brs install
lgold(at)quantum-associat
PostPosted: Sat Apr 19, 2008 9:29 pm    Post subject: brs install Reply with quote
My chute was a soft pack (not a canister) and BRS said to cut the skin 2"
wider than the chute pack on all sides. I scored the cover about 1/2 way
through to make certain that I did not cut too deeply but BRS provided no
insight regarding this.
I don't think BRS recommends a canister for the 701. I don't think they make
a big enough one for the job.
Les
[quote] --
craig(at)craigandjean.com
PostPosted: Sat Apr 19, 2008 11:15 pm    Post subject: brs install Reply with quote
The BRS site is confusing. On this page it shows a picture of a canister with the caption "The shape that defines Sport aircraft. Small light weight fast opening, weights from 600 lbs to 1500."
http://brsparachutes.com/BRS+Products/Models/Sport+Aircraft/default.aspx
But the specifications here (or click on "Specifications" at the bottom of the above page) don't list a canister above 1050 lbs:
http://brsparachutes.com/ViewDocument.aspx?DocumentID=80
Mike Sinclair's 701 tail dragger has a canister BRS which you can just barely make out in this thumbnail. Maybe he kept the weight down:
I’d post the full-sized picture but Barnstormers is down.
-- Craig
 Filesize:  11.82 KB
 Viewed:  281 Time(s)
