Posted: Sat May 10, 2008 10:13 am Post subject: using 87-0ctane with ethanol |
Hi guys,
I’ve been pleased to read these posts on blended ethanol fuel as I fly a
Subaru with Bings. After the first 40 test hours, I’ve only used
87-octane at 10% ethanol. Poor winter weather limited flying to once a
month and I have been concerned about water in the gasoline. At
preflight, I drain enough fuel from each tank to fill a qt glass jar
more than half way. I’ve never found any sign of water or found less
than clear fuel so it’s drained back into 5-gallon storage tanks. The
oldest gas has been 10-12 weeks in the hangar before use and the
Subaru’s performance doesn’t seem to have been affected. I’ve
transferred older gas at the end of winter into my car with no apparent
problems. I’ve never seen signs of water in the 601’s gascolator, the
quart jar or the clear filter on the firewall. I’m only optimistic that
perhaps the fuel I’m using is from stations that have rapid turnover
fuel stocks and a handle on their water separation. I’m going to fly a
lot more this year and have also acquired a set of 5-gallon tanks that
can be carried empty in the wing baggage area for ease of retrieving
fuel from the “street”.
That’s been the experience so far.
Do fly safe,
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
bryanmmartin
Posted: Sat May 10, 2008 4:01 pm Post subject: using 87-0ctane with ethanol |
If you are using gasoline with 10% alcohol in it, you won't see any
water in your samples or your gascolator because any water will be
held in suspension in the fuel by the alcohol -- up to a point, that
is. If enough water gets into the fuel, it will all settle out to the
bottom of the tank taking the alcohol with it. At this point, you will
now have gasoline with a significantly reduced octane rating floating
over a mixture of water and alcohol, neither substance will do nice
things for your engine. This is exactly how you test for alcohol in
gasoline, mix about 10% water with the gas and see if the apparent
water level increases as it settles out. So if you ever do find
"water" in your fuel tank while using gasohol, you might as well drain
the entire tank because the remaining gasoline in the tank will
probably have too low an octane rating to be safely used in your
Subaru engine.
When gas stations start using gasohol, they no longer have to drain
the water from their tank sumps because all the water gets pumped into
the gas tanks of their customers cars mixed with the fuel. On the
other hand, if the storage tank has a lot of water in it before that
first load of gasohol gets dumped into it, the next customers will
pump either low octane gas or the water/alcohol mix into their cars,
depending on whether the separation point ends up above or below the
level of the pump intakes.
Cold winter air can't hold a lot of water, so there isn't a lot to get
absorbed by the alcohol in the gasoline. Hot summer air can hold a lot
of water.
On May 10, 2008, at 2:10 PM, LarryMcFarland wrote:
Hi guys,
fly a Subaru with Bings. After the first 40 test hours, I’ve only
used 87-octane at 10% ethanol. Poor winter weather limited flying to
once a month and I have been concerned about water in the gasoline.
At preflight, I drain enough fuel from each tank to fill a qt glass
jar more than half way. I’ve never found any sign of water or found
less than clear fuel so it’s drained back into 5-gallon storage
tanks. The oldest gas has been 10-12 weeks in the hangar before use
and the Subaru’s performance doesn’t seem to have been affected.
I’ve transferred older gas at the end of winter into my car with no
apparent problems. I’ve never seen signs of water in the 601’s
gascolator, the quart jar or the clear filter on the firewall. I’m
only optimistic that perhaps the fuel I’m using is from stations
that have rapid turnover fuel stocks and a handle on their water
separation. I’m going to fly a lot more this year and have also
acquired a set of 5-gallon tanks that can be carried empty in the
wing baggage area for ease of retrieving fuel from the “street”.
Do fly safe,
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
tshankland(at)sbcglobal.n Guest
Posted: Sat May 10, 2008 6:28 pm Post subject: using 87-0ctane with ethanol |
I haven't really gotten into this but must make a comment. I remember
going to an FAA safety seminar about 25 or 30 years ago where we were
told in no uncertain terms that if we used auto fuel in our aircraft we
would DIE. They gave all the usual reasons, vapor lock, contamination
from "unsafe" fuel supplies etc. Then we found out when tested, other
than by all those pilots that were flying with it anyway, that it did
not do all those things and if we had any expensive piece of paper we
could use auto fuel in our airplanes. My Zodiac as a Suburu and I built
it with aluminum tanks and lines and the flexible lines are automotive,
you know those that tolerate gas and alcohol. I also talked to Bing
about my carburetors and they told me that since they were also used on
many ultra lights their materials were not effected by gasohol. When
people ask me how much aviation fuel cost I honestly don't know because
I get my gas at the Meijers Store.
Tim Shankland
Bryan Martin wrote:
<bryanmmartin(at)comcast.net>
will now have gasoline with a significantly reduced octane rating
floating over a mixture of water and alcohol, neither substance will
do nice things for your engine. This is exactly how you test for
alcohol in gasoline, mix about 10% water with the gas and see if the
apparent water level increases as it settles out. So if you ever do
find "water" in your fuel tank while using gasohol, you might as well
drain the entire tank because the remaining gasoline in the tank
will probably have too low an octane rating to be safely used in
your Subaru engine.
into the gas tanks of their customers cars mixed with the fuel. On
the other hand, if the storage tank has a lot of water in it before
that first load of gasohol gets dumped into it, the next customers
will pump either low octane gas or the water/alcohol mix into their
cars, depending on whether the separation point ends up above or
below the level of the pump intakes.
get absorbed by the alcohol in the gasoline. Hot summer air can hold
a lot of water.
> <larry(at)macsmachine.com >
> Hi guys,
> Do fly safe,
> Larry McFarland 601HDS at www.macsmachine.com
bryanmmartin
Posted: Sat May 10, 2008 7:56 pm Post subject: using 87-0ctane with ethanol |
I used to use auto gas in my Zodiac also, but lately I haven't been
able to find any that isn't contaminated with alcohol. The airport I
fly out of is selling avgas for $4.15 a gallon right now so I'm not
too worried about the price compared to $3.80 a gallon auto gas. Maybe
with enough people screaming about the price of food right now, our
congress idiots will back off of this ethanol kick they're currently
on. We may need to start dragging some of the corn lobbyists out in
the street and beating up on them along with the legislators who keep
pandering to them to put an end to this stupidity.
If you want to use alcohol as fuel, then use alcohol. If you want to
use gasoline, then use gasoline. No way in hell should we be forced to
mix the two together.
remember going to an FAA safety seminar about 25 or 30 years ago
where we were told in no uncertain terms that if we used auto fuel
in our aircraft we would DIE. They gave all the usual reasons, vapor
lock, contamination from "unsafe" fuel supplies etc. Then we found
out when tested, other than by all those pilots that were flying
with it anyway, that it did not do all those things and if we had
any expensive piece of paper we could use auto fuel in our
airplanes. My Zodiac as a Suburu and I built it with aluminum tanks
and lines and the flexible lines are automotive, you know those that
tolerate gas and alcohol. I also talked to Bing about my carburetors
and they told me that since they were also used on many ultra lights
their materials were not effected by gasohol. When people ask me how
much aviation fuel cost I honestly don't know because I get my gas
Tim Shankland
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
