		Dave Nixon
				 Posted: Tue Mar 18, 2008 3:42 pm    Post subject: Accident Hysteria |
				I have been reading about the nahsayers regarding the safety of the Zodiac CH601XL for over a week now. And frankly, I was starting to get worried about my recently completed project that just passed the Airworthiness inspection Friday last.
  So I started investigating the Accidents everyone was referring to. Here is a recap.
  NTSB ID: DFW07LA102 - CH601 XL - 9 month sport Pilot flew into weather at 12:45PM 05/02/07, destroying the airplane in flight. He flew into heavy IMC.  Now what would a 9 month sport Pilot Operator being doing in IMC? I just can't fathom it.  And while doing so, torn the wings off. I do not feel that this is a design flaw but a 'Stupid Pilot Trick'. Unfortunately, he probably didn't have enough hours to know that.
  NTSB ID: LAX07LA218 - CH601 HDS-  VFR - pulled power on base and needed power on final - couldn't get his 912 S to respond. He hit a house, flipped over. Upon examination, NTSB found that both carb bowls were varnished and empty.  Throttle cable was severely frayed.  Owner stated that he ran the engine about 11 times during the 6 year build process.  He ran it most during the recent taxi tests.  This was his first flight.
  And that, my friends is it for CH601s in America.
  And then we have the CH601XL Australian accident of an apparent canopy-bird collision (NO wing detachment)  and CH601HDS in Spain which, at this time appears to be pilot error (Stupid Pilot trick).
  It is good to be cautious but to call for a massive investigation due to a 'chicken little' mentality is absolutely not called for. Our time would be better spent learning all we can about the airplane and its powerplant by following AC90-89 to the letter and being safety conscious E
  You all can do what you want, but I am taking myself out of the "I'm In" gang. What I built is safe and well designed. Watch the NTSB reports for my first flight if you wish.
  Dave Nixon
  CH601XL 3300  tail No: N107R
  Airworthiness Inspected and ready for testing.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Mar 18, 2008 4:17 pm    Post subject: Accident Hysteria |
				I think the 601XL is a safe design. But I think you need to expand your search criteria. For example, what about LAX06LA105?
 Accident occurred Wednesday, February 08, 2006 in Oakdale, CA
  Probable Cause Approval Date: 3/26/2007
  Aircraft: Hooker Zodiac 601XL, registration: N105RH
  Injuries: 2 Fatal.
 The problem with the NTSB database and experimental aircraft is that I can register my plane as anything I wish to name it.
 -- Craig
 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dave Nixon
  Sent: Tuesday, March 18, 2008 5:39 PM
  Subject: Accident Hysteria
 It is good to be cautious but to   call for a massive investigation due to a 'chicken little' mentality is   absolutely not called for. Our time would be better spent learning all we can   about the airplane and its powerplant by following AC90-89 to the letter and   being safety conscious.
 Dave Nixon
                                                 	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Zenith-List  | 	  0123456789
		purplemoon99(at)bellsouth Guest
				 Posted: Tue Mar 18, 2008 4:19 pm    Post subject: Accident Hysteria |
				Dave , what about the instructor in virginia? that was a 601,  and what about the instructor and the owner that went down in calif. ? that was  a 601 both were in the trafic pattern and both had instructor's flying, no  neg  G's  no stunt flying," no stupid pilot tricks " and no noticeable  abrupt  elevator movement, even at that they were at landing speed...   One plane was factory built and one was a kit....  FACT ,both  had the  same end results  wing's folded up...      ?????      Joe  N101 HD   601XL/RAM
  [quote]   ---
		ernieth(at)gmail.com Guest
				 Posted: Tue Mar 18, 2008 4:46 pm    Post subject: Accident Hysteria |
				I think this was the first flight with the wings reattached. The
 question was how it was attached. Report could not determine what
 happened
  do you thing bolts and things fail with no unusal loads? Something
 was no put together right
 do no archive
 On 3/18/08, Southern Reflections <purplemoon99(at)bellsouth.net> wrote:
 [quote] Dave , what about the instructor in virginia? that was a 601, and what about
				If by "instructor in virginia", "One plane was factory built" and "both  had
 the same end results  wing's folded up" you are including Jim Pellien's
 crash then you are seriously confused:
 NTSB Identification: NYC07FA025.
