		a58r(at)verizon.net Guest
				 Posted: Sat Apr 05, 2008 12:05 pm    Post subject: FAA advice |
				I cobbed this off FLY-UL :
 This message was posted to another group (Sport_aircraft)
  Re: ex-planes?
  OK, folks, I'm new to the group and have been "lurking" in the
  background reading this (sometimes painful) thread on certificating
  existing or new light-sport aircraft. Now I think it's time to jump in
  and clarify some of the confusion.
  I am an FAA DAR who certificates light-sport and amateur-built
  aircraft. I also provide FAA-accepted 16-hour ELSA repairman courses--
  more that 40 courses all over the eastern half of the U.S. I've also
  been building experimental airplanes for 40 years.
  So, I deal with these questions every day. Here are the facts.
  There are only five conceivable ways to certificate a light-sport
  aircraft: 1) standard category, 2) special light-sport aircraft
  (SLSA), 3) experimental light-sport aircraft (ELSA), 4) experimental
  amateur-built (EAB) aircraft, and 5) experimental exhibition aircraft.
  Although these are all conceivable ways, some of them are not
  practical. Let's talk about each one.
  STANDARD CATEGORY
  These are the type certificated Cessnas, Pipers, Beech's, etc. Nobody
  is going to certify a light-sport aircraft in standard category because
  it is a multi-million-dollar process to do so and would result in an
  aircraft that nobody could afford. 'Nuff said.
  SPECIAL LIGHT SPORT AIRCRAFT (SLSA)
  These are the 70-odd ready-to-fly new aircraft designs that have come
  on the scene in the last 3 years. Although not the multi-million-
  dollar process that would be required for type certification, SLSA
  manufacturers must create aircraft designs and implement inhouse
  procedures to meet ASTM light-sport aircraft standards. With each such
  aircraft manufactured, they must certify that they have met all
  applicable standards.
  EXPERIMENTAL LIGHT SPORT (ELSA)
  In the words of FAR 21.191(i), there are three kinds of ELSAs:
  1. Existing "ultralight-like vehicles" certificated prior to January
  31, 2008 per 21.191(i)(1). Note that the EAA and ASC have gotten
  exemptions to allow the certification deadline to be extended for
  aircraft that were REGISTERED before the deadline. That means that if
  your existing ultralight was not FAA-registered before the deadline, it
  can NEVER be certificated according to this paragraph. It also means
  that manufacturers of ultralights are essentially out of business
  unless they want to get their design certificated as SLSA.
  2. ELSAs built from a SLSA kit per 21.191(i)(2). The manufacturer
  must have gotten SLSA certification on the aircraft prior to offering
  it in kit form. The kit does not have to meet the 51% rule, but the
  manufacturer must certify that the kit meets the ASTM standards and the
  builder must certify that he has completed the kit EXACTLY as the
  manufacturer specifies. There is no registration or certification
  deadline on this type of ELSA.
  3. ELSAs that were converted from SLSA per 21.191(i)(3). Let's say
  a guy buys an SLSA, but wants to do his own annual condition inspection
  after attending a 16-hour ELSA repairman course (such as the ones I
  offer). He can ask the FAA to change his certification from SLSA to
  ELSA. There is no deadline on making such a conversion.
  EXPERIMENTAL AMATEUR-BUILT (EAB)
  In the words of FAR 21.191(g), to qualify for certification as an EAB,
  the major portion must have been "fabricated and assembled by persons
  who undertook the construction project solely for their own education
  or recreation" (note the word "fabricated" in addition to the
  word "assembled).
  In the olden days when I was a pup, before there were EAB kits, we
  simply bought plans and materials, built the entire aircraft, and
  documented the construction process in a builder's log. Also, in those
  days, an FAA inspector (there were no DARs) had to perform an interim
  inspection of any portion of the aircraft that would be "closed out"
  and would not be visible at the final inspection. Because of that,
  there was generally no question that the "major portion" requirement
  was met, even in the case where one individual began the construction
  and then sold the project to another individual.
  However, over the ensuing 20-30 years, kits began to be available.
  First, they were simply raw material kits, but they gradually advanced
  into having more and more of the aircraft fabrication completed by the
  kit manufacturer. So, to assure that the "major portion" requirement
  was being met, the FAA began evaluating kits and approving them as
  meeting the so-called "51% rule." Therefore, if I bought an approved
  51% kit, finished it myself and maintained a construction log, FAA
  inspectors (and DARs, which had come on the scene by then) would accept
  it as meeting the "major portion" requirement. This held true even if
  I bought such a kit from someone else who had done some of the
  fabrication and assembly work, as long as that person was able to
  provide me with the original bill of sale for the kit and a
  construction log for his efforts.
