		Fox5flyer Guest
				 Posted: Sat Apr 05, 2008 3:52 am    Post subject: NSI compression |
				Hey folks. Has anyone here done head work on there NSI EA81 N/A?  My
 engine has been running just fine, but I've been noticing a  new
 difference in my EGTs Normally they were nearly identical at  cruise power, but suddenly they're 150 degrees different.  So, I did a  normal automotive type compression check which was
 reasonably good, but then  I did a differential check and it's
 appearing that I may have some bad  valves. My highest is #4 at 77/80
 and weakest one is #3 at 50/80. #2 is 76/80  and #1 is 60/80 . Both of
 the weak ones are on the pilot side with air  hissing in the exhaust.
 I can hear a gurgling in the oil tank on all four,  but I don't know
 if that is normal or not since they all sound the same and  the
 starboard cylinders have pretty good compression. I'm fairly
 convinced  I need to do a valve job, but what I need is specific
 teardown/repair  instructions, gasket kit, possibly valves, and someone
 to do the actual valve  job properly.
 Anybody like to give their opinion/recommendations on this?  Sources
 for the above parts would also be appreciated.
 If I go local for  parts, what engine do I tell them I have?
 Deke
  S5 NSI EA81 NA
  380 hours
  NE Michigan
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		n10pg(at)neo.rr.com Guest
				 Posted: Sat Apr 05, 2008 5:05 am    Post subject: NSI compression |
				Hi Deke:
 Why don't you give Ron Carr at RAM Performance a shout. He has done my
 engine. They are located in Clinton OH, a few miles SW of Akron. Their phone
 is (330) 882-6255
 Peter Graichen
 http:/home.neo.rr.com/n10pg/kitfox.htm
 [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
 Sent: Saturday, 05 April, 2008 07:47
 To: Kitfox List
 Subject: NSI compression
 Deke
 S5 NSI EA81 NA
 380 hours
 NE Michigan
		Fox5flyer Guest
				 Posted: Sat Apr 05, 2008 5:20 am    Post subject: NSI compression |
				Thanks Peter.  I'll do that.
 Deke
