Vent lines (was fuel pressure problems)
carl.froehlich(at)cox.net
PostPosted: Wed Mar 19, 2008 2:15 pm    Post subject: Vent lines (was fuel pressure problems) Reply with quote
On my RV-8A I transitioned the ¼” vent tubing to 3/8” about 6” before exiting the bottom of the fuselage.  I also epoxied a piece of aluminum screen on the bevel end cut that faces into the wind.  I read someplace that a few RVs had problems with mud dabbers plugging up the vent line.  I’ll do the same on the RV-10.
Carl Froehlich
RV8A (400 hrs)
RV-10 (wings)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam
Sent: Wednesday, March 19, 2008 10:22 AM
Subject: Re: Fuel pressure problems
I was in light icing on Sunday, coming back from the Cayman Islands, and that was the first thing that crossed my mine. I wasn't to worried about the wing, but that little cold soaked 1/4 vent tube, had my stomach in knots!
David McNeill wrote: [quote]--> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net> One other thing I have done is drill a small (50) hole in the vent lineinside the fairing. This does not affect the tam pressure much and providesan alternate vent in case of icing. Since the caps are not vented, an icingof the forward facing vent line could close the vent and result in fuelstarvation and/or deformed tank. --
sam(at)fr8dog.net
PostPosted: Wed Mar 19, 2008 3:30 pm    Post subject: Vent lines (was fuel pressure problems) Reply with quote
Well, I just got back from the hangar, and I'm embarrassed to say, but I didn't finish the vents before they were installed. Thy were not only straight cut but about an inch or more to long. They are standard now though, except for the right one, and I added a vent inside the faring just in case of an inadvertent icing encounter.We'll see how that works out on the next test flight. Just to low of a ceiling to fly today.
Sam
Carl Froehlich wrote: [quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Carl Froehlich
RV8A (400 hrs)
RV-10 (wings)
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Sam