  Of course, then people started abusing the system, by getting other
  people to finish the kits for them. That situation has gotten so bad
  that the FAA is now revamping their entire system for evaluating kits
  and evaluating EABs submitted for certification. Some of the current
  quick-build kits may be disqualified.
  So, how does that affect the ability to certificate an existing
  ultralight as an EAB? I hear guys who have missed the ELSA
  registration deadline say, "I'll just take my ultralight apart and
  reassemble it, take a few pictures, create a construction log, and get
  it certificated as EAB." Unfortunately, that is not legal. First,
  most ultralights do not meet the "major portion" requirement--either
  they were purchased ready to fly or as a kit that was not evaluated by
  the FAA. Second, FAR 191(g) requires that the major portion be
  FABRICATED and assembled by the applicant-- just reassembling it would
  not qualify.
  I'm not saying that no ultralight is ever going to be certificated as
  an EAB, because DARs and FAA inspectors vary in strictness by which
  they interpret the requirements. I know if I tried to vary from the
  requirements, I would be in trouble with my FAA supervisor!
  EXPERIMENTAL EXHIBITION AIRCRAFT
  This certification category is for aircraft that are intended to be
  used only for "exhibition" purposes, such as performing in air shows,
  performing in aerobatic competitions, competing in air races, display a
  certain kinds of aviation events, etc.
  When certificating an aircraft as experimental exhibition, the FAA
  issues "operating limitations" that severely limit where and when the
  aircraft can be flown. Generally that means the aircraft may be flown
  only 1) while performing or competing at an aviation event, 2) to
  travel to and from such an event, and 3) to practice for such an event.
  Experimental exhibition is "the bottom of the barrel"--the least
  desirable way to certificate an aircraft because of the restrictions it
  imposes. Do people sometimes ignore those restrictions?--sure, but if
  they are caught, they are in trouble.
  CONCLUSIONS
  1. If you have missed the January 31, 2008 ELSA registration deadline,
  a. You MIGHT be able to get it certificated as an EAB, but it is
  not likely.
  b. You can probably get it certificated as experimental exhibition,
  but that would be very restrictive as to where and when you could fly.
  c. Otherwise, you have an expensive lawn ornament on your hands.
  Thus, if you are tempted to buy an existing ultralight off eBay or
  somewhere else, it is critical to determine that it has already been
  certificated as an ELSA (unless of course it meets FAA 103, which very
  few ultralights do).
  2. Any ELSA manufactured, registered, and certificated after January
  31, 2008 must be based on an SLSA kit, as explained above.
  If you have other questions about this, feel free to post them and I'll
  do my best to answer them. Also, I invite you to visit my website
  listed below--it has lots of good information on this topic and much
  more.
  Hope this clarifies some of the confusion!
  regards,
 Bob N.    FireFly 070 Old Kolb
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sat Apr 05, 2008 1:05 pm    Post subject: FAA advice |
				BN, enlightening, BUT, there are us shady characters who will always find a loophole ora way around things.  The first and best approach is the "buy a data plate and install aircraft"
 approach.  I know this works fine with old pick up trucks too
 I supplied an old timer, through a friend, with the paperwork to create an E-2 cub.  Unfortunately
 the guy turned out to be only a well-intentioned dreamer and must be in boot hill by now.
 I visited with the friend (now near 90) and saw the incredible collection he had hanging
 from the rafters in his barn. He well could have built one.
 Anyway we had a nice chat around his woodstove.
 A data plate, airworthiness certificate, and registration papers ARE an airplane.  $$$$$$$
 BB
 On 5, Apr 2008, at 3:59 PM, Bob Noyer wrote:
 [quote]I cobbed this off FLY-UL :
  Re: ex-planes?
  STANDARD CATEGORY
  word "assembled).
  not qualify.
  CONCLUSIONS
  not likely.
  more.
  regards,
  | 	  [b]
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Mon Apr 07, 2008 1:31 pm    Post subject: Re: FAA advice |
				I assume your not mentioning the obvious that is to make the plane comply to part 103 be being within the limitations for weight, fuel etc. by utilizing the Parachute and Float allowances if applicable?
 Part 103 has not gone away, so that is always an option.
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
