Floscan sensor
Tim Juhl
PostPosted: Tue Apr 22, 2008 3:09 pm    Post subject: Floscan sensor Reply with quote
I can get my hands on a lightly used floscan transducer dirt cheap. It is a model 201B-18. Looking on Floscan's website I see specs on a 201B-6 but I haven't had luck finding specs on the -18.
Does any one know if this unit is suitable for use with a Jab 3300 and it's expected fuel flow rates?
Tim Juhl
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
Peter H
PostPosted: Tue Apr 22, 2008 4:14 pm    Post subject: Floscan sensor Reply with quote
Tim FWIW I have been successfully using a Navman which has a rather
cumbersome turbine transducer and no doubt effects my gravity feed to the
pump.
I find the fuel flow meter one of the most useful in the cockpit especially
for managing fuel flow on a cross country. And it shows remaining fuel with
an accuracy of 2%.
Peter H
Charles R Gallagher
PostPosted: Tue Apr 22, 2008 6:01 pm    Post subject: Floscan sensor Reply with quote
Tim, the "B" in the model number denotes a flow rate of 0.6 to 60 GPH and is recommended for 100 to 200 HP. If you do install the flow meter double check the flow direction before you button every thing up. Also, the FLOW SCAN support is good before and after your installation , base on my experience on a marine application. Rgs.,Charles Gallagher
Tim Juhl <juhl(at)avci.net> wrote:[quote] --> JabiruEngine-List message posted by: "Tim Juhl"
Tim Be a better friend, newshound, and [quote][b]
