Patching Hanger Rash
peteohms
PostPosted: Thu Apr 10, 2008 5:11 pm    Post subject: Patching Hanger Rash Reply with quote
Ok, got my new (to me) Kitfox III home and need to fix a couple small holes
in the side of the fuselage. The plane was painted with Durethane. Now I'd
like to just put a round patch on the inside to prevent the holes from
growing and maybe later do something to the ouside, What should I use to
install the inside patch. I figure some hardware store urethane. Any other
suggestions? What will I need to do when I get around to fixing the outside?
Pete
Kitfox III N73BH
Hell Paso, TX
Pete
Leander, TX
Kitfox III, 912ul, Grove
kitfoxpilot(at)msn.com
PostPosted: Fri Apr 11, 2008 3:18 am    Post subject: Patching Hanger Rash Reply with quote
You want to use a small amount of poly tac and glue a silver dollar size patch on the inside.
Ray
Subject: Patching Hanger Rash
Date: Thu, 10 Apr 2008 19:08:01 -0600
--> Kitfox-List message posted by: "Pete Christensen" <apeterchristensen(at)sbcglobal.net>
Pete
Kitfox III N73BH
Hell Paso, TX
Going green? See the top 12 foods to eat organic. [quote][b]
Float Flyr
PostPosted: Fri Apr 11, 2008 5:00 am    Post subject: Patching Hanger Rash Reply with quote
Pete"
First thing to do is to check out the Durethane system. Patch the hole from
the outside with a minimum of 1 inch border, 2" on top of wings using what
they (Durethane) recommends. If that system is similar to Randolph you will
have to remove the finish coat before adhering the patches to outside of the
plane. When the patch is installed and shrunk depending on it's size you
may want to go over the edge of the repair with tape. Replace the original
finish.
If you have a lot of small holes in one area it may be neater and easier to
remove a whole section of cloth and replace it. I
I hope it's on a white area... colour matching can be a bear!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Tom Jones
PostPosted: Fri Apr 11, 2008 6:21 am    Post subject: Re: Patching Hanger Rash Reply with quote
Pete
Kitfox III N73BH
Hell Paso, TX
Pete, I am not familiar with Durethane. Is that just the paint and does the fabric system look like poly fiber? If it is poly fiber it is very easy to patch small holes from the inside. Make a wood frame like a picture frame. Staple a piece of fabric on the frame. Shrink the fabric with an iron at 300 to 350 degrees. Cur out silver dollar size patches with pinking shears. Attach the patches to the inside of the fabric with poly brush.
Try to find someone in your area that has done some covering and has the poly fiber supplies on hand. It would be kind of expensive to purchase. I can send send you some fabric in the mail if you need some. I have lots of good sized scraps left over you can have.
Tom Jones
Classic IV
Ellensburg, WA
peteohms
PostPosted: Fri Apr 11, 2008 7:36 am    Post subject: Patching Hanger Rash Reply with quote
Thanks Tom,
I have a local friend with all the supplies. It is initially poly fiber.
Sounds like a good way to go.
Pete
Pete
Leander, TX
n85ae
PostPosted: Fri Apr 11, 2008 9:19 am    Post subject: Re: Patching Hanger Rash Reply with quote
DON'T try to polytak a patch underneath, unless you plan to repaint. I tried
that under aerothane, and what a mess. The aerothane was fine, but the polybrush/polyspray under it melted which made the aerothane blister and
bubble up all over.
Jeff
Float Flyr
PostPosted: Fri Apr 11, 2008 7:02 pm    Post subject: Patching Hanger Rash Reply with quote
That is why this morning I said to remove the finish coats and dope the patch onto the outside of the hole. Then shrink the patch and finish as normal. Also if there are several holes in the same area it is much cleaner to remove the whole area. E.g. for three or four holes together on the top of a wing remove a strip inside the ribs across the whole top of the wing. When the patch is applied and taped You won't even notice it.
Depending on the hole it is also possible, even advisable to stitch up the wing with a herringbone stitch and cover it with a tape which can be shrunk and finished.
Trying to glue pre-finished pieces of cloth inside a wing or rudder... good luck... you’ll need it!
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
 Filesize:  7.29 KB
 Viewed:  4305 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
