		n85ae
				 Posted: Mon May 05, 2008 12:48 pm    Post subject: Snow Load on the top |
				I noticed the local 701 that sits forlornly with flat tires out on the ramp
 at my airport has developed a slight dip in the top which is I suspect
 from the heavy load of snow on it each year. So on my 801 with that
 thought in mind I made some 20x50 mm .032 L's for the fueslage top.
 Might be worth a passing thought if you plan to park your plane outside.
 The std L's don't provide a lot of strength.
 Jeff
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		John75142
				 Posted: Mon May 05, 2008 2:02 pm    Post subject: Snow Load on the top |
				I have done the same on mine. I ran "L" angles straight down the center
 top-bottom and diagonally on both sides to help with the oil canning. It
 really does tighten up all the large areas of unsupported skin.
 I suspect it also adds a small amount of structure to the whole airframe.
 John (Scratch building 701)
 Kaufman, Tx
  _________________ John Short |
