		jimh474(at)embarqmail.com Guest
				 Posted: Fri Apr 18, 2008 3:27 pm    Post subject: expert in everything |
				Ron;
 I don't interact very often on the Kolb list, just read and chuckle.
 Ron, It seems that you give a bunch of advice in areas that you have no
 experience, or you fail to state your experience in certain subjects, i.e.
 parachutes.
 As to parachutes, what is your experience factor on this subject? Are you
 getting a rebate from BRS so you promote their product?
 There is more than one solution to a recovery parachutes than BRS.
 There is nothing wrong with a hand deployed parachute. It eliminates the
 malfunction of a mortar. If the individual
 using that item rehearses how he is going to deploy it. That is the
 paramount item in a hand deployed parachute. Same with a BRS or any other
 recovery
 parachute. How many on this list has every went through emergency procedures
 of when and how they will deploy a parachute. I will bet you that most have
 never considered rehearsing the procedure. Just take for granted that piece
 of nylon will save their butt.
 Hand deployed or mortar deployed, the individual has to know when to deploy
 and how. It should be second nature to grab the deployment handle without
 even looking.  I also bet you if some of the folks on this list was sitting
 in their airplane and you told them to deploy their recovery parachute, they
 would have to sit there and think a few seconds of where the hell the handle
 is, Seconds wasted is altitude. I think that a person should rehearse this
 until it is second nature to them.
 For a mortar actuated recovery parachute, the activating handle should be in
 easy reach, in case G loads from a catastrophic failure should incur they
 could overcome the G forces generated by the failure.
 Hand deployed, is simple, it is either attached to your chest or in a very
 close proximity to the pilot. On hand deployed I would suggest throwing the
 deployment bag down and out from the airplane. This will keep it away from
 most areas where it could get entangled. Also, you have more force in
 strength throwing it down and away.( This method saved my brothers butt on
 two occasions) Yes, I packed both of them.
 Unlike silk prior to WWII which was sensitive to the environment and had to
 be handled with kid gloves, thanks to DuPont that created a nylon fabric for
 parachutes that is almost indestructible. Very few things will cause nylon
 to go south, acid, direct sunlight. Age is really not a factor on a
 parachute made of nylon that has been properly cared for. The biggest thing
 I see with recovery parachutes is the bridle, if it is a synthetic material
 exposed to the sun, that is always an iffy question of whether or not it
 will hold the load on deployment. Ultra violet rays works on all man made
 synthetic materials and it is undetectable by eye ball whether the item has
 deteriorated or not. I would suggest using a wire cable.
 Experience with parachutes, I have a wee bit. I jumped out of airplanes for
 over 20 years, certified military parachute rigger,was involved with
 development of several parachute systems and many other air item systems. I
 have over 2000 parachute jumps ranging from 500 feet to 43,500 feet. ( that
 is higher than most of you have ever flown commercial).
 Don't get me wrong I am not blowing my horn, just hope that I can give a
 hint to the folks on this list that a parachute whether hand deployed or
 mortar, regardless of how it is deployed and used properly will save your
 bacon. But, you have to be the one to be able to deploy it properly. That
 comes from practicing how to properly deploy it.
 Of course, Murphy may have something to say about!
 Jim Hauck
 The Older better looking  Brother To John H
				 Posted: Sat Apr 19, 2008 2:17 am    Post subject: expert in everything |
				Of course, Murphy may have something to say about!>>
 Hi John,
 have you seen the clip on Youtube of the chute deploying just as a
 weightshift leaves the ground?  Enough to make you wonder.
 Chutes are almost non existant over here. I used to have one on my old
 Thruster but didn`t continue when I swithched to the Challenger. I don`t
 think I have ever seen one fitted in the UK. On the other hand I believe
 that they are mandatory in Germany.
 Cheers
 Pat
		lucien
				 Posted: Sat Apr 19, 2008 8:48 am    Post subject: Re: expert in everything |
				 	  | pj.ladd(at)btinternet.com wrote: | 	 		  Of course, Murphy may have something to say about!>>
 Hi John,
 Cheers
 Pat |
 My .02 on the chute,
 The biggest con of the chute is what the original poster alluded to - actual deployment and descent to the ground can't be actually practiced in the air.
