esnj(at)localnet.com Guest
Posted: Wed Aug 13, 2008 4:59 pm Post subject: Firestar Engine Mount |
I'm new to the List. I have just purchased a Firestar II and I am in the process of getting it in shape to fly. It has a 503 DCDI with a Powerfin Prop. The engine is mounted with about 2 degrees of angle between the engine C/L and the 2 inch Root Tube. The Prop end is above the forward end. The drawings show the engine C/L parallel with the Root Tube. What is the consensus on this angle? Thanks, Dick Jones, Granbury, Tx.
