Posted: Wed Apr 30, 2008 9:53 am Post subject: [Probable Spam] 701 Nose gear stop (7F8-6) |
Hi Stanley,
I'd recommend you add bearing nylon to the top edge of the stops similar
to what's seen in this link.
Straight surfaces are better than curved as I found out after and
changed back to straight. Link below,
http://www.macsmachine.com/images/gear/full/stratstops.gif
Stanley Challgren wrote:
<challgren(at)mac.com>
Builders:
I followed the measurements exactly when fabricating the Nose Gear
Stop (7F8-6). The problem with that was that I was off about 1/8"
somewhere else when doing the Nose Gear Strut Assembly (7L1-1J). The
result is a gap of about 1/8" between the Nose Gear Stop and the steel
tube to which the steering rods attach. Rather than ordering new Nose
Gear Stops from Zenair I am considering adding some bearing material
as that contained in the Lower Bearing (7F7-4C).
The list has previously had pictures of such a fix and the material
was named but I cannot locate either in my files. I can find nothing
in Aircraft Spruce that resembles what I am looking for. Could
someone help me out with the name and where the item can be purchased?
Stan
N701VG (Reserved)
3300 & FWF arrives in May
challgren(at)mac.com Guest
Posted: Thu May 01, 2008 8:22 am Post subject: [Probable Spam] 701 Nose gear stop (7F8-6) |
Larry and Bob:
Thanks for your rapid response. Just ordered 5 feet from Mcmaster-Çarr.
Stan
