Saturday
willfly(at)carolina.rr.co
PostPosted: Fri Jan 06, 2006 5:54 pm    Post subject: Saturday Reply with quote
Weather is good for Saturday. Who want to play and where?
Cappy
sawad13(at)msn.com
PostPosted: Fri Jan 06, 2006 7:10 pm    Post subject: Saturday Reply with quote
I hope to be out at Goose Creek later in the afternoon. I need to change my
tires on my RV-4 and don't have a clue as how to jack the thing up off the
ground to take the wheels off. If your really bored and want to stop by...
come on over! I won't be out there till probably sometime after 2pm.
Ron Awad
Reply-To: rvsoutheast-list(at)matronics.com
To: "SERV" <rvsoutheast-list(at)matronics.com>
Subject: RVSouthEast-List: Saturday
Date: Fri, 6 Jan 2006 20:54:03 -0500
<willfly(at)carolina.rr.com>
Cappy
jclarkmail(at)gmail.com
PostPosted: Fri Jan 06, 2006 7:18 pm    Post subject: Saturday Reply with quote
If you get to Columbia by 11:45, you can go with us for BBQ.
James
Cappy
This is an alternate email. Please continue to email me at
james(at)nextupventures.com .
WVSWIFT(at)aol.com
PostPosted: Fri Jan 06, 2006 7:21 pm    Post subject: Saturday Reply with quote
Ron:
General Waskow at Bradford in Huntersville has a neat jack for the RV4.
Jacks only one at a time by threaded rod.
Eddie Shields
Larry(at)bowenaero.com
PostPosted: Fri Jan 06, 2006 7:26 pm    Post subject: Saturday Reply with quote
There is an offer you shouldn't refuse!
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
bill28104(at)yahoo.com
PostPosted: Fri Jan 06, 2006 7:36 pm    Post subject: Saturday Reply with quote
hey Ron, I ordered a jack for rv's. should arrive
next week. if you can wait, you can use it. bill
--- Ron and Shannon AWAD <sawad13(at)msn.com> wrote:
Shannon AWAD" <sawad13(at)msn.com>
sawad13(at)msn.com
Where does it jack the plane up at? The tie down eyebolts???
Ron Awad
Subject: Re: RVSouthEast-List: Saturday
Date: Fri, 6 Jan 2006 22:21:39 EST
Ron:
Eddie Shields
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
sawad13(at)msn.com
PostPosted: Fri Jan 06, 2006 7:41 pm    Post subject: Saturday Reply with quote
Could I just lift the plane up off the ground by the engine mount with a
Chain fall??? I may end up waiting till I get use of a proper jack but my
tires got alot of wear and tear on my trip to Florida last weekend and the
tires now are BALD BALD BALD!!!! I would like to change them out before I
fly it again.
Ron Awad
Subject: RE: RVSouthEast-List: Saturday
Date: Fri, 6 Jan 2006 19:36:22 -0800 (PST)
> sometime after 2pm.
> Ron Awad
> >From: "Steve Glasgow" <willfly(at)carolina.rr.com>
> Glasgow"
> where?
> >Cappy
> browse
> Subscriptions page,
> FAQ,
> http://www.matronics.com/Navigator?RVSouthEast-List
> Admin.
tadsargent(at)bellsouth.n
PostPosted: Fri Jan 06, 2006 7:57 pm    Post subject: Saturday Reply with quote
Ron I'll be there tomorrow with instructions how to remove tires. Also use Bill's jack it is safer, unless you want to take the cowl off. Also the method you are thinking of may spin the a/c around.
Date: 2006/01/06 Fri PM 10:41:17 EST
sportav8r(at)aol.com
PostPosted: Fri Jan 06, 2006 8:24 pm    Post subject: Saturday Reply with quote
I don't know, Cappy - the voices are telling me to stay home and clean my guns tomorrow...
eanderson(at)carolina.rr.
PostPosted: Fri Jan 06, 2006 8:34 pm    Post subject: Saturday Reply with quote
Ron, I have a clamp that you clamp to the lower leg (near the brake) and
then use a car jack to lift the axle. Got both out at the Hanger. But the
screw jack of Bill's might be easier.
Ed
sawad13(at)msn.com
PostPosted: Fri Jan 06, 2006 8:57 pm    Post subject: Saturday Reply with quote
I will have a look in your hangar for the clamp
Ron Awad
To: <rvsoutheast-list(at)matronics.com>
Date: Fri, 6 Jan 2006 23:34:12 -0500
<eanderson(at)carolina.rr.com>
Ed
PostPosted: Sat Jan 07, 2006 4:41 am    Post subject: Saturday Reply with quote
Thanks for the offer but I made plans to visit Mike Louder's project in Stanley county. Next time for sure.
Cappy
PostPosted: Sat Jan 07, 2006 6:45 am    Post subject: Saturday Reply with quote
Ron, the clamp is in my tool bag in the aircraft, behind the pilot seat
back. Its a "U" bolt with a piece of Green Angle iron. The "U" bolt has
two nuts on each leg, big nuts are oversized and are simply spacers. Take
nuts off, put "U" bolt around gear leg as close as you can get it to the
brake caliper mount. Put the legs of the "U" bolts through the holes in the
angle iron. Tighten it down Good. The take the car jack and slip it under
the angle iron, jack up the angle iron and gear. If you are going to have
the wheel off a while I would put a block of wood under the axle.
Car jack is beside the storage cabinet.
Remember you will have to disassembly your brake caliper - otherwise the
rotor will keep you from pulling the wheel off after you remove the axle
nut.
Ed
WVSWIFT(at)aol.com
PostPosted: Sat Jan 07, 2006 6:53 am    Post subject: Saturday Reply with quote
It picks up at the axle. Real neat and small to carry in plane.
Eddie
sawad13(at)msn.com
PostPosted: Sat Jan 07, 2006 7:23 am    Post subject: Saturday Reply with quote
Thanks Eddie, will have to pull the pants off and take a look later today.
Ron Awad
Date: Sat, 7 Jan 2006 09:53:25 EST
Eddie
RV8 tail section done
RV6AN25EH(at)aol.com
PostPosted: Sat Jan 07, 2006 2:43 pm    Post subject: Saturday Reply with quote
Hey Ron,
Do not use the engine mount ring to lift the your plane. I have heard of
this breaking the engine case. Note: this ring is to lift the engine only!
Ed Horgan
N25EH
sawad13(at)msn.com
PostPosted: Sat Jan 07, 2006 5:31 pm    Post subject: Saturday Reply with quote
I was thinking of hooking the chain up to the engine mount itself and
pulling up only on one side at a time, but will try Ed's clampy thing, and
if that doesn't work I will see if I can use the one Eddie mentioned.
Ron Awad
Date: Sat, 7 Jan 2006 17:43:23 EST
Hey Ron,
only!
Ed Horgan
N25EH
