orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Sat Mar 08, 2008 6:59 pm Post subject: TT mounting specifications |
Does anyone have the specs for the TruTrak flat pack DigiFlight II? I have the servos but am trying to wait until later in getting the head. However this then creates another problem and this is planning the instrument panel. I know the panel cut out sizes but not what goes behind the panel. Is the housing wider then the front panel? How far back does it go and what extra clearance is needed? I have searched their site and can not find any sizing documents.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
flagstone(at)cox.net Guest
Posted: Sat Mar 08, 2008 7:40 pm Post subject: TT mounting specifications |
Gary:
This ref has the overall dimensions. If the flat pack dimensions are
consistent with the standard model, the dimensions shown are for the case
size. I happened to have my standard version out and I checked its
dimensions. They agree to the site.
http://www.trutrakflightsystems.com/instruments.htm
Mark
toaster73(at)embarqmail.c Guest
Posted: Sat Mar 08, 2008 7:45 pm Post subject: TT mounting specifications |
Was looking at this earlier today too. The depth is shown on the product
page on the website as 5.5 inch, for flat pack or round. The cutout is in
the install manual. Be nice if they had a 3 view somewhere.
-Chris Lucas
#40072
Posted: Sat Mar 08, 2008 8:02 pm Post subject: TT mounting specifications |
The dimensions are on their website as '1.6” H x 4.3” W x 5.5” D'
whereas the cutout is 4.14" W and 1.44" H. The website has this on
the main info page for the instrument, although probably not in the
documents. They also ship with it a front plate that can be used, I
assume, to fit it into a radio stack width cutout.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 8, 2008, at 9:59 PM, orchidman wrote:
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
http://forums.matronics.com/viewtopic.php?p=168521#168521
billderou(at)yahoo.com Guest
Posted: Sat Mar 08, 2008 8:41 pm Post subject: TT mounting specifications |
Looks like you are getting this in pieces and unfortunately this is from memory.
The front top & bottom are 3/8" above and below the cutout, add 1/2" for each side. Use 5.5" for depth but add 2.5" for DB-25 connector and pitot/static connections.
Bill DeRouchey
#40029, flying
Chris <toaster73(at)embarqmail.com> wrote:
[quote]--> RV10-List message posted by: "Chris"
-Chris Lucas
#40072
orchidman
Posted: Sun Mar 09, 2008 5:42 pm Post subject: Re: TT mounting specifications |
Thanks all. This is getting real close to having the real thing. I believe I can safely position the location of the cutout on the panel now. I have one of the face plates (thanks to Stein and crew).
RV10 - # 40674
(N2GB Flying) |
