Tim Olson
Posted: Mon Apr 07, 2008 8:19 pm Post subject: Door separation/opening is an issue, what's the fix/s ? |
Vortex generators placed on the inside of the doors.....then open
the cockpit air vents and aim them aft along the door surface.
Deems Davis wrote:
When a door opens in flight, the greater/higher pressure is most alway
on the inside of the aircraft. In some high performance aircraft even
with forward hinged doors traveling in excess of 200 mph, it is
physically impossible to close the door while in flight. (remember
Bernoulli?)
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
