Wiring 3300 to an alternator switch
Goto page Previous  1, 2, 3  Next
BobsV35B(at)aol.com
PostPosted: Sat Mar 22, 2008 7:37 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Good Evening Noel,
I note that the one you googled is dated as revision 4. My copy is revision
3 and I see that revision 4 shows all new pages!
I guess I will have to print a whole new manual. I wonder if they really did
revise every page or if they just decided to list all of them as new? That's
an awful lot of wasted paper!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 3/22/2008 10:21:22 P.M. Central Daylight Time,
noelloveys(at)yahoo.ca writes:
I just googled jabiru Schematic and came up with this: (top of the page!)
_www.usjabiru.com/images/pdf/manuals/new%20stuff/3300HL-IM.pdf_
(http://www.usjabiru.com/images/pdf/manuals/new%20stuff/3300HL-IM.pdf)
Everything you wanted to know about Jabiru engines and more besides...
Check out page 54 for a circuit diagram. That diagram shows the output to the
battery being switched ( Master) and protected by a fuse link. The feed to the
main buss is not switched or protected.... I’d recommend a breaker of at
least the capacity of the alternator. Funny on page 57 they say to hook up the
battery direct... I don’t htink they looked at their own schematic and that’
s what I’d go by.
According to page 56 you can put a switch on the red wire that comes from
pin #5 on the voltage regulator and then feed the output of that switch to the
main buss.
A word of caution here the solid state ( lots of diodes and transistors)
rectifier/regulator may not be able to stand switching the alternator on and
off during normal flight so save turning off the line to the main buss as an
emergency procedure.
Noel
From: owner-jabiruengine-list-server(at)matronics.com
[mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Saturday, March 22, 2008 2:17 PM
Subject: Re: Re: Wiring 3300 to an alternator switch
Good Morning Once Again Ron,
That information has been very helpful in directing me to some of the
problems I had wondered about. Do you have any idea how sophisticated is the
controlling device associated with the Jabiru? Sounds like Evinrude has done quite
well!
The diodes I do understand. They were being discussed as the future when I
went through school and I have kept abreast of such development. All of the
principles mentioned are still the same as before, full wave rectification and
all, but I still do not have good handle on the voltage regulation fine
points. It appears as if they just sink excess current.
Sounds kinda hairy to those of us familiar with power conservationist
attitudes. My training was in the day of carbon pile regulators.
Thanks again, I now know that I can reference outboard motors for more
information.
Have you found any documentation that is specific to how Jabiru controls or
regulates the output?
Is there any sort of over voltage protection provided? While I am not
generally a fan of "Crow Bar" protection. this might be used here to good
advantage. It would be a shame to blow several thousand dollars worth of electronics
if a battery connection were to fail.
So much to be learned!!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/22/2008 10:44:28 A.M. Central Daylight Time,
kc7hfa(at)totalusa.net writes:
I learned electronics many years ago, while in the military. I just
googled "permanent magnet regulator" and found this
http://continuouswave.com/whaler/reference/PMA.html it gives a description of how the electricity is
generated then how it's converted to DC via the regulator... Hope it helps
BobsV35B(at)aol.com
PostPosted: Sat Mar 22, 2008 7:41 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Ah yes! The vaunted Vicker's Drive.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/22/2008 10:27:15 P.M. Central Daylight Time, noelloveys(at)yahoo.ca writes:
Nothing with a turbine would have one! They also use variable displacement pumps to keep their alternators turning at a constant speed.
Noel
Create a Home Theater Like the Pros. Watch the video on AOL Home.
