gmcjetpilot
Posted: Tue Apr 22, 2008 11:16 pm Post subject: Lightspeed III & DPS smart Tach, signal issue help? |
<?xml:namespace prefix = mailto />Does any one have experience getting a DSP smart tach to work with a LS Plasma III?
I am helping a guy out with his new Lightspeed III ignition. My analysis the LS signal is not compatible in stock form to drive the DPS tach.
He wants to use his DPS smart tach (they are out of business BTW). Here is the issue.
The new ignition LS Plasma III has a tach signal of a square tooth wave from 0 volt to +10 volts amplitude with a duration of 1.5ms. It fires two times per revolution. OK its a hall effect signal a digital OFF/ON.
Here is the issue, the tach was triggered with a sensor in the access hole of a magneto. It detected the internal rotating magnet in the magneto. Unlike a typical magnetic inductive signal (alternating) it states in the installation manual, voltage sits at a constant +5 volts and when the magnet passes the sensor, the voltage momentary drops to 0.70 volts. How it looks on a scope I don't know, probably rounded or spike.
I need to go from the LS's positive square wave signal to a volt drop signal that is not so square wave, basically inverting the wave.
Is there some easy circuit off the top of your head to convert these two wave forms, condition the signal? I'm thinking an Op amp, diode and a cap and R or two.
I'm drawing a blank. The DSP tach does have selection of pulse per rotation. Taking the tach apart to mod it is not on the table (yet). Access to the schematics is not likely. May be it is time he bought a new tach?
Thanks George
Be a better friend, newshound, and [quote][b]
nuckolls.bob(at)cox.net Guest
Posted: Wed Apr 23, 2008 5:42 am Post subject: Lightspeed III & DPS smart Tach, signal issue help? |
At 12:12 AM 4/23/2008 -0700, you wrote:
| Quote: | <?xml:namespace prefix = mailto />Does any one have experience getting a
the issue.
Was the original DSP sensor a two-wire or three-wire device?
I've seen through-the-housing aircraft magneto tach sensors
in both formats. The three wire devices are always hall effect
sensors that output a digital friendly, square waveform. If
it was a two-wire device, then it's probably a variable reluctance
sensor . . . a coil of wire wound on a central bias magnet.
The the output from these devices is a digitally unfriendly,
one-cycle per event ground referenced waveform not unlike that
illustrated in Figure 2 of this document.
http://cache.national.com/ds/LM/LM1815.pdf
Usually, the input circuitry for a device expecting a
variable reluctance input signal are capable of
properly responding to a single pulse having
nicely squared edges. But there may be a DC bias
issue presents an offset issue.
Put a 1K resistor across the input to the tach and
then look at DC voltage on both ends of the
resistor. If there is no obvious DC common mode
voltage, then check resistance of each end of
resistor to ground. Hopefully, one end is tied to
ground. If so, then the OTHER end is your real
signal input lead. If there is a measurable
DC voltage and/or neither end of the sensor input
runs at ground, then there's a possibility that
the tachometer expects a floating signal sensor
with some DC continuity and that unlike the
tach chip described above, needs to be spoofed
into believing that the ground referenced, digital
pulse from LS ignition is a variable reluctance
sensor.
The easiest way to craft an interface box is
on the bench. Set up a signal generator to
emulate the output of the LS ignition.
The 555 timer based r/c servo tester is also
suitable. See page 7 of:
http://www.princeton.edu/~mae412/TEXT/NTRAK2002/292-302.pdf
. . . except in this case, you want to vary
the period of the timing pulses (Adjust R3 in
diagram) as opposed to adjusting pulse width
(R2).
and R or two.
If the DSP tach expects a dc-continuity through
a sensor with floating ground, you might experiment
with transformer coupling a buffered version
of the LS tach signal. Something like the top sketch
at . . .
http://www.aeroelectric.com/_temp/LS-DSP_Interface.pdf
. . . offers a foundation for a working solution.
If all it needs is an inverter, then the lower
sketch is a starting point.
That is probably the least expensive in terms of
$time$. Even after you solve the electronic problem,
there are issues of packaging, installation and
the specter of unanticipated future issues with respect
to EMC, etc.
It's up to all the participants involved to put
value on their $time$ and to assess return on
investment.
