		John75142
				 Posted: Mon May 05, 2008 6:24 am    Post subject: NO Battery box in my 701. Support only COMMENTS, CRITICISM. |
				DO NOT ARCHIVE
 I'm no inspector but it looks pretty good to me. Where to you plan on
 mounting it?
 John (Scratch building 701)
 Kaufman, Tx
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ John Short |
		Geoff Heap
  Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
				 Posted: Mon May 05, 2008 6:31 am    Post subject: Re: NO Battery box in my 701. Support only COMMENTS, CRITICI |
				location will be immediately behind landing gear on starbord side. I think this is per plans. In the pic you can see the angle is built into the bottom "legs"...Geoff
		dougsnash
				 Posted: Mon May 05, 2008 9:06 am    Post subject: NO Battery box in my 701. Support only COMMENTS, CRITICISM. |
				Geoff, this is a very similar concept to what I have
 done but I haven't gone through inspection yet so I
 have no idea if it will pass or not.
 Very nice simple design though.
 Doug MacDonald
 CH-701 Scratch Builder
 NW Ontario, Canada
 --- Geoff Heap <stol10(at)comcast.net> wrote:
  Heap" <stol10(at)comcast.net>
  I like the this new room. You can swing a cat around
  in here without hitting a 601 builder. I’d like to
  here some comments on my battery set up.
  Traditionally there was a battery box over the
  battery. I didn’t put one in, nor do I see the
  need for one. This is a modern fully enclosed
  battery. Leak proof and (according to Nuckolls) you
  can drill a hole in it and not only is there nothing
  to leak out, it should still work fine. (and there's
  nothing back there that can touch the terminals
  which will have Rubber boots on them) Attached is a
  pic. My concern is that an FAA Inspector will not
  like it and insist on some stupid fiber glass box (I
  have one that came with my Fuse kit. By the way. I
  Plans built my wings and then switched to partial
  kits. After seeing the contents of the partial kit
  boxes I still consider myself a Plans
  Builder……………….. Geoff Heap
 Be a better friend, newshound, and
 know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
		john.marzulli(at)gmail.co Guest
				 Posted: Mon May 05, 2008 10:05 am    Post subject: NO Battery box in my 701. Support only COMMENTS, CRITICISM. |
				That looks cool.
 My only question is about the rivet bulbs - Is the vibration of the bulbs against the battery a potential problem? Sure the thing is sealed, but could the rivets fail from the rubbing or could a crack start on the battery holder's frame?
 Overall it seems like this is a great idea for scratch builders.
 Good luck!
 DO NOT ARCHIVE
 On Mon, May 5, 2008 at 7:04 AM, Geoff Heap <stol10(at)comcast.net (stol10(at)comcast.net)> wrote:
   	  | Quote: | 	 		  --> Zenith701801-List message posted by: "Geoff Heap" <stol10(at)comcast.net (stol10(at)comcast.net)>
  I like the this new room. You can swing a cat around in here without hitting a 601 builder. I'd like to here some comments on my battery set up. Traditionally there was a battery box over the battery. I didn't put one in, nor do I see the need for one. This is a modern fully enclosed battery. Leak proof and (according to Nuckolls) you can drill a hole in it and not only is there nothing to leak out, it should still work fine. (and there's nothing back there that can touch the terminals which will have Rubber boots on them) Attached is a pic. My concern is that an FAA Inspector will not like it and insist on some stupid fiber glass box (I have one that came with my Fuse kit. By the way. I Plans built my wings and then switched to partial kits. After seeing the contents of the partial kit boxes I still consider myself a Plans Builder……………….. Geoff Heap
  Every thing built…Working on the Electric City stuff. Getting myself educated. SLOW.
  Rotax 80hp/Dynon D180/Garmin 296/Icom AC-A210/Dual controls
  http://forums.matronics.com/viewtopic.php?p=181219#181219
  http://forums.matronics.com//files/battery_box_1_106.jpg
  801-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
  MS -
  e -
            -Matt Dralle, List Admin.
 John Marzulli
 http://701Builder.blogspot.com/
 http://www.GenevieveMarzulli.org/
  http://www.JohnMarzulli.net/
 "Flying a plane is no different than riding a bicycle... it's just a lot harder to put baseball cards in the spokes.
 -Airplane The Movie  [quote][b]
		Geoff Heap
				 Posted: Mon May 05, 2008 1:33 pm    Post subject: Re: NO Battery box in my 701. Support only COMMENTS, CRITICI |
				The rivets actually just miss the bottom of the battery. They come a little closer than I meant them to.
 Thanks for noticing though. what I'm looking for is criticism. Does anyone know an FAA ruling stating that a battery box is mandatory. I have not tried to research that.