Float Flyr
PostPosted: Sat Mar 22, 2008 7:45 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
The regulator case itself should be a heat sink. In this case the regulator actually workd as a transistor controlled voltage divider circuit. The fuse link protects the battery and as I said I also recommend a switch or better yet a circuit breaker between pin 5 of the regulator and the main buss. Output is 20 amp continuous I think I would try a 20A breaker and if you start blowing it install a load meter and a 30A breaker. Under no circumstances though load the alternator past 20A continuous duty
Noel
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Peter Harris
Sent: Saturday, March 22, 2008 10:18 PM
Subject: RE: Re: Wiring 3300 to an alternator switch
Bob,
You are right about the excess current it is taken to earth at the base of the regulator which should be mounted on a heat sink panel. AC output from the PM alternator varies with RPM and the excess energy is bled off to earth during the rectification/regulation process.
It sounds a bit primitive but it is simple and effective. Over voltage protection is worthwile in case the regulator burns out.
Peter H
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Sunday, 23 March 2008 2:47 AM
That information has been very helpful in directing me to some of the problems I had wondered about. Do you have any idea how sophisticated is the controlling device associated with the Jabiru? Sounds like Evinrude has done quite well!
The diodes I do understand. They were being discussed as the future when I went through school and I have kept abreast of such development. All of the principles mentioned are still the same as before, full wave rectification and all, but I still do not have good handle on the voltage regulation fine points. It appears as if they just sink excess current.
Sounds kinda hairy to those of us familiar with power conservationist attitudes. My training was in the day of carbon pile regulators.
Thanks again, I now know that I can reference outboard motors for more information.
Have you found any documentation that is specific to how Jabiru controls or regulates the output?
Is there any sort of over voltage protection provided? While I am not generally a fan of "Crow Bar" protection. this might be used here to good advantage. It would be a shame to blow several thousand dollars worth of electronics if a battery connection were to fail.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/22/2008 10:44:28 A.M. Central Daylight Time, kc7hfa(at)totalusa.net writes:
--> JabiruEngine-List message posted by: "KC7HFA" <kc7hfa(at)totalusa.net>
I learned electronics many years ago, while in the military. I just googled "permanent magnet regulator" and found this http://continuouswave.com/whaler/reference/PMA.html it gives a description of how the electricity is generated then how it's converted to DC via the regulator... Hope it helps.
Ron Asbill
N601ZX - CH-601 XL
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sat Mar 22, 2008 7:49 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
The problem isn’t in shutting down the line to the main buss... Damage to the regulator can be done when you turn on the alternator to the buss during heavy loads. If for some reason you want to shut down the output to the buss in flight you should shed all load on the buss before reconnecting the regulator output to the buss.
Noel
Sent: Saturday, March 22, 2008 10:54 PM
Good Evening Peter,
Thanks for the information.
Do most Jabiru operators use some sort of over voltage protection? Is there a common method that has been successful?
As I am sure you can tell, my knowledge in this area is woefully inadequate.
Are there any good sources of data that I can study?
If a contactor was opened by a crowbar or other over voltage protection such that it would save the electronics, would the alternator still be damaged or is there some modality that would cause it to reduce it's output?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/22/2008 7:51:24 P.M. Central Daylight Time, peterjfharris(at)bigpond.com writes:
Bob,
It sounds a bit primitive but it is simple and effective. Over voltage protection is worthwhile in case the regulator burns out.
Peter H
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
BobsV35B(at)aol.com
PostPosted: Sat Mar 22, 2008 7:55 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Printed and stuck in the manual!
Thanks Noel.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/22/2008 10:46:47 P.M. Central Daylight Time, noelloveys(at)yahoo.ca writes:
Noel
Float Flyr
PostPosted: Sat Mar 22, 2008 8:06 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Great!  Have look at the list of revised pages which follows the table of contents.  It will give you a list of all the updated and added pages...  Saves wear and tear on the printer, paper and cartridges.  You may have to make notes of the different pages you will need and print only those pages...  The old pages can go in the bottom of the bird cage.
Noel
Sent: Sunday, March 23, 2008 1:05 AM
Good Evening Noel,
I note that the one you googled is dated as revision 4. My copy is revision 3 and I see that revision 4 shows all new pages!
