lgold(at)quantum-associat Guest
Posted: Thu Mar 20, 2008 3:03 pm Post subject: Does it have a Clutch? |
How can I find out if my 912ULS includes a clutch? I understand that Rotax started including them with all 912s about the time my engine was purchased, about 4-years ago. Since I purchased it, unused, with my Zenith kit (it now has about 25 hours on it) I never got any documentation about this. I have been told that, with a clutch, the engine would do a lot better in a prop strike.
The engine's SR is 5643233.
Les
docyukon(at)ptcnet.net Guest
Posted: Thu Mar 20, 2008 3:37 pm Post subject: Does it have a Clutch? |
Les You can tell by the part# of the gearbox, the # will be stamped on the top of the gearbox. 888-560 = no clutch 887-712 = with clutch. If your # is other, I can probably cross check. Doc
Posted: Thu Mar 20, 2008 6:06 pm Post subject: Does it have a Clutch? |
Thanks Doc,
I'll check the number next time I'm at the airport.
Les
[quote] From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Bill and Marsha
Sent: Thursday, March 20, 2008 4:33 PM
To: rotaxengines-list(at)matronics.com
Subject: Re: Does it have a Clutch?
Posted: Fri Mar 21, 2008 10:03 pm Post subject: Does it have a Clutch? |
Doc,
My gearbox part number is 887-703. Clutch, or no clutch? ....and how do you find this information?
Les
Thom Riddle
Posted: Sun Mar 23, 2008 11:36 am Post subject: Re: Does it have a Clutch? |
Les,
Look in a Rotax Parts Manual to find the part number and description. I believe (as in not certain) the last three digits indicate various versions of prop shaft depending upon whether or not it has accommodation for options like governor for constant speed props or other variations, including which engine it is for, as in 912UL/A/F/ULS/S or 914UL/F. I also think that the first three numbers, in your case 887, indicate that the gearbox does have a clutch. The 888 series do not have the clutch.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun Mar 23, 2008 7:35 pm Post subject: Does it have a Clutch? |
Thom,
I did look at the parts list and Doc (is email is "Bill and Marsha") also
confirmed that my gear box has a clutch. I guess now I can break a prop or
two without destroying my crank shaft (maybe).
Thank you,
Les
[quote] --
