zenith-list(at)steensland Guest
Posted: Mon Apr 28, 2008 10:48 am Post subject: rear wing spars |
Looking ahead a little, I was wondering how scratch builders are bending
their rear wing spars? Most of the D-I-Y brakes I've seen are all 8'
and the spar is a full 12'.
Are people extending their brakes to bend a full 12' or are they farming
out those few bends.
Lee Steensland
601XL/Corvair (7637L reserved) Kit/Scratch builder 0.01% complete!
amyvega2005(at)earthlink. Guest
Posted: Mon Apr 28, 2008 11:50 am Post subject: rear wing spars |
there are instructions on how to connect two pieces to make one rear wing spar.
You can get them from Seb or Roger Heintz.
Juan
sky_ranger161
Posted: Mon Apr 28, 2008 12:08 pm Post subject: rear wing spars |
Hey Lee,
I can't speak for everyone, but I made the rear spar splice that's been approved by Chris Heintz. This allows you to bend the rear spar in two 6-foot sections. In my mind, it's actually an improvement because it provides a doubler at a place where you've cut a big hole in the rear spar for the aileron control rod. You can the get hand-drawn version on Mark Townsend's 601 site:
http://www.ch601.org/resources/rear%20spar/601xl_rear_spar_splice.htm
or another builder, Randy Bryant drew it up a little more legibly at:
http://www.n344rb.com/plans/RearChannelSplice.pdf
You can visit my Kitlog site to see it built. There are more pics than this one - this is just the first one I could find:
http://www.mykitlog.com/users/display_log.php?user=debo&project=132&category=1384&log=32988&row=94
Hope this helps.
Debo Cox
Nags Head, NC
www.mykitlog.com/debo
Making fuselage parts
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Mon Apr 28, 2008 3:31 pm Post subject: Re: rear wing spars |
Lee,
A see a few others have posted the splice 2 pieces method. I can't say what's best, but I made all my long bends, including the rear spar, the rear longerons and others by bending the metal over a board. I've prepared a 3/4" piece of oak that is 12 foot long with an edge that is cut back about 30 degrees, then rounded to the desired radius. I clamp the metal between this board (on the bottom) and another 2/4 on top to my work bench. I then bend the metal over, at first by hand, then using a soft rubber mallet. I go a little bit at a time until the bend is formed. There are pictures in the Wings section on my web sight of the rear spars.
http:\\daniel.dempseyfamily.us
By the way, this is basically the same edge treatment I used on all my forming blocks. Anyway that's how I did it.
Dan
601XL plans builder. (fuselage complete)
| Quote: | "zenith-list(at)steensland"]Looking ahead a little, I was wondering how scratch builders are bending
Lee Steensland
601XL/Corvair (7637L reserved) Kit/Scratch builder 0.01% complete! |
_________________ Scratch building XL with Corvair Engine |
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
cj.tremblay(at)videotron. Guest
Posted: Mon Apr 28, 2008 7:21 pm Post subject: rear wing spars |
Lee, go on my web site
http://www.zodiac640.com/
On this specific page below, you will see how I do this kind of bending for
my tail wing spar ( 9 feet x .040 in 6061-T6). The spar is around 3 meter
long. Special bending technique required to bend with increment of 10
degrees, on a left and right alternance bending.
http://www.zodiac640.com/tail.htm
I do also other bendings for my wing spars (12 feet long for uper and lower
angle in .032 in 6061-T6) with my 8 feet brake.
Good visit. Ask me questions if you have those after visit.
A+
Christian Tremblay
CH640 Plan builder
n1269k
Posted: Sat Nov 21, 2009 5:24 am Post subject: Re: rear wing spars |
Does anyone know how the two piece rear wing spar will be affected by the new safety upgrades?
