lwinger
Posted: Tue Apr 01, 2008 3:08 pm Post subject: Interior painting |
I'll make it simple. I'm polishing the outside of my 601XL, but I'm needing help on the interior paint.
I'm looking for durable, fairly easy to apply and cost effective. Any suggestions?
Thanks.
P.S. I've read the archives, but feel free to point me to a specific previous post. There must be a gem or two in the thousands of posts containing "paint"!
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
psm(at)ATT.NET Guest
Posted: Thu Apr 03, 2008 2:52 am Post subject: Interior painting |
Hi Larry,
I've used self etching primer in a medium gray color directly on the
aluminum. Preparation is just scratching up the aluminum with 100
grit emery cloth and a wipe with a clean rag and some lacquer
thinner. The result is a relatively flat grey color which seems to
be reasonably durable.
For accents, I use a flat black enamel. This turned out to be a
problem when applied directly over the self etching primer. I found
I needed to put a regular primer over the self etching stuff or the
enamel would lift the first coat of paint.
All of these paints are available at an automotive paint store in
rattle cans. Bring your credit card when buying the self etching
primer -- it costs around $15 per rattle can.
Have fun,
Paul
XL fuselage
At 04:08 PM 4/1/2008, you wrote:
| Quote: | I'll make it simple. I'm polishing the outside of my 601XL, but I'm
