		AZFlyer
				 Posted: Tue Apr 01, 2008 10:19 am    Post subject: 601XL with Wheel Pants |
				Builders,
 The photo assembly of the front fork on the 601 XL with wheel pants (new version) states "radius the front edge of wheel fork".
 Can somebody explain to me the purpose of this radius.  It doesn't look like the wheel pant touches there...so?
 Mike
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember,  "the second mouse gets the cheese"! |
				 Posted: Tue Apr 01, 2008 11:42 am    Post subject: 601XL with Wheel Pants |
				Hi Mike,
 Three things come to mind.  The radius edge would certainly cut the air
 better if you didn't have the wheel pant on.  The radius would reduce
 the stress at bending.
 The radius would not cut into the fiberglass on the wheel pant if
 contact were made at that point.  All that aside, the fork would
 definitely look better with a nice radius
 on the large exposed edges.
 AZFlyer wrote:
  Builders,
  Mike
  Mike Miller (at) millrml(at)aol.com
  601 XL, 3300, Dynon
		Dave Nixon
				 Posted: Wed Apr 02, 2008 12:05 pm    Post subject: Re: 601XL with Wheel Pants |
				The radius along with inverting the two bolts in front are required for the 'new' streamlined wheel pant to fit properly.  the radius is not much (1/4" ?) but, in my case, found it necessary to get a proper fit.
 N107R CH601XL with Jabiru 3300 leapt into the air today for its maiden voyage.  Some bugs.  Worked them out this afternoon and tested via High speed taxi. Tomorrow it is back into the air.
 One issue that I have, the front seal strip for the canopy at the forward fuselage cowl does not want to stay glued.  I have used 3-M Trim adhesive. No go. Hot glue gun. No go. RTV no go. This afternoon I tried a 2 part epoxy. Won't know until tomorrow AM.  Apparently, my forward edge of the canopy just touches the cowl causing the lip of the seal to roll back or under. However you want to look at it. I shortened the Air Shocks 3/8" to keep the canopy from extending farther.  It helped but didn't solve the problem entirely.  Any Suggestions?
 Dave Nixon
 Flying N107R
		jmaynard
  Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
				 Posted: Wed Apr 02, 2008 12:25 pm    Post subject: 601XL with Wheel Pants |
				On Wed, Apr 02, 2008 at 01:05:23PM -0700, Dave Nixon wrote:
  	  | Quote: | 	 		   N107R CH601XL with Jabiru 3300 leapt into the air today for its maiden
 Woohoo!
 Jay Maynard, K5ZC                   http://www.conmicro.com
 http://jmaynard.livejournal.com      http://www.tronguy.net
 Fairmont, MN (FRM)                        (Yes, that's me!)
 AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
  _________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
				 Posted: Wed Apr 02, 2008 1:41 pm    Post subject: 601XL with Wheel Pants |
				 	  | Quote: | 	 		   I shortened the Air Shocks 3/8" to keep the canopy from extending farther.
 I'm going to have to shorten mine about the same amount or move the brackets
 back. How did you shorten the air shocks? Extend the threads with a die and
 cut off the extra? Are the threaded shafts very hard? I also worry about
 damaging the smooth surface when clamping the shafts.
 -- Craig
		amyvega2005(at)earthlink. Guest
				 Posted: Wed Apr 02, 2008 9:34 pm    Post subject: 601XL with Wheel Pants |
				clean with some cleaner approved by Zentih, then use Gorilla glue.  mine will not come off.
 JUan
		bobefx(at)yahoo.com Guest
				 Posted: Thu Apr 03, 2008 10:05 am    Post subject: 601XL with Wheel Pants |
				Craig,
  My rear mount for the shocks was forward by 20mm and I had the same problem. Check the location. I moved mine back 20mm. I got new mounts so I could use the same holes in the fus. Roger sent them right out.
  Bob
				 Posted: Thu Apr 03, 2008 2:04 pm    Post subject: 601XL with Wheel Pants |
				Thanks, I already have undrilled replacement brackets. But using them in a new, more rearward position will leave some existing holes in the top longerons empty and require some new holes. If I can use the existing bracket in its original position by shortening the gas spring I’ll have a cleaner fix.
 -- Craig
 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bob Sturgis
  Sent: Thursday, April 03, 2008 11:37 AM
  Subject: Re: Re: 601XL with Wheel Pants
 Craig,
 Bob
				 Posted: Thu Apr 03, 2008 2:47 pm    Post subject: 601XL with Wheel Pants |
				That's why I got new rear mounts, and used the existing holes in the longerons. Best fix. Shortening the gas springs can cause other problems, not a good idea.
  My new rear mounts were longer then the originals so I could use the same holes.
				 Posted: Thu Apr 03, 2008 3:04 pm    Post subject: 601XL with Wheel Pants |
				My old and new brackets are the same length. How long are the replacement brackets you received from Roger?
 -- Craig
  Sent: Thursday, April 03, 2008 4:42 PM
