		wrice(at)omnicityusa.com Guest
				 Posted: Sun Apr 06, 2008 8:20 am    Post subject: EAB to ELSA |
				Bob:  Is there any process to convert  a EAB to the ELSA in order for the owner/pilot can take the 16 hour course and  be able to inspect is own  plane??                          Thanks  fpr your input.  Bill Rice
  [quote]   To: Kolb-list(at)matronics.com (Kolb-list(at)matronics.com)
    Sent: Saturday, April 05, 2008 3:59    PM
    Subject: FAA advice
 I cobbed this off FLY-UL :
 This message was posted to    another group (Sport_aircraft)
 Re: ex-planes?
 OK,    folks, I'm new to the group and have been "lurking" in the
 background    reading this (sometimes painful) thread on certificating
 existing or new    light-sport aircraft. Now I think it's time to jump in
 and clarify some of    the confusion.
 I am an FAA DAR who certificates light-sport and    amateur-built
 aircraft. I also provide FAA-accepted 16-hour ELSA repairman    courses--
 more that 40 courses all over the eastern half of the U.S. I've    also
 been building experimental airplanes for 40 years.
 So, I deal    with these questions every day. Here are the facts.
 There are only five    conceivable ways to certificate a light-sport
 aircraft: 1) standard    category, 2) special light-sport aircraft
 (SLSA), 3) experimental    light-sport aircraft (ELSA), 4) experimental
 amateur-built (EAB) aircraft,    and 5) experimental exhibition aircraft.
 Although these are all conceivable    ways, some of them are not
 practical. Let's talk about each    one.
 STANDARD CATEGORY
 These are the type certificated Cessnas,    Pipers, Beech's, etc. Nobody
 is going to certify a light-sport aircraft in    standard category because
 it is a multi-million-dollar process to do so and    would result in an
 aircraft that nobody could afford. 'Nuff    said.
 SPECIAL LIGHT SPORT AIRCRAFT (SLSA)
 These are the 70-odd    ready-to-fly new aircraft designs that have come
 on the scene in the last 3    years. Although not the multi-million-
 dollar process that would be    required for type certification, SLSA
 manufacturers must create aircraft    designs and implement inhouse
 procedures to meet ASTM light-sport aircraft    standards. With each such
 aircraft manufactured, they must certify that    they have met all
 applicable standards.
 EXPERIMENTAL LIGHT SPORT    (ELSA)
 In the words of FAR 21.191(i), there are three kinds of    ELSAs:
 1. Existing "ultralight-like vehicles" certificated prior to    January
 31, 2008 per 21.191(i)(1). Note that the EAA and ASC have    gotten
 exemptions to allow the certification deadline to be extended    for
 aircraft that were REGISTERED before the deadline. That means that    if
 your existing ultralight was not FAA-registered before the deadline,    it
 can NEVER be certificated according to this paragraph. It also    means
 that manufacturers of ultralights are essentially out of    business
 unless they want to get their design certificated as    SLSA.
 2. ELSAs built from a SLSA kit per 21.191(i)(2). The    manufacturer
 must have gotten SLSA certification on the aircraft prior to    offering
 it in kit form. The kit does not have to meet the 51% rule, but    the
 manufacturer must certify that the kit meets the ASTM standards and    the
 builder must certify that he has completed the kit EXACTLY as    the
 manufacturer specifies. There is no registration or    certification
 deadline on this type of ELSA.
 3. ELSAs that were    converted from SLSA per 21.191(i)(3). Let's say
 a guy buys an SLSA, but    wants to do his own annual condition inspection
 after attending a 16-hour    ELSA repairman course (such as the ones I
 offer). He can ask the FAA to    change his certification from SLSA to
 ELSA. There is no deadline on making    such a conversion.
 EXPERIMENTAL AMATEUR-BUILT (EAB)
 In the words of    FAR 21.191(g), to qualify for certification as an EAB,
 the major portion    must have been "fabricated and assembled by persons
 who undertook the    construction project solely for their own education
 or recreation" (note    the word "fabricated" in addition to the
 word "assembled).
 In the    olden days when I was a pup, before there were EAB kits, we
 simply bought    plans and materials, built the entire aircraft, and
 documented the    construction process in a builder's log. Also, in those
 days, an FAA    inspector (there were no DARs) had to perform an interim
 inspection of any    portion of the aircraft that would be "closed out"
 and would not be visible    at the final inspection. Because of that,
 there was generally no question    that the "major portion" requirement
 was met, even in the case where one    individual began the construction
 and then sold the project to another    individual.
