Fox5flyer Guest
Posted: Sat Apr 05, 2008 3:52 am Post subject: NSI compression |
Hey folks. Has anyone here done head work on there NSI EA81 N/A? My
engine has been running just fine, but I've been noticing a new
difference in my EGTs Normally they were nearly identical at cruise power, but suddenly they're 150 degrees different. So, I did a normal automotive type compression check which was
reasonably good, but then I did a differential check and it's
appearing that I may have some bad valves. My highest is #4 at 77/80
and weakest one is #3 at 50/80. #2 is 76/80 and #1 is 60/80 . Both of
the weak ones are on the pilot side with air hissing in the exhaust.
I can hear a gurgling in the oil tank on all four, but I don't know
if that is normal or not since they all sound the same and the
starboard cylinders have pretty good compression. I'm fairly
convinced I need to do a valve job, but what I need is specific
teardown/repair instructions, gasket kit, possibly valves, and someone
to do the actual valve job properly.
Anybody like to give their opinion/recommendations on this? Sources
for the above parts would also be appreciated.
If I go local for parts, what engine do I tell them I have?
Deke
S5 NSI EA81 NA
380 hours
NE Michigan
n10pg(at)neo.rr.com Guest
Posted: Sat Apr 05, 2008 5:05 am Post subject: NSI compression |
Hi Deke:
Why don't you give Ron Carr at RAM Performance a shout. He has done my
engine. They are located in Clinton OH, a few miles SW of Akron. Their phone
is (330) 882-6255
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Saturday, 05 April, 2008 07:47
To: Kitfox List
Subject: NSI compression
Deke
S5 NSI EA81 NA
380 hours
NE Michigan
Fox5flyer Guest
Posted: Sat Apr 05, 2008 5:20 am Post subject: NSI compression |
Thanks Peter. I'll do that.
Deke
