Source for FT nose gear friction pad?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
MPPalmer(at)aol.com
PostPosted: Tue Apr 29, 2008 11:53 am    Post subject: Source for FT nose gear friction pad? Reply with quote
The nose gear friction pad on our Glasair FT has noticeably worn. (2800 hours / 13 years.) There's a slight step where it bears against the bottom of the stop plate.
And, over all these years, it has absorbed oil. Some of the oil can be leeched out by soaking the pad in solvent, but I'm thinking I should probably look for a new pad. We get a slight shimmy as we come to a stop, although I also discovered that the hardware holding the friction pad was loose. That would explain the slight side to side shimmy.
I'll plan to email NewGlasair about it, but thought I would ask if anyone has found an alternate source for the FT nose gear friction pad.
Mike Palmer <><
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
(http://autos.aol.com/used?NCID=aolcmp00300000002851) [quote][b]
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
