		scott.glaser(at)thedefian Guest
				 Posted: Thu Mar 13, 2008 1:36 pm    Post subject: Yak-52 Gen Fail Indication |
				High All,
 I'm having trouble with a Gen Fail Indication on my '52.  I was running on
 the ground in the RPM ranges where the gen should have been on line and the
 gen fail light was flickering.  I shut down and checked with my local guru
 who warned me of wire chaffing on the voltage regulator damper plate.  I did
 find a wire that was on it's way to being chaffed but that didn't seem to be
 all the way through the sheath.  I repaired the wire, reconnected the
 voltage regulator and ran the engine.  Much to my dismay the gen fail light
 is now on all the time.  I checked the reset button on the voltage gadget
 box on the firewall above the voltage regulator, it had not been tripped.  I
 also opened he circuit box on the right side behind the access panel and saw
 no smoking guns.  Any help or suggestions as to what could be the culprit
 would be greatly appreciated!
 Scott
 N8252
				 Posted: Thu Mar 13, 2008 1:57 pm    Post subject: Yak-52 Gen Fail Indication |
				Contact me at 252-671-7005
 Mark Bitterlich
				 Posted: Thu Mar 13, 2008 6:45 pm    Post subject: Yak-52 Gen Fail Indication |
				I'm certain by now you have talked to Mark and he has more eloquently said
 what I'm about to say. Having gone through exactly this with the help of
 Mark and Dennis it was sorted out. First thing to do is ohm out your fuses
 in the power panel. Unfortunately on the 52, it is behind your seat! You
 need to pull the fuses out of the circuit to check them otherwise all you
 are going to do is ohm out your circuit. I found that it was my 30 amp fuse
 that was between the main circuit between the BMP 200 and the carbon pile
 regulator. Sorry for my generality but my 52 wiring diagram is at the
 hanger.
 Start with the simple, check your fuses. If you have a need for a spare BMP
 200, I have one! :>)
 Doc
				 Posted: Fri Mar 14, 2008 10:54 am    Post subject: Yak-52 Gen Fail Indication |
				Actually Doc, I do not recommend checking fuses right off the bat with a
 problem like Scotts.  I am not a big fan of dive-bombing, although your
 recommendation to check fuses is of course always a good idea, and each
 person likes to do things their own way.
 Personally, in a case like Scotts... And no one really knows the whole
 story here since there is more that has happened than is in his original
 email... But regardless, I recommend going to the DNP-200 relay and
 putting an alligator clip on the bus line going to the generator.  Start
 the engine and watch the voltage.  Not only should it be there, but it
 should come up to 28 volts and start regulating with increase in engine
 RPM.  This is one test... It only requires removing a cover and a panel,
 and tells you a LOT.  If you have regulated voltage there, then it is
 likely that you have a DNP-200 issue, or a broken wire, etc.  If you
 have voltage, the next step is to check the enable terminal on the
 DNP-200 (pin V).  If you have NO voltage, you move your alligator clip
 right to the generator itself.  Shortly you get to the point where you
 check the fuses.  But for example, if you DO have voltage at the
 generator bus on the 200, there is simply no need to go yanking fuses to
 check... They're obviously good.
 Having worked with Marine Electricians on airplanes for almost the last
 4 decades, I can tell you that there are clearly two ways to go about
 fixing aircraft electrical issues.
 First Method:  "I saw this problem before, and this is what caused it
 last time, ok... Try replacing that part first.  If that does not work,
 start replacing one part after another until it does work."  This is
 typically the common method and is an example of your tax dollars at
 work.
 Second Method:  Look at the system.  Understand how it works.  Take
 measurements at critical points until you know what MUST be bad and why
 it caused the problem you are seeing.  Pull part and replace it, and
 know even before you turn it back on that it is going to work.
 I teach the second method.  The over-whelming desire by most everyone on
 this planet is to use the first method.
 Guess which method most general aviation guys typically use?
 Now another warning against the first method.   When you start swapping
 out parts, you have the distinct chance of screwing something else up,
 and now you have TWO problems on the same system, and that can be deadly
 to find.
 Scott started with a flickering generator light.  He was given a
 recommendation to pull the voltage regulator out and check for bad
 wiring.  He did that.  He saw a wire that needed attention.  He fixed
 that wire.  He put the regulator back in.  Now he has a totally dead
 generator with a constant generator light.  Hmmmm.
 Mark Bitterlich
		brian-1927(at)lloyd.com Guest
				 Posted: Fri Mar 14, 2008 12:33 pm    Post subject: Yak-52 Gen Fail Indication |
				On Mar 14, 2008, at 11:50 AM, Bitterlich, Mark G CIV Det Cherry Point,
 MALS-14 64E wrote:
  Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
 I guess that is what makes a horse race. I do tend to check the
 obvious things first, e.g. fuses and broken wiring. I find that gets
 about 80% of the problems without having to resort to the schematics
 and the multi-meter. But once I get past those obvious thing, I am
 right there with Mark.
 Brian Lloyd                         3191 Western Drive
 brianl AT lloyd DOT com             Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
