iworonko(at)cox.net Guest
Posted: Sun Mar 23, 2008 4:16 pm Post subject: first flight |
Hi Gang,
after two years of rebuilding and a wide body and a nose gear conversion mod, N58EW took to the air today. It flew nicely but since I have not flown a Kitfox or the like before I see that the light controls will get some getting use to. The little black ball looked like I was playing PinBall with it.
However , I did have one serious issue that I need to resolve before further flights. When I reduce power to about 4500 RPM the engine starts shaking badly and it continues to shake down to about 3500 RPM. Below and above that range it runs fine. On the ground it seems to run fine. During mag check, one side drops more just a little more then the other and shakes a bit.
Oh yes, the engine is a 912UL with a IFA Ivo.
any ideas?
Eric N58EW speedster
kitfoxpilot(at)msn.com Guest
Posted: Sun Mar 23, 2008 4:40 pm Post subject: first flight |
Did you make sure both carbs were sync'ed, I would start with that.
Ray
From: iworonko(at)cox.netTo: kitfox-list(at)matronics.comSubject: first flightDate: Sun, 23 Mar 2008 19:12:46 -0500
Hi Gang,
Posted: Sun Mar 23, 2008 5:51 pm Post subject: first flight |
Yes, the carbs were synched at idle, dont remember checking them in 3500-4500 RPM range
Eric
pulsair(at)mindspring.com Guest
Posted: Sun Mar 23, 2008 8:12 pm Post subject: first flight |
Eric,
Did you follow the service bulletin from Skystar to shorten the isolator spacers on the engine mounts? Jeff Classic IV
Posted: Mon Mar 24, 2008 6:24 pm Post subject: first flight |
Jeff,
I couldn't find anything about shortening isolators on Skystars list of SB's.
Do you have a service bulletin number or a copy of it?
Eric
Posted: Tue Mar 25, 2008 1:47 pm Post subject: first flight |
Eric,
It is Service Bulletin 54A. The e-mail is below. Though it was intended for the 912ULS the bulletin recommends it for all 912's. Mine did the same thing yours is doing until I shortened the spaces. Now I only have a harmonic vibration around 3,000 - 3,100 Rpm which I ignore. You may also want to check the torque. Jeff
www.kitfoxaircraft.com/Service%20Bulletins.htm - 85k -