I guess I will have to print a whole new manual. I wonder if they really did revise every page or if they just decided to list all of them as new? That's an awful lot of wasted paper!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/22/2008 10:21:22 P.M. Central Daylight Time, noelloveys(at)yahoo.ca writes:
Everything you wanted to know about Jabiru engines and more besides... Check out page 54 for a circuit diagram. That diagram shows the output to the battery being switched ( Master) and protected by a fuse link. The feed to the main buss is not switched or protected.... I’d recommend a breaker of at least the capacity of the alternator. Funny on page 57 they say to hook up the battery direct... I don’t htink they looked at their own schematic and that’s what I’d go by.
According to page 56 you can put a switch on the red wire that comes from pin #5 on the voltage regulator and then feed the output of that switch to the main buss.
A word of caution here the solid state ( lots of diodes and transistors) rectifier/regulator may not be able to stand switching the alternator on and off during normal flight so save turning off the line to the main buss as an emergency procedure.
Noel
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Ron Asbill
N601ZX - CH-601 XL
http://www.matronics.com/Navigator?JabiruEngine-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution st href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List.matronics.com/">http://forums.matronics.com
5
6
7
8
9
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Peter H
PostPosted: Sat Mar 22, 2008 11:16 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Hi Bob,
My knowledge is a bit patchy. The best source for good info is aeroelectrics list found in the Matronics group or you could Google for Bob Nucholls Aeroelectric Connection. He has a diagram for the crowbar over voltage protection (OV) which disconnects a runaway alternator if the regulator should fail. Then the life of the alternator would depend on the mode of failure. Normally overvoltage goes to earth through the regulator but if the Reg. went OC and with no OV protection then your main bus will be exposed to the unregulated alternator output which goes up to 60VAC
There is also another alternative circuit which could be used for OV protection and which would allow the alternator to remain connected. Basically this alternative OV circuit is like a supplementary regulator which starts to work if the supply voltage goes above 15V.
Old Peter (1938 vintage)
Sent: Sunday, 23 March 2008 11:24 AM
Subject: Re: JabiruEngine-List: Re: Wiring 3300 to an alternator switch
Good Evening Peter,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Bob,
Peter H
jetboy
PostPosted: Sat Mar 22, 2008 11:52 pm    Post subject: Re: Wiring 3300 to an alternator switch Reply with quote
Bob if I can help explain the type of system used by Jabiru I hope it aids your wiring choice.
Some texts refer to the PMA as a dynamo. The Jabiru assembly is similar to most Japanese and Harley motorcyles- not the old brit bikes that used Lucas -the prince of darkness- electrics.
Early 3300 used a 3-phase stator, which requires a six diode rectifier stack like most automotive "alternators" have. In theory, this is much better for the output filtering because the ripple from a 3 phase is much less than the "on-off" flow from a single phase winding.
Old motorcycles and Rotax 2 strokes used a shunt regulator to limit the output. This was in the form of a selenium pile mounted under the headlight for cooling on the bikes or a triggered diode (SCR) switch module on the rotax. When the output got above 14 volts the shunt device would load the stator windings and the current would be limited by the available magnet strength. the Rotax units had a habbit of failing open circuit leaving 50 volts to burn up whatever I had connected downstream.
You can choose a linear series regulator, Powermate or B+C LR3 come to mind. The limitation on these is that they are, much like a carbon pile, in the line and reduce the current by turning it to heat. The big advantage is the output is much cleaner. If they fail it will usually be short cct and that is not favourable to your avionics, so these normally need or incorporate some overvoltage crowbar.
Newer motorcycles, Jabiru and i believe Rotax 912 use a series switching regulator. That is, when the transistors see the voltage applied to the yellow 'sense' wire is lower than the internally preset reference voltage, the bridge rectifier is triggered on. this is by activation of the two SCRs that are in the -ve legs of the bridge. The SCR that is conducting remains conducting until the end of the AC cycle coming from the stator windings, at this time the SCR remains non conducting unless there is a fresh trigger from the transistors that sense the voltage.
