drfred(at)suddenlinkmail. Guest
Posted: Fri Mar 21, 2008 11:35 am Post subject: Manifold pressure port |
Can anybody give me a hint as to where the hook up is for the manifold
pressure on a IO 540 E4 A5 engine? Looks like there should be a 1/4
nipple to connect the hose that goes to the sensor. I can't seem to
find the port in the overhaul manual.
Thanks in advance.
And to the gentleman getting the tools. Get the good springback dimple
dies. Worth their weight in gold.
Fred Williams
40515
In the "now where does this wire go? " part of finishing.
BPA(at)bpaengines.com Guest
Posted: Fri Mar 21, 2008 11:43 am Post subject: Manifold pressure port |
Fred,
You can pull your MP from the #5 cylinder intake port. There should be a
gallery plug (1/8 pipe)right under the oil drain back fitting by the
rocker box cover.
Allen
BPE, Inc.
Posted: Fri Mar 21, 2008 3:07 pm Post subject: Manifold pressure port |
Got it . Thanks.
Fred
BPA wrote:
Fred,
rocker box cover.
Allen
BPE, Inc.