 The lifeblood of emergency procedures is actual practice of them in the air in the airplane. Engine-outs, unusual attitudes and so forth; all of these we can go up in the airplane and practice under actual conditions.
 Emergency procedures that can't be practiced or even simulated to any degree aren't worth very much - as we know in an actual emergency training takes priority over thinking the situation through.
 So I personally don't see a large value to fitting the ballistic chutes to our planes, particularly to good designs like the ones we fly. There is a remote possibility that the chute could save your life in a very extreme circumstance, but because of the very small likelihood of encountering such a situation, I personally don't think it's worth 3000 bucks.
 3000 bucks will buy lots of maintenance items, as well as gas for practicing flying the plane in more "simulatable" emergency scenarios like engine-outs and such.
 Again, JMHO,
 LS
  _________________ LS
Titan II SS |
		Steve Boetto
				 Posted: Sat Apr 19, 2008 11:18 am    Post subject: expert in everything |
				Nice thought, certianly something to think about as you watch the houses on  the ground get bigger.  But seriously, you are forgetting the rest of the  formula.  I fly sans windshield. If I take a bird in the face the plane may  be perfectly functional but I might be flying blind.  No way to land that  sucker. There are other situations when a chute would help of which an engine  out is not on my list. There was an excrllent article a few years ago in Sport  Pilot.
  Steve
  FF #007/floats
  FF #040/floats SnF 2008 UL Grand Champ
   In a message dated 4/19/2008 12:52:04 P.M. Eastern Standard Time,  lstavenhagen(at)hotmail.com writes:
 Again,  JMHO,
 LS
 Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
				 Posted: Sat Apr 19, 2008 12:58 pm    Post subject: expert in everything |
  the air.
  Again, JMHO,
  LS
 Lucien:
 Anyone that can fly a Kolb can land it in an emergency situation without
 power.  Of course, parachutes are not for that type emergency.
 My first save was a catastrophic failure of the upper aileron bell crank in
 my US, October 1985.  Before the use of my parachute for the first time, my
 attitude was much the same as yours.  I can handle the situation, plus this
 is a factory welded kit and it has never happened before.  Guess I was a
 little wrong in that respect, but right in having another way to save my
 life.  Kolbs do not fly long without aileron control.
 Second catastrophic failure was even more of a surprise than the first.
 Failure of leading edges of both wings on my FS 4.5 years later.  Sure, I
 flew aerobatics in the FS, as well as the US.  However, all within the
 authorized stress envelope of the aircraft.  The wing was the last thing we
 ever thought would fail.  Without the same old Handbury parachute, my flying
 career would have been permanently ended March 1990.
 We don't need to actually practice parachute deployment in the air to
 receive valuable familiarization and training.  It can be done in the
 cockpit of the airplane.  Know how to grab and pull the handle with your
 eyes closed without thinking about it.  When the time comes to use it, do
 not hesitate. Time is altitude. Altitude is safety.  No matter what
 altitude, use it if you are no longer in control of the aircraft.
 To think there is not a catastrophic failure in the future of your Kolb or
 any other aircraft is pretty naive.
 Even though the odds of ever using a parachute in a catastrophic event are
 pretty damn slim, when the time comes to use one and you felt it was too
 expensive to purchase, and you don't have one, will probably really piss you
 off.  Don't worry about screaming all the way to the ground, you'll be so
 damn scared no sounds will be emitted.  If you are like me, you are
 thinking, "I don't believe this is happening to me."  and "Damn, I don't
 believe this is happening to me again."
 I have hauled an expensive piece of equipment with me for nearly 3,000
 hours, and have not needed it.
 If that 10 cent 3/16 bolt on the bottom flying wires breaks, or the nut
 comes off, I have a way to offset the problem.
 Take care,
 PS:  No matter how reliable your aircraft, a midair will ruin your day, with
 or without a parachute.  Could possibly save your life though.
