Chelton display
dlm46007(at)cox.net
PostPosted: Sun Mar 30, 2008 1:03 pm    Post subject: Chelton display Reply with quote
I started the new IO540 this AM; I have the output of an EIS6000 going serially to the Cheltons and a Grand Rapids Sport. The Sport was logging the data. The engine ran fine after switching a couple of wires on the SLICKSTART. The data as displayed on the computer shows normal EGTs for idle of abut 900F. The Chelton engine display, however shows negative numbers in the 2 digits while operating and negative low three digits when shutdown. Any ideas? [quote][b]
Tim Olson
PostPosted: Sun Mar 30, 2008 1:50 pm    Post subject: Chelton display Reply with quote
You have some scale factor/offset/field setup to do
on the EIS to provide the values at the right scale.
Also, make sure your GRT actually has the Chelton version
of software running on it. GRT makes more than one software
rev for various integrations...you want the Chelton version.