 The docket is stored in the Docket Management System (DMS). Please contact
 Records Management Division  <http://www.ntsb.gov/info/sources.htm#pib>
 14 CFR Part 91: General Aviation
 Accident occurred Saturday, November 11, 2006 in Basye, VA
 Probable Cause Approval Date: 7/25/2007
 Aircraft: Czech Aircraft Works CH 601 XL RTF, registration: N601VA
 Injuries: 1 Fatal.
				 Posted: Tue Mar 18, 2008 4:56 pm    Post subject: Accident Hysteria |
				Flight into weather like that is pilot error and is a matter of luck
 that this or any plane makes it though
 -1
 On 3/18/08, Sabrina <chicago2paris(at)msn.com> wrote:
  The CA 02/06 aircraft was flown near weather so severe that a ferry pilot
  had to divert. The leading edges had elongated rivet holes upon inspection
  after the crash. Was it the final flight or the ferry flight that caused
  the elongated leading edge rivet hole damage?
  The S-LSA was heard to "explode" first, and then a wing fold, same with the
  Spanish crash.
  Another weather fold was already mentioned and a bird strike = 5.
  http://forums.matronics.com/viewtopic.php?p=170801#170801
				 Posted: Tue Mar 18, 2008 6:20 pm    Post subject: Accident Hysteria |
				Sure Do, AllI say is WHY.....      Joe                 N101HD
				 Posted: Tue Mar 18, 2008 6:24 pm    Post subject: Accident Hysteria |
				You're right, my  mistake...    fuel          I'am  sure there was another... Have to look in my pile of papers  from last  year, or the year  before...                      Joe N101HD
  [quote]   ---
		jmaynard
  Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
				 Posted: Tue Mar 18, 2008 7:48 pm    Post subject: Accident Hysteria |
				On Tue, Mar 18, 2008 at 06:04:19PM -0700, Sabrina wrote:
  	  | Quote: | 	 		   agreed... just build the airplane to specs!
 That doesn't explain the factory aircraft's inflight breakup. That's the one
 that has me the most concerned.
 Jay Maynard, K5ZC                   http://www.conmicro.com
 http://jmaynard.livejournal.com      http://www.tronguy.net
 Fairmont, MN (FRM)                        (Yes, that's me!)
 AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
  _________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
		notsew_evets(at)frontiern Guest
				 Posted: Tue Mar 18, 2008 8:08 pm    Post subject: Accident Hysteria |
				Are you Maynard that lives on Walts Way ????
		jmaynard
				 Posted: Tue Mar 18, 2008 8:18 pm    Post subject: Accident Hysteria |
				On Tue, Mar 18, 2008 at 09:05:37PM -0700, steve wrote:
  	  | Quote: | 	 		   Are you Maynard that lives on Walts Way ????
 Nope...Oakwood Drive.
		jmaynard
				 Posted: Wed Mar 19, 2008 4:35 am    Post subject: Accident Hysteria |
				On Tue, Mar 18, 2008 at 10:28:03PM -0700, Sabrina wrote:
  	  | Quote: | 	 		   Check out the S-LSA's fuel and exhaust system.  The factory built had an
  exhaust system with 5 times the length of exhaust pipe, 10 times the
  amount of exposed (non-heat muffed and much hotter) surface and fuel lines
  running down both sides of the engine.  The amount of leverage or stress
  on the exhaust ports for cylinders 1 and 2 are much greater on the S-LSA
  version.
 now you've got me curious, because when I looked at the factory version
 during my visit to the factory, it didn't strike me as being unusual as far
 as GA exhaust systems go. Are there pictures of yours somewhere we can see
 for comparison?
		Iberplanes
  Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
				 Posted: Wed Mar 19, 2008 5:58 am    Post subject: Accident Hysteria |
				Hello Dave,
  [quote]   Take into account the 601 crashed in Barcelona was an   XL.
    Bye,
    Alberto Martin
 Iberplanes IGL
 http://www.iberplanes.es
 Igualada -    Barcelona - Espaņa
  _________________ Alberto Martin
601 XL - Jabiru 3300
Igualada - Barcelona - Spain |
		bill_dom(at)yahoo.com Guest
				 Posted: Wed Mar 19, 2008 6:00 am    Post subject: Accident Hysteria |
				Every now and then I see posts from people who don't seem to be clear as to what accidents/incidents are the ones causing concern. For the benefit of these peoples, here are the incidents in question:
 LAX06LA105 Oakdale, CA. Wing folded up. A witness stated that he saw the wings "visibly vibrate" and then "left wing collapsed and folded rearward against the fuselage"
 DFW07LA102 Canadian, TX. This is the guy that flew into IMC and his plane broke up in flight. No witnesses.