The advantage of this regulator is that no current is dumped to ground, and as it is switching on it does not get hot. It is either on or off. the battery has to absorb the excess of the 'on' pulse which can be a problem if you run without battery connected or with sense wire disconnected. SCRs usually fail 'open cct' so there will be no output hence there is little need for other overvolt protection, so long as the sense wire is ALLWAYS in connection with the output wire.
If you wish to be able to turn off the PMA, I would suggest switching one of the AC stator wires. The Jabiru manual is not very clear here, in 3 places it shows different recommendations. I would follow the text that calls for yellow and red to be joined and connected direct to battery studs, or via a fuse link (this is a bolted fuse element or a short crimped thin wire in the engine bay- you cannot fix a problem of a magnitude that would cause this fuse to blow anyway)
If you wish to use the 'charge fail' lamp facility as depicted in the sample wiring schematic for J250 aircraft, you will then need to disconnect some of the regulator from the battery via the master switch. My option would be to use a double pole master and wire the lamp via the spare pole. This would avoid flat battery whilst preserving the direct regulator-battery connection. Dont blame me if you did it another way and have burnt parts!
Regards, Ralph
telecommunications engineering is my day job
part-time avionics and PT6 instrumentation troubleshooter
CH701 with Jabiru 2200a
and yes I have a turbine and it DOES have a PMA. came off an A7
Ralph - CH701 / 2200a
Gilles.Thesee(at)ac-greno
PostPosted: Sun Mar 23, 2008 3:11 am    Post subject: Wiring 3300 to an alternator switch Reply with quote
Noel Loveys a écrit :
Generators and magnetos are somewhat limited in their capacity to
generate electrical power so over voltage is not generally a
consideration.
Noel and all,
Whereas I would second you on the self limited *current* capacity of
permanent magnet alternators, I beg to differ on the over *voltage*
issue : a PM alternator cannot prevent from producing voltage when
spinning, and if the regulator fails, voltage may climb as up as 80-100
volts according to model and rpm.
A good battery may temporarily soak the voltage excursion, but those
values are sufficient to damage any avionics if not taken care of on
time. So overvoltage protection is worth some consideration if expensive
avionics is installed.
As mentioned elsewhere, the Aeroelectric website and list provide really
valuable information and circuit architecture suggestions. The
experience an knowledge there are hard to beat.
FWIW
Best regards,
Gilles
http://contrails.free.fr
BobsV35B(at)aol.com
PostPosted: Sun Mar 23, 2008 4:22 am    Post subject: Wiring 3300 to an alternator switch Reply with quote
Good Morning Noel,
I did look at the list of revised pages and they show ALL pages as having been revised!
I don't mind the paper so much, but all that ink!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/22/2008 11:07:43 P.M. Central Daylight Time, noelloveys(at)yahoo.ca writes:
Noel
BobsV35B(at)aol.com
PostPosted: Sun Mar 23, 2008 5:08 am    Post subject: Wiring 3300 to an alternator switch Reply with quote
Good Morning Peter,
I have been monitoring the matronics list for several years and 'Lectric Bob for at least twenty years. I do have several copies of the Connection plus it's predecessor from the Down By The Riverside Press!.
I even attended one of his seminars a year or so ago.
That is probably why I am so concerned as to how the permanent magnet alternator can be deactivated so that it will not fry the electronics nor tear itself apart. I think I do understand the use of a crow bar to save the panel, but the runaway alternator has me concerned.
I had no idea there was such a thing available as a permanent magnet alternator. I guess every time it was mentioned, I disregarded and skipped over it because I worked only on military and certified aircraft electrical systems. Never messed with outboards, lawn mowers or snow mobiles.
Thanks for all the help you and others have provided.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/23/2008 2:17:40 A.M. Central Daylight Time, peterjfharris(at)bigpond.com writes:
Hi Bob,
BobsV35B(at)aol.com
PostPosted: Sun Mar 23, 2008 5:18 am    Post subject: Wiring 3300 to an alternator switch Reply with quote
Good Morning Ralph,
That helps a lot!
