ogdenk
Posted: Mon Mar 31, 2008 5:36 am Post subject: HS Attachment Bars |
All,
I just started my tailcone, and when I went to drill the HS-1011C horizontal stabilizer attachment bars, I found that the pre-punched holes were conical in shape. That is, one side of the hole is a bit larger than the other, larger than the #30 bit used to match drill. I understand that this is probably the result of punching a hole through such a thick piece, but it seems like this would leave a lot of slop for the rivet. Just wanted to check whether others noticed this as well? Should the larger side of the hole be put against the bulkhead?
Kent Ogden
#40710 (real) slow build
johngoodman
Posted: Mon Mar 31, 2008 6:04 am Post subject: Re: HS Attachment Bars |
Are you talking about the F 1011C on page 10-3?
If the hole is too big you might want to contact Vans for a replacement.
John
_________________ #40572 Phase One complete in 2011 |
ogdenk
Posted: Mon Mar 31, 2008 7:18 am Post subject: HS Attachment Bars |
Yes, these parts first appear on page 10-3. These are the heavy tapered bars that will attach the HS to the tailcone. This would be a bad place for failure to occur.
I will give Vans a call to see what they say.
Kent
| Quote: | >> "johngoodman" <johngoodman(at)earthlink.net> 3/31/2008 10:04 AM >>>
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net>
John
#40572 QB Fuselage, wings finished
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=173867#173867
_-============================================================
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-= --> http://www.matronics.com/Navigator?RV10-List
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-= --> http://forums.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
ogdenk
Posted: Mon Mar 31, 2008 7:22 am Post subject: HS Attachment Bars |
Just talked to Vans, they said it's normal and the shank of the rivet will expand to fill the hole.
Kent
John
N711JG reserved
