jeff(at)rmmm.net Guest
Posted: Sun Apr 27, 2008 1:06 pm Post subject: Rough on the lafet mag |
HI All,
After returning to the ground and as I shut down I went from both the
right then left mag before shutting down. I noticed the left running
slightly rough compared to the right. I didn't have time to look it
over then but I will soon. Other than the plugs can anyone tell me
anything they have found to cause this.
Thanks in advance to anyone with Ideas.
Jeff R.
A258 - N128LJ / Gold Rush 110 hours and climbing slowly.
Posted: Sun Apr 27, 2008 1:29 pm Post subject: Rough on the lafet mag |
JEFF ROBERTS a écrit :
| Quote: | Other than the plugs can anyone tell me anything they have found to
cause this.
Cracked high voltage leads.
Best regards,
Gilles
http://contrails.free.fr
topglock(at)cox.net Guest
Posted: Sun Apr 27, 2008 3:17 pm Post subject: Rough on the lafet mag |
Jeff,
Knowing your history with heat problems and the time on your engine, why
not just change the plugs. It may not fix the problem, but it will
eliminate them as the cause. http://www.sparkplugs.com has them cheap!
As suggested, it could be plug leads. Might want to check carb
springs and stuck cables, too. Let us know what you find...
Jeff - Baby Blue
JEFF ROBERTS wrote:
| Quote: | HI All,
slightly rough compared to the right. I didn't have time to look it over
then but I will soon. Other than the plugs can anyone tell me anything
Jeff R.
size color="#000000" face="courier new,courier">
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
Checked by AVG.
