		txpilot
				 Posted: Tue Mar 25, 2008 3:10 pm    Post subject: KX-155 Audio Out |
				I have a KX-155 and a Sigtronics Sport 200 intercom.  I'm trying to figure out the proper wiring between units.  The KX-155 has an 'audio hi' and 'audio lo' for both the comm and nav.  I'm confused what is meant with the 'hi' and 'lo'.
 Are the 'audio hi' connections supposed to go to the common blue intercom wire, common with the headset jacks, while the 'audio lo' connections go to ground?  If that's the case, why must the 'audio lo' connections be shielded if it's going to ground anyway?
 Thanks for your help!
 Dan Ginty
		n801bh(at)NetZero.com Guest
				 Posted: Tue Mar 25, 2008 3:54 pm    Post subject: KX-155 Audio Out |
				I got tripped up on that term when I was wiring my experimental too. I have wired alot of car radios and other stuff growing up so the  Hi/ Lo thing seemed strange. Someone on this list straightened me out. The HI is really the hot wire or feed, the Low is just the ground. Why they don't call it that is beyond me..
 Ben Haas
 N801BH
 www.haaspowerair.com
 -- "txpilot" <djg7(at)comcast.net> wrote:
 --> AeroElectric-List message posted by: "txpilot" <djg7(at)comcast.net>
 Dan Ginty
 http://forums.matronics.com/========================================================================bsp;           - ========================;        - List Contribution Websp;                       &nb=====================================================
 _____________________________________________________________
 Click here to find single Christians that want to meet you today.
		nuckolls.bob(at)cox.net Guest
				 Posted: Wed Mar 26, 2008 3:16 am    Post subject: KX-155 Audio Out |
				At 11:49 PM 3/25/2008 +0000, you wrote:
  	  | Quote: | 	 		  I got tripped up on that term when I was wiring my experimental too. I
 Ben Haas
 N801BH
 'hi' and 'lo'.
 Dan Ginty
     Not all "LO" sides of signals paths are necessarily grounded.
     I wasn't 'in the business' when the vernacular was adopted
     and in any case, whoever conceived it probably used a reasonable
     thought process. When one needs to identify power or signal
     pathways and their functionality, a common vernacular is
     seldom shared between disciplines. The electricians who wired
     your house called them "line", "neutral" and "ground". In the
     DC power world they might favor (+) and (-). In the AC signal
     world the plus minus thing doesn't fit but there's still a need
     to differentiate between the two wires for the purposes of
     phasing. Hence the HI and LO thing. It's quite common for
     the LO side of a path to get to ground somewhere in the system
     but be totally floating in the far reaches of the wiring to
     various components . . . it's that control-your-ground-loops
     thing.
     It can be frustrating but those are the cards that are
     dealt to us. Without seeing the internal schematic for the
     black boxes your trying to tie together, one cannot deduce
     the rationale for shielding a LO side wire. I would guess
     that it's because its simply the ac equivalent of a minus-side
     in a DC circuit; intended to denote phasing and not
     necessarily "ground".
     I've had a few notes from readers over the years chiding
     me for my "follow the instructions" recommendations for
     answering questions on shield grounds. "Surely", they say,
     "there must be some common rules of physics that can/should
     guide us in all cases."  The vernacular adopted by the
     manufacturer's installation data and the designer's goals
     for architecture are not necessarily common so the ultimate
     map to Nirvana is the schematic. If a wire or shield is
     shown to be connected in a particular manner, then it
     matters not what it's called or how the shield or wire is
     used. Schematics are the universal language in electronics
     even if the symbols are sometimes a bit funny looking.
