andrewbutler(at)ireland.c Guest
Posted: Wed Mar 26, 2008 8:41 am Post subject: Aux power and the battery |
All, I have two general queries that I would like some help on.
1. I have purchased an AC to 12V 5A DC power supply. I would like to use this as an ad-hoc power for install and testing of components through the build. I was thinking of attaching a standard male cigaratte lighter plug to the leads and then use a female recepticle to receive and power the bus. What issues do I need to consider? What will happen if I do this while the battery (an Odyssey PC680) is left attached to the system?
2. I have purchased a two stage charger. Is it kohser to charge the battery through the same female cigaratte power port?
Thanks for your help.
Andrew Butler.
RV71700 - Finishing kit.
Galway, Ireland.
schaefer(at)rts-services. Guest
Posted: Wed Mar 26, 2008 4:35 pm Post subject: Aux power and the battery |
Make sure you have the right polarity.
If the power supply does not handle short circuits (internal current limit and shutdown) you might want to fuse it.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Andrew Butler
Sent: Wednesday, March 26, 2008 11:39 AM
Subject: Aux power and the battery
Andrew Butler.
Galway, Ireland.
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
nuckolls.bob(at)cox.net Guest
Posted: Wed Mar 26, 2008 5:23 pm Post subject: Aux power and the battery |
At 04:38 PM 3/26/2008 +0000, you wrote:
| Quote: | All, I have two general queries that I would like some help on.
12 volts is a bit too low to be run in parallel with
a battery. Generally speaking, 12v power supplies are
crafted for energizing electronics. Since 12v batteries
in vehicles need 13.8 minimum (14.2 better) to co-exist
with a power source, the supply you have could be used for
limited testing as a stand-alone source of power.
| Quote: | 2. I have purchased a two stage charger. Is it kohser to charge the
If it's an automotive "smart charger", what is it's
rated capacity for charging? The BEST way to power your
airplane from the AC mains is to acquire some form of
smart charger. Exemplar devices can be viewed in this
.pdf catalog from Schumacher.
http://www.schumacherproducts.com/assets/pdf/sec_catalog.pdf
I have a couple of Schumacher products, one of which
is good for 25A in the recharge mode. I'll need to do
some tests with it but my thinking is that devices like
these could be permanently connected across your ship's
battery and plugged into the wall. Their microprocessor
smarts should react to keep the battery charged irrespective
of how much "stuff" you test.
This should work even large loads and relatively
small smart chargers. Of course the battery will have
to make up the difference between what say a 2A
charger will put out and a 10A test load. But as
soon as you shut things off, the battery charger
can be trusted to do its thing and bring the battery
back up to 100%.
If you'd like to have a power supply that emulates
"real" vehicular power, watch for 13.8 volt devices
sold to power mobile electronics in the house. I used
to sell the Samlex 1223 and a kit to make it emulate
an alternator. You could plug it into wall, hook it
to the alternator's b-lead and have it respond to
the cockpit alternator control switch. Sitting in
the left seat, everything on the panel worked as if
you had an engine running with a 23A alternator on
it. See:
http://tinyurl.com/2zdt3u
I've always recommended that builders not buy a new
battery until the airplane was ready to fly. During
construction phases, a lawn tractor battery and a
plug-in-the-wall power supply would let you get everything
running in the airplane without abusing a brand
new flight-battery. A smart charger connected
across the battery is a reasonable substitute for a
high-quality power supply.
( -Thomas Paine 1776- )
klehman(at)albedo.net Guest
Posted: Wed Mar 26, 2008 5:24 pm Post subject: Aux power and the battery |
Sure if it is on a battery bus. Maybe not a good idea if you have to
leave a battery contactor energised.
Ken
Andrew Butler.
Galway, Ireland.
Posted: Wed Mar 26, 2008 5:33 pm Post subject: Aux power and the battery |
At 07:30 PM 3/26/2008 -0500, you wrote:
| Quote: | Make sure you have the right polarity.
Good points!
jpiavis(at)microsoft.com Guest
Posted: Fri Mar 28, 2008 9:54 am Post subject: Aux power and the battery |
Along the lines of the current thread, what is the best way to connect the power supply/ charger? Can a 20A charger be connected via the b-lead to simulate alternator current to the system, or should the charger always be connected across the battery. Same for a dedicated power supply? I’m also looking for a good power supply while I work through the avionics configuration and familiarization of the systems.
Jim
RV-7 Getting Close
Posted: Fri Mar 28, 2008 12:22 pm Post subject: Aux power and the battery |
At 10:49 AM 3/28/2008 -0700, you wrote:
| Quote: | Along the lines of the current thread, what is the best way to connect the
connected across the battery. Same for a dedicated power supply? I m also
A "power supply" is generally clean and stable enough
to be stand alone energy source for running things in
your airplane or on the bench.
A "battery charger" may not . . . and the best way to
use a charger is to connect it permanently across the
battery and then use the battery to run ship's systems.
Any of the power supply products rated for an output
voltage of "13.8" will be a stand-alone product designed
to run loads up to and including it's rated output
current. Do a Goggle search on
13.8 power supply
and you get a wad of hits. I'd recommend something
on the order of 20A or better capability like a Samlex
1223 . . . but there are many serviceable products.
See:
http://www.nextag.com/13.8vdc-power-supply/search-html
http://www.radiodan.com/misc/samlex1223.htm
Speedy11(at)aol.com Guest
Posted: Sun Mar 30, 2008 6:20 am Post subject: Aux power and the battery |
Bob,
A good thought, but I found that I needed the actual battery for making brackets and fitting into the airframe. There's nothing like having the actual battery when fitting and running wires.
Stan Sutterfield
| Quote: | I've always recommended that builders not buy a new
new flight-battery. |
Create a Home Theater Like the Pros. Watch the video on AOL Home.
Posted: Sun Mar 30, 2008 7:38 am Post subject: Aux power and the battery |
At 10:15 AM 3/30/2008 -0400, you wrote:
| Quote: | Bob,
Stan Sutterfield
new flight-battery.
Sure, but what's wrong with making that the very
last task you complete? Battery leads can be fabricated
extra long and fitted with temporary terminals to
mate with your shop battery. Space can be allocated
for installation of the flight-battery's attach
hardware.
The long leads could even be long enough to
reach outside the airplane so that the test
battery and supporting charger can be on
a cart or stand outside the airframe.
Some folks consider last task before first flight
to be a wash and wax job, why not make it a
battery installation instead?
Posted: Mon Mar 31, 2008 6:07 am Post subject: Aux power and the battery |
Well, as I mentioned, a good thought, but, for me, that idea does not work. The battery size is unique and it in enclosed in a steel case which needed to be mounted to support structure. At first, I bought only the battery steel case and used it to fabricate brackets and do fitting. That worked fine for awhile. But, as I needed to make hold down brackets and finalize wiring and attach shunts and HE devices, I found having the actual battery beneficial.
I'm sure that with your years of experience, you know how long to make certain wires and can visualize the entire setup. But, with my limited experience, I need the actual battery to see where everything fits and to make sure I get wire lengths right and don't cause interference problems that I have to later solve.
I am not using the battery to power anything. I recharge it periodically to keep it full up and use my Samlex (sp?) power supply to test circuits and power avionics.
Stan Sutterfield
| Quote: | >Bob,
| Quote: | A good thought, but I found that I needed the actual battery for making
Stan Sutterfield
new flight-battery.
hardware.
battery installation instead? |