 However, over the ensuing 20-30 years, kits began to be    available.
 First, they were simply raw material kits, but they gradually    advanced
 into having more and more of the aircraft fabrication completed by    the
 kit manufacturer. So, to assure that the "major portion"    requirement
 was being met, the FAA began evaluating kits and approving them    as
 meeting the so-called "51% rule." Therefore, if I bought an    approved
 51% kit, finished it myself and maintained a construction log,    FAA
 inspectors (and DARs, which had come on the scene by then) would    accept
 it as meeting the "major portion" requirement. This held true even    if
 I bought such a kit from someone else who had done some of    the
 fabrication and assembly work, as long as that person was able    to
 provide me with the original bill of sale for the kit and    a
 construction log for his efforts.
 Of course, then people started    abusing the system, by getting other
 people to finish the kits for them.    That situation has gotten so bad
 that the FAA is now revamping their entire    system for evaluating kits
 and evaluating EABs submitted for certification.    Some of the current
 quick-build kits may be disqualified.
 So, how    does that affect the ability to certificate an existing
 ultralight as an    EAB? I hear guys who have missed the ELSA
 registration deadline say, "I'll    just take my ultralight apart and
 reassemble it, take a few pictures,    create a construction log, and get
 it certificated as EAB." Unfortunately,    that is not legal. First,
 most ultralights do not meet the "major portion"    requirement--either
 they were purchased ready to fly or as a kit that was    not evaluated by
 the FAA. Second, FAR 191(g) requires that the major    portion be
 FABRICATED and assembled by the applicant-- just reassembling it    would
 not qualify.
 I'm not saying that no ultralight is ever going    to be certificated as
 an EAB, because DARs and FAA inspectors vary in    strictness by which
 they interpret the requirements. I know if I tried to    vary from the
 requirements, I would be in trouble with my FAA    supervisor!
 EXPERIMENTAL EXHIBITION AIRCRAFT
 This certification    category is for aircraft that are intended to be
 used only for "exhibition"    purposes, such as performing in air shows,
 performing in aerobatic    competitions, competing in air races, display a
 certain kinds of aviation    events, etc.
 When certificating an aircraft as experimental exhibition,    the FAA
 issues "operating limitations" that severely limit where and when    the
 aircraft can be flown. Generally that means the aircraft may be    flown
 only 1) while performing or competing at an aviation event, 2)    to
 travel to and from such an event, and 3) to practice for such an    event.
 Experimental exhibition is "the bottom of the barrel"--the    least
 desirable way to certificate an aircraft because of the restrictions    it
 imposes. Do people sometimes ignore those restrictions?--sure, but    if
 they are caught, they are in trouble.
 CONCLUSIONS
 1. If you    have missed the January 31, 2008 ELSA registration deadline,
 a. You    MIGHT be able to get it certificated as an EAB, but it is
 not    likely.
 b. You can probably get it certificated as experimental    exhibition,
 but that would be very restrictive as to where and when you    could fly.
 c. Otherwise, you have an expensive lawn ornament on your    hands.
 Thus, if you are tempted to buy an existing ultralight off eBay    or
 somewhere else, it is critical to determine that it has already    been
 certificated as an ELSA (unless of course it meets FAA 103, which    very
 few ultralights do).
 2. Any ELSA manufactured, registered, and    certificated after January
 31, 2008 must be based on an SLSA kit, as    explained above.
 If you have other questions about this, feel free to    post them and I'll
 do my best to answer them. Also, I invite you to visit    my website
 listed below--it has lots of good information on this topic and    much
 more.
 Hope this clarifies some of the    confusion!
 Mike
       regards,
    Bob N.    FireFly 070 Old Kolb
  | 	  [b]
		cristalclear13
  Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
				 Posted: Sun Apr 06, 2008 7:13 pm    Post subject: Re: EAB to ELSA |
				Bill,
 I'm not Bob, but I took Mike Huffman's LS-I repairman course last week.  It's a great course and he's a great teacher.  He talked about this (what you asked) in his class.  Probably NOT what you want to hear, but there is no way to certificate a plane as E-LSA when it has already been certificated as E-AB.
 Mike's web site - http://www.sportaviationspecialties.com/Articles.htm
  _________________ Cristal Waters
Kolb Mark II Twinstar Rotax 503 DCSI  Sept 2007 - sold Sept 2012
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
