assisted living. Click now!
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Thu Mar 20, 2008 3:33 pm    Post subject: Re: Accident Prevention |
				I've been flying 33 years and doubt if I've ever pulled much more than 3 g's in any maneuvers, including steep turns. This is true even with all the students I've flown with.  If it was routine to pull that many g's we'd have broken airplanes all over the place.
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
				 Posted: Thu Mar 20, 2008 4:09 pm    Post subject: Accident Prevention |
				Yep
 I assumed this was calc , they did finite analyis on the wingwhy would
 the miss that
 On 3/20/08, Bryan Martin <bryanmmartin(at)comcast.net> wrote:
  > Thanks,
  > Very interesting.
  > 118kt",
  > reviewed...
  Bryan Martin
  N61BM, CH 601 XL,
  do not archive.
		planecrazydld(at)yahoo.co Guest
				 Posted: Thu Mar 20, 2008 5:32 pm    Post subject: Accident Prevention |
				very common thought - but untrue. It is theoretically impossible to overstress the airframe structure by deflection of the controls to limit at or below maneuvering speed. This does not address gust loading, vertical wind shear, and other transients that are frequently encountered during flight.
 Gordon <cscsail(at)gmavt.net> wrote:[quote] --> Zenith-List message posted by: "Gordon"
 Gordon
				 Posted: Thu Mar 20, 2008 6:14 pm    Post subject: Accident Prevention |
				Dave
 This report did a detailed investgation on how a aircraft could be
 damage at or below va with the right/wrong control inputs
 On 3/20/08, David Downey <planecrazydld(at)yahoo.com> wrote:
 [quote] very common thought - but untrue. It is theoretically impossible to
  flight.
  "Gordon"
  Gordon
		dredmoody(at)cox.net Guest
				 Posted: Fri Mar 21, 2008 7:27 am    Post subject: Accident Prevention |
				I second that motion Tim. I have flown several  times with friends in their aerobatic planes (Citabria Decathalon, Christen  Eagle, Steen Skybolt, Extra 300) and have found that the 4G entry / exit from an  inside loop is way, way more G load than I would ever confidently put my 601XL  through (once it is finished that is). Other pilots mileage may vary but nobody  needs to worry about me overstressing my XL. Hell, Bill of Georgia flies even  lighter touch than me so take us both off the worry list.
  Dred
		sdthatcher
				 Posted: Fri Mar 21, 2008 3:21 pm    Post subject: Accident Prevention |
				OK Jerry, I admit that being careful doesn't sound fun but if you're 67, you
 have obviously either been lucky or not as bold as you think.  Doing rolls,
 immelmans, etc., are not yank and bank flying!  Imagine decending to pattern
 altitude... the speed slowly builds up while you're watching one aircraft
 turn x-wind to join the downwind and another overflying the field. You bank
 hard right at 60-70 degrees to miss the aircraft overflying the field (to
 get an instrument rating I believe you've got to hold a 720, 60 degree bank
 without losing altitude, so this isn't too hard on the plane).  But Winds
 are gusting to 25 kts and suddenly you go vertical and pull back on the
 stick simultaneously while never noticing that you had exceeded maneuvering
 speed. Easily a 4-6 g maneuver. All I'm saying is that it can happen. Not
 often. Maybe never. But think about it when you are in the pattern.
 Another common error was mentioned previously regarding stalling the
 aircraft in a tight turn. I was doing some spot landings in a Mooney and
 while tuning base to final (and decending), I banked it hard over to at
 least 70 degrees. Engine was at idle.  I knew I was going to hit the spot on
 the runway, so I leveled off... except the plane would not level off! It
 continued the left turn and those famous words, "Oh S..t" were stated
 loudly. The wing had stalled and the controls were useless. I added power,
 nosed over (all this within about 50 feet of the ground) and the plane
 immdiately leveled off, I dropped the gear and missed the mark entirely!
 Moral of the story. Never make hard turns in the pattern or anywhere else
 unless absolutely necessary
 DO NOT ARCHIVE
 N601EL
 Message from Jerry Hey
 <<Surviving and living are not at all the same.  Putting around making
 gentle turns may extend your life but it is not living.  Yanking and
 banking are the important fun part of flying, much more so than
 sitting still in the left seat, afraid to twitch.   I love to fly.
 One of my old friends, flying a Tailwind, can't go from point to point
 without tossing in a roll ever so often.  One night, in pitch black,
 we did roll after roll as we cork screwed along, only the lights on
 the ground to pronounce right side up and our laughter filling the
 cabin.    That was living!   I would not have a plane that cannot
 handle a little fun.   Jerry  age 67   (701 scratch )>>
