		Dana
				 Posted: Wed Apr 02, 2008 6:01 pm    Post subject: Fuel pump mounting |
				I was wondering where people mount their fuel pump.  The Ultrastar manual
 says to mount it between the front engine mounting bolts, which seems a
 little awkward (and would require a rather long pulse tube).  The Cuyuna
 manual says NOT to mount it directly to the engine (presumably to protect
 it from vibration), and to mount it above the pulse line connection to the
 crankcase (to avoid fuel collecting in the pump and/or pulse line).
 On mine, the pump was mounted (by a previous owner) to a plate bolted to
 the side of the engine, and the pulse line runs (slightly) downhill to the
 pump.  It's not the Rotax pump with the weep hole, though I suppose I could
 drill one.  Double whammy I guess, but it works fine (so far), and I've
 seen no evidence of fuel or oil collecting there.  Still, I'm making some
 changes tomorrow (adding a plunger primer and getting rid of the squeeze
 bulb), so I'm wondering if I should move the pump while I'm at it, and
 wondering where others have mounted it (and any associated problems).
 -Dana
   Lie ? Me ? Never!  No, no, no, the truth is far too much fun!
		aoldman(at)xtra.co.nz Guest
				 Posted: Thu Apr 03, 2008 12:04 am    Post subject: Fuel pump mounting |
				Well just my opinion but I would not remove rthe squeeze bulb. I have always
 made a point of locating the squeeze bulb where it can be reached .It is
 after all a fuel pump that is neither mechanical nor electric .In the last
 400 hrs of flying there has been at least one time that it has saved me a
 long walk home,If you can reach it ,it is another string to your bow if
 needed. There are some rules to pumping them .THEY WORK BETTER WHEN HELD
 VERTICAL.
 Tony
      Downunder
		Dana
				 Posted: Thu Apr 03, 2008 2:51 am    Post subject: Fuel pump mounting |
				At 04:01 AM 4/3/2008, Tony Oldman wrote:
  	  | Quote: | 	 		  Well just my opinion but I would not remove rthe squeeze bulb. I have
 always made a point of locating the squeeze bulb where it can be reached
 .It is after all a fuel pump that is neither mechanical nor electric .In
 the last 400 hrs of flying there has been at least one time that it has
 saved me a long walk home...
 I thought of that, but OTOH it's another point for failure... and a bad
 bulb (a brand new one from ACS for that matter) nearly CAUSED me a long
 walk home.  As squeeze bulb failures seem to be more common than pulse pump
 failures, removal of the bulb should be a safety improvement.
 -Dana
   The family that shoots together..... shouldn't be messed with!
		ElleryWeld(at)aol.com Guest
				 Posted: Thu Apr 03, 2008 3:39 am    Post subject: Fuel pump mounting |
				another opinion of the squeeze bulb  they are  very poor quality and I have heard many stories and had the one fail on my  first plane Great rig for in a Boat , nothing I would install in anything I  fly  if I want redundant I would install mechanical or Vacum pump and  Electric pump for back up I don't want to have to give up a hand  that I  might need for flying the plane to give my plane in Flight CPR
  Ellery in Maine
   In a message dated 4/3/2008 3:05:34 A.M. Eastern Standard Time,  aoldman(at)xtra.co.nz writes:
  [quote]-->    Kolb-List message posted by: "Tony Oldman"    <aoldman(at)xtra.co.nz>
 VERTICAL.
 Tony
         Downunder
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Thu Apr 03, 2008 6:52 am    Post subject: Re: Fuel pump mounting |
				My Mikunni fuel pump is mounted on one of the square tubes of the engine support just above the impulse nipple.
 There was already a hole there so thats where I put it.
 I had also considered an aircraft dash plunger primer, since I have one sitting around, but decided against it since it is yet another potential failure point in the fuel system.(obstruction & potential air leak)
 If you must have one, it is much better than a squeeze bulb at least.
 If you are using it to squirt some extra fuel in the carb for starting it would be better to use the carb nipple to a seperate fuel line to squirt extra fuel.
 If it is to prime your fuel line then perhaps there is already an air leak that is allowing fuel to drain back into your tank?
 Right now my fuel line run is about 24" with a fuel filter bowl type at the low point and a pump at the hight point in the circuit and use tygon (expensive) fuel tubing. I think my fuel system is optimized at this point.
 With my fuel line arrangement the lines stay primed with fuel even when I leave it sit for a couple months.
 My start procedure is to pull choke with ignition OFF and pull start 2 times then Ign ON and one or two pulls and its off and running.
 On another note, last evening I got the 2 new CHT guages hooked up to the Instrument properly...still need to test to make sure my readings are good now.
 Then I'll play with main jets to get the temps in line.
 I have some bigger and smaller main jets on the way #270, #280, #290, #300 & #310 and a different needle 6DH7 in case I feel like experimenting. Also have a K&N air filter on the way.
 Good work on that rudder pedal mod, I'll have to keep that one in mind for future reference.
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
				 Posted: Thu Apr 03, 2008 3:47 pm    Post subject: Fuel pump mounting |
				I have the squeeze bulb installed with a bypass incase it  fails {this I believe to be the recomended instalation for these}
  Tony
     Downunder
  [quote]   ---
		Dana
				 Posted: Thu Apr 03, 2008 5:34 pm    Post subject: Fuel pump mounting |
				At 07:44 PM 4/3/2008, Tony Oldman wrote:
   	  | Quote: | 	 		  | I have the squeeze bulb installed with a bypass incase it fails {this I believe to be the recomended instalation for these} |
  A bypass protects against a blocked bulb, but not against a leaking bulb.
  -Dana
   War doesn't determine who's right but who's left.    [quote][b]
				 Posted: Thu Apr 03, 2008 6:08 pm    Post subject: Fuel pump mounting |
				ok now what are you going to do when the squeeze bulb  falls apart  while trying to give your engine in flight CPR ? your bypass  line wont be worth much then ha,  then if you happen to have a spare one  aboard scramble around the cockpit  for it,  meanwhile   (Don't forget to keep flying the plane ) and that one falls apart   trying to install it in flight,   no thanks there just not good enough  quality for me  but good luck using them  if you  must
  Ellery
   In a message dated 4/3/2008 6:48:27 P.M. Eastern Standard Time,  aoldman(at)xtra.co.nz writes:
  [quote]   I have the squeeze bulb installed with a bypass incase it    fails {this I believe to be the recomended instalation for these}
    Tony
       Downunder
    [quote]     ---
				 Posted: Fri Apr 04, 2008 12:40 am    Post subject: Fuel pump mounting |
				Very true ,so I guess like many things in life, sometimes it will work for  you and sometimes it will work against you.
  Tony
       Downunder
  [quote]   From:    Dana    Hague (d-m-hague(at)comcast.net)
    Sent: Friday, April 04, 2008 2:22  PM
    Subject: Re: Fuel pump    mounting
 -Dana
  War doesn't determine who's right but who's left.  	  | Quote: |
  | 	  [b]
