Wiggly Cotter pins
recapen(at)earthlink.net
PostPosted: Thu Apr 24, 2008 4:36 am    Post subject: Wiggly Cotter pins Reply with quote
One of my four engine mount bolt cotter pins wiggles a bit - it is set like the other three.
I've re-done it a bunch of times - so either it is technique for this particular bolt...or there's something wrong with the setup. I'm using the same size pin for all four bolts. I'm really thinking it is my technique.
According to the 43.13 the head should fit snug - which I take to mean that they shouldn't wiggle. Conceptually, I think the wiggling could lead to friction erosion of the pin - with a potential for failure.
Maybe, I need to do this one using the other method for setting them - I've been trying to bend one leg over the top and the other down - I may try the 'anchor' method as shown in the 43.13.
Somebody tell me that I'm not out of my mind with my anal-retentiveness.....
Ralph Capen
RV6AQB Slider N822AR (at) N06
Knocking out the million little things.....
flyinwithme99(at)yahoo.co
PostPosted: Thu Apr 24, 2008 7:12 am    Post subject: Wiggly Cotter pins Reply with quote
Sorry Ralph, can't vouch for your sanity !!
If you really need this cotter pin to quit wiggling...try adding another washer under the nut to cause the bottom of the slot in the castle nut to be more in line with, or alittle higher than the hole drilled in the bolt.
I've seen that when the hole is alittle high in the slot of the castle nut, that it can be difficult to secure the cotter pin from wiggling....especially with the larger cotter pins.
Manny
"Ralph E. Capen" <recapen(at)earthlink.net> wrote:
[quote]--> LycomingEngines-List message posted by: "Ralph E. Capen"
I've re-done it a bunch of times - so either it is Be a better friend, newshound, and [quote][b]
javisteele(at)sympatico.c
PostPosted: Thu Apr 24, 2008 8:13 am    Post subject: Wiggly Cotter pins Reply with quote
Ralph. quit worrying. if the loose cotter pin is a bother put a drop of crazy glue on it. It wont wiggle and it will keep on doing its job/
JC
dc71(at)netspace.net.au
PostPosted: Thu Apr 24, 2008 4:45 pm    Post subject: Wiggly Cotter pins Reply with quote
No - you're not out of your mind.
My LAME (Aussie terminology for A&P) said that my wiggly pins needed
to be fixed - either installing next size up, or using a dab of
silicone RTV (but not too much to obscure visibility)
Indran
it is my technique.
failure.
retentiveness.....
Ralph Capen
