		wild.blue(at)verizon.net Guest
				 Posted: Thu May 01, 2008 6:49 am    Post subject: L/D |
		brian-1927(at)lloyd.com Guest
				 Posted: Thu May 01, 2008 9:55 am    Post subject: L/D |
				On May 1, 2008, at 7:44 AM, Jerry Painter wrote:
 Precisely. L/D.
 L/D changes with configuration, prop, engine, speed, individual
 aircraft, etc. The best way to find L/D for your airplane is to go out
 and try it. It isn't difficult and you will learn a lot from the
 experiment.
 Brian Lloyd                         3191 Western Drive
 brianl AT lloyd DOT com             Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
		bhancock(at)worldwidewarb Guest
				 Posted: Fri May 02, 2008 9:00 am    Post subject: L/D |
				On May 1, 2008, at 11:58 PM, Yak-List Digest Server wrote: 	  | Quote: |
 1) In a prior post, it was stated "stall speed increases with angle of bank."
 Well, not really.  We should all become students of the V-G diagram.  Stall speed
 increases with increased load factor.  It happens that load factor increases
 with angle of bank.
 Right....and it was my post you're referring to.  Just to be clear, from a practical standpoint if you are in the pattern (low airspeed already) with a high bank angle (created by being too close on downwind as was the scenario I presented) and you need to react to something out of the ordinary or just plain overshoot centerline and decide to pull on the stick (increased load) to "correct" the situation, you've just entered the aviation version of "dead man's curve"...
 Of course this is all basic airmanship and L/D is what we're specifically talking about, but unless you have an AOA in your airplane I don't think most people are going to be calculating reserve lift on short final.  Like I said, some people are mechanical fliers, some people are feel fliers (referring to VFR, of course).  Hopefully, however, we can all feel the Yak/CJ approaching departed flight without ever looking at an instrument...
  	  | Quote: | 	 		  However, in some banked flight regimes, such as banked
 descending flight, the load factor may not increase.
 Or 110 degrees of bank in a wing over...
 Cheers,
 Barry
				 Posted: Fri May 02, 2008 9:26 am    Post subject: L/D |
				I posted this yesterday, but for some reason it didn't show up on list, only
 the header, so here it is again.
 JP
		buddairbum(at)cox.net Guest
				 Posted: Fri May 02, 2008 2:37 pm    Post subject: L/D |
				My attitude is that every airplane that can be landed power off from
 downwind SHOULD be landed power off as often as practical so the pilot
 develops an intuitive set of references. That way, when the engine finally
 does decide to pack up, you know exactly how the airplane is going to react
 in that situation.
 In high performance airplanes like Yaks, Pitts, etc, the L/D difference
 between power-off and just enough power to tell that you have it on, is
 huge. Partially because of the prop angle changing and partially because of
 matching the prop rpm to the forward speed, which reduces braking effect and
 greatly flattens the glide angle. If most approaches are flown with just a
 hair of power to make it easier to judge the approach, then, when the engine
 quits, the pilot is in unknown territory and on a test flight.
 I'm not saying every single approach should be flown power off (although
 mine always are, when possible), but enough should be to develop the
 references so you know where you'll be at the bottom of the dead engine
 glide from any altitude.
 I flew for 38 years without a single serious engine problem, then had two,
 in two different aircraft (a Pitts and a C-150) within 24 hours. I've had
 three since then, all three in one year, all three in Pitts (hard to
 diagnose fuel pump problems).  Plus a fire and a complete loss of oil
 pressure.
 Knowing where it's going to go when the propeller stops propelling is a good
 thing.
 bd
  JP
				 Posted: Fri May 02, 2008 3:14 pm    Post subject: L/D |
				 	  | Quote: | 	 		  > However, in some banked flight regimes, such as banked
 Ah, you remember.