 LAX07FA026 Yuba City, CA. A factory build AMD that broke up in flight. One witness sated that he heard an explosion and "observed the center section of the airplane falling straight down"
 Then you have the Australian and Spanish incidents.
 In the Australian incident, a bird strike is suspected.
 In the Spanish incident, a wing folding up in flight is suspected.
 Another 2 incidents that have fueled concerns are the 2 cases of wing flutter, one by a member of  this list when he overflew a power plant and a the other one that affected an AMD Zodiac in South Florida.
 William Dominguez
 Zodiac 601XL Plans
 Miami Florida
 http://www.geocities.com/bill_dom
				 Posted: Wed Mar 19, 2008 6:19 am    Post subject: Accident Hysteria |
				And with the Aussie crash the "witness" first  interviewed said " The PROP STALLED".    Go  figure....SW
  [quote]   ---
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Wed Mar 19, 2008 7:06 am    Post subject: Re: Accident Hysteria |
				While not commenting on the design of the XL I do want to make a comment on pilot skills.  I have been a pilot over thirty years and CFII for 23.  I also used to go to a lot of airshows as crew of a WWII B25.  I met a lot of very experienced and sometimes "famous" pilots, that have since killed themselves in airplanes.
 What I have learned from all this and what I remind myself each time I fly is that anyone can use poor judgement and anyone can make a mistake.  Not enough fuel, too short a runway, weather worse than forecast, etc.  All these are traps waiting for the unwary.  Some pilots just don't know any better, while others know better but think that their superior skills will carry them thru. Regardless of your ratings or flight hours, when you start getting too comfortable in an airplane the alarm bells should be going off.
 I have no plans to quit building my XL.  I intend to build it to the plans, fly it within the design envelope and keep my eyes open for anything that might lead to trouble.  I'll also continue to follow the comments expressed on this list but will put my faith in facts, not conjecture.  Discussion is healthy and can help lead to solutions, but so  much of what I've read recently seems to have little substance backing it up.  I know it is hard to be patient but I think the answers we're all waiting for will soon be forthcoming and that we should try to take a calm and reasoned approach to the issue.
 Tim
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		Larry Hursh
  Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
				 Posted: Wed Mar 19, 2008 9:35 am    Post subject: Accident Hysteria |
				Well said Tim - my sentiments exactly!
   Larry H
 Tim Juhl <juhl(at)avci.net> wrote:
   [quote]--> Zenith-List message posted by: "Tim Juhl"
 Tim
 ______________
 CFII
 Champ L16A flying
 Working on fuselage
 Read this topic online    [quote][b]
  _________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
		japhillipsga(at)aol.com Guest
				 Posted: Thu Mar 20, 2008 8:38 am    Post subject: Accident Hysteria |
				Tim, I have not commented on any of these gloom and doom threads, but I can assure you that the XL if built correctly is a tough little bird. I have been into a few situations that scared me wet and she held together. When I hear about wing this and re design that, rib, bolt or whatever I know the fault was out side the ZAC design and the correct materials and can be laid at the feet of the pilot or some unforeseen force of nature that exceeds max. "You can't out fly stupid". Keep building and so if you want to fly in my XL-3300 with dual sticks, just let me know. My 2 cents, Best of luck, Bill of Georgia N505WP, 601XL 126 Hrs
		Larry Hursh
				 Posted: Sat Mar 22, 2008 8:29 am    Post subject: Accident Hysteria |
				Thanks for clarifying the list of accidents and incidents.  My question is has any of the Heinz Family responded to any of these with real answers to why they happened???  I AM concerned as I'm sure most of the list is too.
   Larry Hursh
   CH601XL (N601LL Reserved)
 William Dominguez <bill_dom(at)yahoo.com> wrote:
    	  | Quote: | 	 		  Every now and then I see posts from people who don't seem to be clear as to what accidents/incidents are the ones causing concern. For the benefit of these peoples, here are the incidents in question:
 William Dominguez
 Zodiac 601XL Plans
 Miami Florida
