georgerace
Posted: Thu May 01, 2008 11:41 am Post subject: Fitting Cowl -Jabiur USA FWF Kit for 701 |
Has anyone on the list purchased and installed the Jabiru USA 701 FWF Kit?
I am at the point of fitting my cowl and it looks like I am going to have to
cut a bunch off the back of the lower cowl, about 7 inches. Also the
opening in the lower cowl for the oil cooler ends up just at the back of the
muffler, not anywhere near the oil cooler. The carb air inlet falls up
against one of the engine mounts. The flared opening, in the cowl bottom,
will be greatly reduced in size, about 1/2 the original.
Would like to chat with someone who has done this part of the install
successfully.
George
Kit Building
N73EX (Reserved)
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
dwilde(at)clearwire.net Guest
Posted: Thu May 01, 2008 11:59 am Post subject: Fitting Cowl -Jabiur USA FWF Kit for 701 |
I don't have the Jabiru but with my Rotax firewall forward, I had to cut
out a fairly large area out of the lower cowl to fit around the front
landing gear. I have also had to go back and cut more off to provide
for more cooling air.
Dan Wilde
George Race wrote:
successfully.
George
Kit Building
N73EX (Reserved)
moorecomp
Posted: Thu May 01, 2008 1:16 pm Post subject: Re: Fitting Cowl -Jabiur USA FWF Kit for 701 |
George,
I follow your project and love the changes you made to the elevator control. I suspect the the cowl is common to the 2200 and the 3300. Add the length of the extra cylinders and see if that is about what needs to be removed.
I live in the Northern Lower near Traverse City, and would love to stop by sometime and see your project.
Best regards,
Craig Moore - A&P
Mancelona, MI
701 builder wannabe
cffd(at)pgrb.com Guest
Posted: Fri May 02, 2008 6:18 am Post subject: Fitting Cowl -Jabiur USA FWF Kit for 701 |
George,
I built my cowl using Jabiru supplied nose bowls. The rest is .016
aluminum.
You can see it at
http://www.geocities.com/cffd66/Airplane/Jabinstall/JabInstall.html
Chuck D.
N701TX
________________________________ Message 7
_____________________________________
Time: 12:41:02 PM PST US
Subject: Fitting Cowl -Jabiur USA FWF Kit for 701
to
the
successfully.
George
Kit Building
N73EX (Reserved)
alaskajim(at)cox.net Guest
Posted: Fri May 02, 2008 6:35 am Post subject: Fitting Cowl -Jabiur USA FWF Kit for 701 |
Pete used my 701 for the prototype fitting of the Jab 3300, 701 FWF
package. Give me a call if you wish. Jim 480-766-0003
On May 2, 2008, at 8:18 AM, Chuck Deiterich wrote:
<cffd(at)pgrb.com>
George,
aluminum.
You can see it at
Chuck D.
N701TX
> From: "George Race" <mykitairplane(at)mrrace.com>
> Kit?
> have to
> of the
> up
> bottom,
> successfully.
> Thanks,
> George
> Kit Building
> N73EX (Reserved)