My learning curve is still on the way up. Your fine explanation has been printed and added to the manual.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/23/2008 2:56:52 A.M. Central Daylight Time, sanson.r(at)xtra.co.nz writes:
Float Flyr
PostPosted: Sun Mar 23, 2008 1:56 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Thanks Ralph:
It’s always good to learn more.
I was under the understanding that the carbon pile actually lowered the voltage when it came into problems.,, Which were generally crystallization of the piles.
I can see the switching one of the stator wires but couldn’t see the advantage of that.
Does your turbine produce 400 Hz three phase??
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Peter H
PostPosted: Sun Mar 23, 2008 2:38 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Gilles and Ralph,
If the J3300 is fitted with a series switching regulator does this mean that
the alternator AC output is switched on or off the bridge connection and it
would go OC when the battery is fully charged and there is no load dumping
to earth?
Does this mean that the regulator is safe and does not require OV protection
or do we need OV protection for interruption of a heavy DC current on the
busbar side?
Peter H ( I suppose this should be on the aeroelectrics list)
Float Flyr
PostPosted: Sun Mar 23, 2008 3:44 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
To be honest I didn’t look at the list of revised pages... Happy printing... I hate the cost of cartridges too.
Noel
Sent: Sunday, March 23, 2008 9:49 AM
Good Morning Noel,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
BobsV35B(at)aol.com
PostPosted: Sun Mar 23, 2008 4:49 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Good Evening Noel,
All 110 pages have been revised, the bulletins brought up to date, and we will be heading to Texas tomorrow to help our Granddaughter install the 3300 Jabiru engine in her Quick Built Legend Cub!
Thanks for all the help from everyone. I have learned a lot about permanent magnet alternators in the last few days.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/23/2008 6:45:49 P.M. Central Daylight Time, noelloveys(at)yahoo.ca writes:
Noel
lbmathias(at)verizon.net
PostPosted: Sun Mar 23, 2008 5:48 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
PostPosted: Sun Mar 23, 2008 5:50 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Hey guys,
Try www.inksell.com for good prices on printer cartridges; they are much cheaper than those you buy in any store. They aren't the printer mfgr brand but I have had no problem for the past couple years I have been using them.
Linda
BobsV35B(at)aol.com
PostPosted: Sun Mar 23, 2008 6:22 pm    Post subject: Wiring 3300 to an alternator switch Reply with quote
Good Evening Peter,
Just a bit of information if you will. What is an SCR?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/23/2008 5:39:47 P.M. Central Daylight Time, peterjfharris(at)bigpond.com writes:
jetboy
PostPosted: Sun Mar 23, 2008 6:37 pm    Post subject: Re: Wiring 3300 to an alternator switch Reply with quote
Peter & Noel
If I wanted to disable the alternator I would switch the AC off rather than the rectified and regulated DC. 3 reasons: switching the DC does not isolate your windings from burning up. Switching the DC involves another infirm connection and much longer path to the battery. The rating of the switch required is lower and the AC line is prior to the regulator so any voltage drops are not affecting the output.
The series switching regulator, when up to full voltage on the DC bus, is OC, and the AC available from the PMA is not consumed. The windings stay cool, and there is no load on the engine because the magnets are passing a coil that is not connected anywhere.
If wired in a safe configuration and with a battery or capacitor across the output it should not need any further OV protection. Interrupting a heavy load off the DC bus will not cause the regulator do go OV. Anytime the sense wire is not directly connected to the output, you need another form of protection, because the voltage control loop is open, and like an automotive alternator, full output will be made available to all in its path.
Bob's aerolectric Z20 looks to be a safe method, and has the fusible links to isolate any faulty units from further harm.
Ralph.
PS the turbine with a PMA is a JFS100 APU, the alternator is for 24 volts (at) 4 amps and only uses a rectifier. It gives me no trouble, but the igniter box is another story.....
Peter H wrote:
Gilles and Ralph,
to earth?
busbar side?
Page 2 of 3
