		hdwysong(at)gmail.com Guest
				 Posted: Tue Mar 25, 2008 1:56 am    Post subject: oddball 0.25" fast-on terminal source? |
				Hello all,
 I'm fabricating a new harness for my voltage regulator (Zeftronics
 regulator for a Cessna) and am searching for a supplier of uninsulated
 0.25" female fast-on terminals that have a small tab sticking out of
 the 'back' that will lock them inside the plastic backshell.  I've
 checked the Mouser, Newark, B&C, Waytek, and Allied catalogs without
 luck.  However, perhaps I'm not using the correct keyword to find
 these oddball terminals in their search engines.  Perhaps an autoparts
 store would carry them (the original Cessna regulator was a Ford part,
 I believe)?
 Thanks for any suggestions you folks can provide.
 D
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		nuckolls.bob(at)cox.net Guest
				 Posted: Tue Mar 25, 2008 3:54 am    Post subject: oddball 0.25" fast-on terminal source? |
				At 03:50 AM 3/25/2008 -0600, you wrote:
 Hello all,
 I believe)?
    I've never found these as loose fabrication or repair
    parts . . . but that doesn't mean somebody doesn't have
    them.  Most builders use individual fast-on terminals
    and ditch the housing. You can buy the housing with
    terminals installed and short pig-tails at some care
    parts stores. I think I've seen them in the red "Help"
    line of blister-packed, peg-board products.
    I can get you a part number for a reel of 5,000! B&C
    used to have some that were used with the housing that
    fits the connector on the back of an alternator. These
    were bare-brass (un-plated) parts. They might work with
    your regulator tabs connector housing. I'd go with the
    loose PIDG fast-on terminals and ditch the housing.
         ( . . .  a long habit of not thinking   )
         ( appearance of being right . . .       )
         (                  -Thomas Paine 1776-  )
		rdunhamtn(at)hotmail.com Guest
				 Posted: Tue Mar 25, 2008 6:38 am    Post subject: oddball 0.25" fast-on terminal source? |
				"uninsulated 0.25" female fast-on terminals that have a small tab sticking out of the 'back' that will lock them inside the plastic backshell"
 I have bought just such a part for the voltage regulator connector on my plane from NAPA aircraft and auto parts store.
 Rodney in Tennessee
 In a rush? Get real-time answers with Windows Live Messenger.  [quote][b]
		klehman(at)albedo.net Guest
				 Posted: Tue Mar 25, 2008 6:42 am    Post subject: oddball 0.25" fast-on terminal source? |
				If you really want them I believe I have purchased these, tin plated, in
 small quantity, cut from a reel, from digi-key however they are open
 barrel crimps (cheap automotive) onto the wire. There were at least two
 sizes listed depending on wire gauge. You want the small for tefzel or
 just clip the fingers. Like Bob, I prefer to shove individual PIDG
 connectors into the housing or ditch the housing. I will use the open
 barrel crimps on small awg 22 and smaller if I must, but I don't
 consider them suitable for 18 awg or larger unless soldered and that has
 other issues associated.
 Ken
 Robert L. Nuckolls, III wrote:
  <nuckolls.bob(at)cox.net>
 > Hello all,
 > I believe)?
		hooverra(at)verizon.net Guest
				 Posted: Tue Mar 25, 2008 8:02 pm    Post subject: oddball 0.25" fast-on terminal source? |
				At 06:48 PM 3/25/2008 -0500, you wrote:
 D,
          I had the same issue and bought a roll of AMP tin plated for 18-22
 AWG wire.
 DigiKey P/N A27933CT-ND
 AMP P/N 60295-2
 If these will help send me your address off list and I will mail you a few.
 I bought 100 and needed 3   I just couldn't think of butt splices on the
 Alternator wires.
    Why butt splice? You can do a very compact, robust solder
    splice. See:
 http://aeroelectric.com/articles/Tech_Tips/Solder_Lap_Splicing/Solder_Lap_Splices.html