  _________________ John Hauck
Titus, Alabama |
		Thom Riddle
				 Posted: Sat Apr 19, 2008 1:07 pm    Post subject: Re: expert in everything |
				A good alternative to mortar powered chutes are the ones made and sold by these folks in BC, Canada.
 http://www.ultralight.ca/recovery/default1.htm
 They have a lot of good accessory products and at one time also made the GSC System wooden props. I understand they sold the prop business to one of their ex-employees who now runs it. I had their mechanically actuated in-flight adjustable prop on my Tornado. Very good prop in my experience.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		Arty Trost
  Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
				 Posted: Sat Apr 19, 2008 3:01 pm    Post subject: expert in everything |
				Lucien, I disagree with your statement  "Emergency
 to any degree aren't worth very much."  (In relation
 to the value of a parachute.)
 A friend of mine had structural failure on his Tierra
 ultralight when flying (at) 1500' AGL and pulled the
 handle of his BRS chute.  He had never "practiced" -
 but he had no trouble in getting the parachute to
 launch.  Came down on the tail with no injury to
 himself - just scared to death.  It made me a believer
 in emergency chutes.  Just another form of insurance,
 which I hope I'll never have to use.
 Since I'm pretty small - I have only 15 lbs. over the
 much-written about 90 lb. weakling! - I've often
 wondered if I'd have the strength to pull the handle
 and launch the chute on my Drifter.  But it's way too
 expensive for me to try it out, and friends have
 assured me that the adrenalin rush will give me the
 strength of 10 when it comes to pulling that handle!
 Arty Trost
 Maxair Drifter
 Sandy, Oregon
  	  | Quote: | 	 		    > My .02 on the chute,
  poster alluded to -
  > the air.
  through.
  worth 3000 bucks.
  well as gas for
  > Again, JMHO,
  > LS
  Lucien:
  emergency.
  control.
  can be done in the
  No matter what
  the aircraft.
  you felt it was too
  like me, you are
   and "Damn, I don't
  me for nearly 3,000
  breaks, or the nut
  Take care,
  life though.
  browse
  Un/Subscription,
  FAQ,
  Forums!
  Admin.
 www.LessonsFromTheEdge.com
 "Life's a daring adventure or nothing"
                       Helen Keller
 "I refuse to tip toe through life just to arrive safely at death."
		russ(at)rkiphoto.com Guest
				 Posted: Sat Apr 19, 2008 4:32 pm    Post subject: expert in everything |
				LUCIEN
 DON'T KNOW ABOUT YOU BUT MY  LIFE IS WORTH A LOT  MORE THAN  A MEASLY
 3000 BUCKS.
 IF I CAN  HAVE A RESCUE CHUTE ON ANYTHING I FLY, I'LL BLOODY WELL
 HAVE IT. COUNT ON IT
 I'M DETERMINED TO LIVE AS LONG  AS I CAN.
 YOU DO WHATEVER YOU WANT
 On Apr 19, 2008, at 12:48 PM, lucien wrote:
 > Hi John,
 > old
 > don`t
 > believe
 > Cheers
 > Pat
  actual conditions.
  Again, JMHO,
  LS
  LS
  FS II
  http://forums.matronics.com/viewtopic.php?p=177854#177854
		JetPilot
				 Posted: Sat Apr 19, 2008 6:38 pm    Post subject: Re: expert in everything |
				Lucien,
 You beliefs about parachutes and emergencies are very misguided.  Emergency procedure like engine out landings are complicated with a lot of variables and must be practiced to be done correctly.  Stall / Spin recovery also requires skill and technique that should be practiced.
 Pulling a handle on a chute is not something that needs to be practiced to be done successfully.  If my airplane becomes uncontrollable for any of a million possible reasons, I will pull the handle and the chute will come out, not a lot of skill involved.   The chute is going to deploy by itself once the handle is pulled, the technique I use to pull pull that handle, how hard, or how fast I am going to pull the handle is not going to change a damn thing, the chute will come out in just the same way...
