Alfred Buess
				 Posted: Sun Mar 16, 2008 9:09 am    Post subject: AW: The trials of fitting |
				Fred,
 Just a small hint before you run into the next trouble with your doors: Bond
 the shoot bolt guides into the fuselage structure only AFTER painting the
 doors inside! I had to learn the hard way, that painting can make the door
 fitting too tight. Implication:  The guides had to be taken out,
 repositioned and bonded in again. Good luck and lots of patience!
 Alfred
 Alfred Buess, CH-3052 Zollikofen, Switzerland
 E-Mail: ykibuess(at)bluewin.ch
 Europa XS #097, Monowheel, Foam wing, Rotax 912ULS, Airmaster 332 CS
 -----Ursprüngliche Nachricht-----
 Von: owner-europa-list-server(at)matronics.com
 [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Fred Klein
 Gesendet: Samstag, 15. März 2008 21:16
 An: europa-list(at)matronics.com
 Betreff: Re: The trials of fitting
 On Saturday, Mar 15, 2008, at 09:00 US/Pacific, ALAN YERLY wrote:
  	  | Quote: | 	 		   Trials of fitting, in a word is craftsmanship.
  Unless you have built cabinets with curved doors for a living, fitting
  the Europa doors or an any aircraft canopy is not an intuitive task.
 Yerlysan...you are indeed a master and I such a novice...this is said with
 total respect.
 It's reassuring to know that a pro plans for 40 hours/door set, I think I've
 been hard at it for about 3 weeks, just this morning succeeding in locking
 the shoot bolts within the fuselage after being satisfied w/ the hinge
 operation. I wish I had had the benefit of your process before beginning
 rather than accepting the build manual as gospel (until I hit some dead
 ends).
 Thank you for your comments on gapping, as how to properly allow for filler
 and paint has been something I've been scratching my head about; the goal
 being to have all gaps looking good AND functional after getting them back
 from the painter. I've been really surprised to find significant variations
 in the thickness of the filler/primer on the fuselage top in the vicinity of
 the tang recesses as delivered.
 I have one suggestion which may be helpful to others regarding the location
 of the hinges and their alignment. I happened to have a 6'
 length of 3/32" precision ground SS rod (from McMaster-Carr) which I
 temporarily substituted for the hinge pins while locating the hinge leaves
 on the tang. Used in conjunction w/ a straightedge, it really simplified
 alignment.
 Fred
 A194
 This message has been scanned for viruses and dangerous content by
 MailScanner, and is believed to be clean.
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
