		apilot2(at)gmail.com Guest
				 Posted: Tue Apr 08, 2008 3:49 pm    Post subject: NVFR avionics help |
				Substitute SL30 for the SL40. Gives you TSO VOR and ILS. Otherwise, for more space, but older technology, you could put used KX155 or Mk12D in panel. The SL30 should fit in same space, maybe same tray as SL40.
  On Tue, Apr 8, 2008 at 4:20 PM, Chris and Susie McGough <VHMUM(at)bigpond.com (VHMUM(at)bigpond.com)> wrote:
 [quote]        Guys I have decided to change my 10 to NVFR and was  wondering if anyone had some ideas on an easy way to upgrade.
  My current setup is
  DYNON D180
  Garmin 327 Transponder
  SL40 Radio
  Garmin 296 GPS
  Vertical card compass
  Backup ALT and ASI
  Intercom
  So my question is what would be the simplest way to  upgrade to NVFR . The Australian regs say you must have a TSO GPS or VOR or  ADF.
  Should I just get a new GPS?
  regards Chris
		coop85(at)cableone.net Guest
				 Posted: Tue Apr 08, 2008 3:56 pm    Post subject: NVFR avionics help |
				Chris,
      I have a Garmin 480 and absolutely love it.  Since Garmin announced they would no longer produce it you might be able to find them for a better deal before the supply runs out.  I’m just speculating but I suspect a number of folks will shy away from them out of support concerns.  With the 480 (or 430 or 530) you’d have GPS and VOR available.
 Marcus
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and Susie McGough
  Sent: Tuesday, April 08, 2008 6:21 PM
  To: RVs_in_Aus(at)yahoogroups.com.au
  Subject: NVFR avionics help
 My current setup is
 DYNON D180
 SL40 Radio
 Garmin 296 GPS
 Backup ALT and ASI
 Intercom
 regards Chris
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		ron.mcgann(at)baesystems. Guest
				 Posted: Tue Apr 08, 2008 4:07 pm    Post subject: NVFR avionics help |
				Does the inbuilt CDI capability on the 430 and/or SL-30  meet the VOR indication/OBS requirement, or do you need a separate CDI/OBS (eg  GI-106 or MD-200 etc)?
  cheers,
  Ron
   	  | Quote: | 	 		           From: owner-rv10-list-server(at)matronics.com    [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus    Cooper
 Sent: Wednesday, 9 April 2008 9:24 AM
 To:    rv10-list(at)matronics.com
 Subject: RE: NVFR avionics    help
 Chris,
 Marcus
 My current setup    is
 DYNON    D180
 SL40 Radio
 Garmin 296    GPS
 Backup ALT and    ASI
 Intercom
 regards    Chris
 0 | 	  1   [quote][b]
		n212pj(at)gmail.com Guest
				 Posted: Tue Apr 08, 2008 4:12 pm    Post subject: NVFR avionics help |
				Might want to think about upgrading your SL40 to an SL30  and adding a CDI, such as the GI-102A.  Upgrade your 294 to a 496 for  terrain, weather.  Of course you'll have nav lights, landing light,  strobes, plus panel lights and overhead map reading lights.  Basically,  night VFR should be capable of "light" or "rudimentary" IFR.  The problem  with NVFR is that you can easily get into an IFR environment (unseen clouds that  you enter, loss of a horizon due to pitch black seas or landscape).  I love  flying at night, but have found that since going from the well lit Northeastern  US to the relative darkness of the Northwest US, night flying has a whole new  meaning.  I wouldn't do it where I am located now without being IFR rated  and having an IFR panel.  Not unless it was clear skies and city  lights.
  [quote]         From: owner-rv10-list-server(at)matronics.com    [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and    Susie McGough
 Sent: Tuesday, April 08, 2008 4:21 PM
    My current setup is
    DYNON D180
    SL40 Radio
    Garmin 296 GPS
    Backup ALT and ASI
    Intercom
    regards Chris
  | 	  [b]
		VHMUM(at)bigpond.com Guest
				 Posted: Tue Apr 08, 2008 4:29 pm    Post subject: NVFR avionics help |
				Thanks John I am in Australia  and are only  doing the NVfR as I am studying commercial Pilot licence and NVFR is helpful.
  I was thinking I could just swap the radio to SL 30  and plug into Dynon?
  The 296 has terrain and the weather feature is not  available in Australia
  I have all lights etc it just the avionics
  Chris
  [quote]   ---
				 Posted: Tue Apr 08, 2008 4:41 pm    Post subject: NVFR avionics help |
				You might want the SL30 hooked to both the Dynon and a CDI,  incase the Dynon goes away you could switch over.  Or, get a battery backup  for the Dynon.