 BRS Chutes have been a huge success in Cirrus aircraft.  There are also over 200 saves listed on:
 http://www.brsparachutes.com/files/Documents/Lives-Saved.pdf
 If someone is unable to grasp the concept of pulling a big red handle just because there is no way to practice it, they should probably not be flying.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		lucien
				 Posted: Sat Apr 19, 2008 9:23 pm    Post subject: Re: expert in everything |
				 	  | JetPilot wrote: | 	 		  Lucien,
 Mike |
 Heh... I usually get hate mail when I mention my viewpoint on the chutes, this time followed suit nicely....
 As for the ongoing discussion of the chute, I'm going to stop at this point to avoid the inevitable jousting that will surely break out. Instead, I'll refer anyone interested to the yahoo groups, such as Fly-UL, where there have been very extensive threads on the pros and cons of the ballistic chutes. Most of them eventually got out of hand and the end, but still contain lots of valuable reasoning on both sides.
 LS
Titan II SS |
		Dana
				 Posted: Sun Apr 20, 2008 5:08 am    Post subject: expert in everything |
				At 10:38 PM 4/19/2008, JetPilot wrote:
 I don't dispute that BRS's have saved lives, but about 3/4 of the "saves"
 on that list are NOT situations where a chute should have been
 used.  "Engine failure" (except in very rare situations) is not a reason to
 use a chute, and there is NO excuse for "loss of control".  As for the
 Cirrus, the chute is standard equipment because the aircraft has no
 demonstrated spin recovery (the "book" spin recovery is "pull the
 chute").  The Cirrus is a fairly hot ship; lots of fairly low time pilots
 with too much money buy one, get into trouble, panic, and pop the chute.
 As for practicing, PG and HG pilots regularly do it.  The pilot sits in his
 harness suspended from something overhead, and practices reaching for the
 chute and throwing it while an instructor swings and spins him around to
 disorient him.  If it's a "reserve repack" clinic, the pilot actually
 throws the chute, then the riggers repack them at the end of the day.
 Still... that rocketless Canadian one looks interesting.  I've emailed
 asking for more info and pricing.
 -Dana
   "Makers of oils will assure you their lubricants will last the life of
 the transmission. This may be true, but that life can be longer if you
 change the oil.
		jb92563
  Joined: 23 Mar 2007 Posts: 314 Location: Southern  California
				 Posted: Mon Apr 21, 2008 12:13 pm    Post subject: Re: expert in everything |
				Dana,
 Let us know the price you find.
 Last time I checked with them a couple years ago, it was a couple hundred or 3 less than a BRS....not much difference to make it worthwhile over a BRS.
 Perhaps now that the Canadian dollar is worth more, they will cost more than a BRS, unless they lowered their prices.
  _________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
		Dana
				 Posted: Mon Apr 21, 2008 1:34 pm    Post subject: expert in everything |
				At 04:13 PM 4/21/2008, jb92563 wrote:
  	  | Quote: | 	 		  Last time I checked with them a couple years ago, it was a couple hundred
 I guess not much has changed:
  	  | Quote: | 	 		  RPS 525 is $ 2450 plus shipping
 It weighs 16 lbs
 Repacking interval is every 5 years and it can be done by a rigger, does
 not necessarily have to come back to us.
 Delivery is 4 - 6 weeks from confirmed order date.  All orders are
 confirmed by a deposit of $ 1000 before we will proceed with the order.
 Yikes, that's only $50 less than I paid for my plane... including
 trailer!  'Fraid the budget doesn't run to it right now...
 -Dana
   In general, liberalism consists of A & B getting together to see what
 they can make C do for poor old D.
		Thom Riddle
				 Posted: Mon Apr 21, 2008 1:47 pm    Post subject: Re: expert in everything |
				re: spring launched vs rocket launched recovery chutes
 Saving $300 is worth... $300. Another payoff is that you don't have to pay HAZMAT fees when shipping. A high quality spring launch is pretty much murphy proof.
 I'm not selling them and have never owned one but if it every comes time for me to replace my BRS, it will be with the spring-launched one.
Buffalo, NY (9G0)
- Anonymous |
				 Posted: Mon Apr 21, 2008 2:05 pm    Post subject: expert in everything |
  Thom Riddle
 Thom R:
 How well does the spring loaded lauch compare with the solid rocket launch
 of the BRS?
Titus, Alabama |
		jb92563
		cristalclear13
  Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
