Alternate Feed Switch, is it a Master Switch??
nuckolls.bob(at)cox.net
PostPosted: Sat Apr 12, 2008 7:36 am    Post subject: Alternate Feed Switch, is it a Master Switch?? Reply with quote
At 12:06 AM 4/12/2008 -0700, you wrote:
Help! Am working on a new electrical system design (pretty much a standard
Z-11) for a complete re-wire of a certified ship. A friend tells me that a
certified aircraft can only have one Master Switch per FAA regs.
Ask him to cite the regulation. I've never read it anywhere.
We have lots of switches in TC aircraft OTHER than the DC
POWER MASTER switch that re-organize bus structures and/or
control alternative pathways to power sources. For example,
many offerings in recent years at HawkerBeech have a "clearance
delivery" switch that allows one to power up one radio directly
from the battery for the purpose of getting ATIS and Clearance
Delivery before powering up the whole airplane.
Is the "Alternate Feed" switch for the Endurance Bus considered a
Master Switch? If so, how does it reconcile with any regs? Or, is my
friend wrong? I have read Sec. 23.1361, regarding Master Switch
arrangement, and I'm not totally comfortable in my interpretation of what
is being said. The section seems to infer that more than one switch can
be incorporated into a Master Switch arrangement, but with some
restrictions. Can someone shed some light on me regarding this matter?
I have been planning to locate the Alternate Feed switch immediately
adjacent to the main Master Switch and under a switch guard. Presumably,
both switches would only be on simultaneously for the short time after
energizing the Endurance Bus via the Alternate Feed and turning the main
Master off after an alternator or battery contactor failure.
Per 23.1361, am I restricted to no more than a 5 amp total load on the
Endurance Bus (that should be plenty)? Would I also be restricted to no
more than a 5 amp protective device for the bus feed? My bus feed wire
will be about 8" long.
Thanks to any of you "Masters" for any enlightenment you can share.
The 5-Amp rule presupposes that the battery feeder to the
E-bus Alternate Feed switch is LONG . . . 5A is the rule-
of-thumb for limiting always-hot feeders directly from
the battery that might pose a post-crash risk of fire.
It's pretty much a hip-shot number. Give me control over
the conditions and I can light off gasoline with a 1A
feeder and not open the breaker.
If you NEED to protect the alternate feed at more than
5A, then install a "mini-battery contactor" right at
the battery bus as suggested in:
http://www.aeroelectric.com/Pictures/Schematics/E-BusFatFeed.gif
http://www.aeroelectric.com/PPS/DCPwr/E-Bus/E-Bus_Heavy.pdf
This provides for local disconnect of feeders protected
at more than 5A.
The FAR quoted above can be found at:
http://www.risingup.com/fars/info/part23-1361-FAR.shtml
Okay, let's look at it:
Sec. 23.1361 - Master switch arrangement.
(a) There must be a master switch arrangement to allow ready disconnection
of EACH electric power source from power distribution systems, except as
provided in paragraph (b) of this section.
Note that the rules allow for MORE than one power source, hence more
than one switch . . .
The point of disconnection must be adjacent to the sources controlled by
the switch arrangement.
Yup, unless the feeder is limited to 5A or less as described below:
If separate switches are incorporated into the master switch arrangement, a
means must be provided for the switch arrangement to be operated by one
hand with a single movement.
Yeah . . . this is a tad silly. If one is concerned about getting
switching ALL potential hazards off with switches as a single movement
then the magneto switches should probably be included under the
one-movement-does-all mechanism. In the suggested switch layouts
shown in
http://www.aeroelectric.com/PPS/Mechanical/Switches.pdf
. . . switches that control all power including ignition are
grouped at one end of the array. Easy to locate and easy to get
turned OFF in a timely manner when circumstances call for it.
For a TC aircraft, you can craft a hinged "crash bar" that
provides the requested one-stroke operation of adjacent switches.
I had a discussion some years ago with a 172 owner who was
wanting to do the same thing you're doing. We discussed using
switch guards over adjacent switches and ganging them together
with a bonded plate so that slapping them down opened both
switches.
Now, this one-hand-operation is somehow magically ignored in
some TC aircraft where emergency batteries are used to power
up essential appliances . . . they are generally not fitted with
or even arranged such that one-handed operation is possible.
(b) Load circuits may be connected so that they remain energized when the
master switch is open, if the circuits are isolated, or physically
shielded, to prevent their igniting flammable fluids or vapors that might
be liberated by the leakage or rupture of any flammable fluid system; and
(1) The circuits are required for continued operation of the engine; or
(2) The circuits are protected by circuit protective devices with a rating
of five amperes or less adjacent to the electric power source.
(3) In addition, two or more circuits installed in accordance with the
requirements of paragraph (b)(2) of this section must not be used to supply
a load of more than five amperes.
(c) The master switch or its controls must be so installed that the switch
is easily discernible and accessible to a crewmember.
Since your proposed changes are not part of the original
TC on the as-built airplane, you're going to have to jump
STC/337 hoops. So this is between you and your local
regulators. What you're proposing has been done before
and is not a really big deal. It's just slight rearrangement
of the design goals that have been similarly addressed with
additions of the "clearance delivery" switch on modern
aircraft.
Leo Holler
PostPosted: Sat Apr 12, 2008 10:52 am    Post subject: Re: Alternate Feed Switch, is it a Master Switch?? Reply with quote
Thanks Bob for an exceptional and thorough response. You very clearly took the most of the "fog" out of my feeble interpretation of Section-23-1361. I'll be able to better make my 337(Field Approval) case to FAA now, as well as educate my friend.
Does the above mean that the 5A rule applies only if there is no disconnection adjacent to the source? Also, do you consider the 8" unprotected run from battery to Alternate Feed switch to be excessive? If so, I can fuse it, or add the mini-contactor as you have suggested. Also, I have heard that new Cessnas have Essential/Endurance buses installed. Have you or anyone else heard of this and, if so, how did they handle the Master Switch arrangement? A local Cessna dealer hinted that I could get their schematic by buying the CD for several hundred dollars or by buying a new aircraft. Shocked This forum seems much more user friendly. Very Happy
Thanks again.
Leo