 Sent: Tuesday, April 08, 2008 5:27 PM
 Subject: Re: NVFR avionics    help
    Chris
    [quote]     ---
		dlm46007(at)cox.net Guest
				 Posted: Tue Apr 08, 2008 7:06 pm    Post subject: NVFR avionics help |
				swap the sl40 for an sl30 you then have a tsoed vor/loc/gs.  the utput can be shownon the Dynon
  My current setup is
  DYNON D180
  SL40 Radio
  Garmin 296 GPS
  Backup ALT and ASI
  Intercom
  regards Chris
		dmaib@me.com
				 Posted: Tue Apr 08, 2008 7:58 pm    Post subject: NVFR avionics help |
				Garmin GNC 300 XL (?) comes to mind as a swap for the SL40. It is a great little IFR GPS/Comm with moving map. They are pretty inexpensive as well.
 David Maib
 40559
 On Tuesday, April 08, 2008, at 06:31PM, "Chris and Susie McGough" <VHMUM(at)bigpond.com> wrote:
  	  | Quote: | 	 		  Guys I have decided to change my 10 to NVFR and was wondering if anyone had some ideas on an easy way to upgrade.
 My current setup is
 DYNON D180
 SL40 Radio
 Garmin 296 GPS
 Backup ALT and ASI
 Intercom
 regards Chris
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
		AirMike
				 Posted: Tue Apr 08, 2008 9:39 pm    Post subject: NVFR avionics help |
				Obviously you are going through the time consuming process of panel planning. After beating around the bush for 2 months, I went with the SL30 as most of the threads here also indicate. I tried for a long time to save the extra two thousand plus dollars on the SL40 (radio only). I finally realized that it was false economy. Yes(Ron) you do need the additional CDI and Glide slope lights. The AFS3500 has (built in) the CDI indicators for guidance but you also need an audio panel for the Marker Beacon lights. Yes that is another $1000. My panel is being finished by the very nice folks at Aerotronics in Billings, MT. While I have not yet received the panel, I am very impressed with the excellent customer interaction and pro-active approach that Aerotronic takes. I got three bids on my panel, but went with them on my intuition and the advice of a member of the EAA advisory panel. I will give another report after I P/U the panel later this month. This is my thinking that this a a serous NVFR panel and will get me out of trouble if caught in IFR conditions. It seem to be a very cost effective setup. Probably could save more with Dynon
 AFS3500  (1x)
 Garmin SL30 Nav/Com
 Garmin 327  Mode "C" Transponder
 Garmin 340 Audio
 Garmin 496
 Digiflight II VS
 Trutrak B/U ADI  Backup  2.25"
 UMA Altimeter     Backup   2.25"
 UMA A/S             Backup    2.25"
 Xaon XRX           TCAS  Beta (talks to 496)
 PAI Vertical Card compass
  _________________ See you OSH '18
Q/B - sold. |
				 Posted: Tue Apr 08, 2008 10:17 pm    Post subject: NVFR avionics help |
				Mike ....my 10 is just about ready to fly and as per email you can see my
 current setup and wanted to go from there.
 thanks anyway  regards Chris
		rj_todd(at)yahoo.co.uk Guest
				 Posted: Wed Apr 09, 2008 3:52 am    Post subject: NVFR avionics help |
				Hi Chris,
 You'll need to replace (or add to) the SL-40 with an SL-30 which will give you a TSO'd VOR/LOC/GS. To this you will have to add an MD200 series CDI to maintain the TSO.
 Why don't you contact Jake (can't find his e-mail address at the moment) to confirm that you don't need anything else avionics wise?  Also why noit try the Oz RV Yahoo group site?
 Looking forward to hearing about the first flight - Spring is in the air!
 Rodger
 --- On Wed, 9/4/08, Chris and Susie McGough <VHMUM(at)bigpond.com> wrote:
 [quote] From: Chris and Susie McGough <VHMUM(at)bigpond.com>
  Subject: Re: Re: NVFR avionics help
  Date: Wednesday, 9 April, 2008, 8:13 AM
  you can see my
		GRANSCOTT(at)aol.com Guest
				 Posted: Wed Apr 09, 2008 6:42 am    Post subject: NVFR avionics help |
				KX 155 with a CDI would be pretty inexpensive compared to a TSO'd GPS and  may give you good  situational and back  up...
 Planning your summer road trip? Check out AOL Travel Guides.
