Fuel Tank Nutplates
JAPhillipsGA(at)aol.com
PostPosted: Fri Mar 28, 2008 7:25 pm    Post subject: Fuel Tank Nutplates Reply with quote
Fellow RV Builders, I'm about to remove my wings for storage until painting, but before I put them up I want to rivet in the nutplates that hold the root farings on. Should these holes at the edge of the tanks be dimpled or countersunk ? Seem like they are pretty close to the Proseal and I'd hate to make a leak. What does everybody else do ? Thanks, Bill of Georgia
Create a Home Theater Like the Pros. Watch the video on AOL Home.
(http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom00030000000001) [quote][b]
Carl
PostPosted: Sat Mar 29, 2008 5:25 am    Post subject: Fuel Tank Nutplates Reply with quote
Just carefully squeeze the rivets in the nutplates and you shouldn’t have a problem. CJ
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of JAPhillipsGA(at)aol.com
Sent: Friday, March 28, 2008 11:22 PM
To: rv8-list(at)matronics.com
Subject: Fuel Tank Nutplates
Carl Bell
Building N947CB
RV 7A
planecrazzy(at)wildblue.n
PostPosted: Sat Mar 29, 2008 5:13 pm    Post subject: Fuel Tank Nutplates Reply with quote
Hi Carl,
Use #6 screws, 3/8 dia 3/32 dimple die, and #6 dimple die with flat on sides
to clear tank edges. Pro seal doesn't harden completely ,so the dimpling shouldn't
cause leaking.
ray
On Sat, Mar 29, 2008 at 9:23 AM, Carl Bell <carlbell(at)gforcecable.com (carlbell(at)gforcecable.com)> wrote:
Just carefully squeeze the rivets in the nutplates and you shouldn't have a problem. CJ
From: owner-rv8-list-server(at)matronics.com (owner-rv8-list-server(at)matronics.com) [mailto:owner-rv8-list-server(at)matronics.com (owner-rv8-list-server(at)matronics.com)] On Behalf Of JAPhillipsGA(at)aol.com (JAPhillipsGA(at)aol.com)
To: rv8-list(at)matronics.com (rv8-list(at)matronics.com)
PostPosted: Sun Mar 30, 2008 10:02 am    Post subject: Fuel Tank Nutplates Reply with quote
Ray, what does "flat on sides" mean? Thanks, Bill
PostPosted: Sun Mar 30, 2008 12:30 pm    Post subject: Fuel Tank Nutplates Reply with quote
Bill,
The female die will be 1/2" in dia., grind a flat to clear the edge of the tank.
Hope that helps.
ray
On Sun, Mar 30, 2008 at 2:59 PM, <JAPhillipsGA(at)aol.com (JAPhillipsGA(at)aol.com)> wrote:
[quote]Ray, what does "flat on sides" mean? Thanks, Bill
