jfrjr(at)adelphia.net Guest
Posted: Sat Mar 04, 2006 9:55 am Post subject: fuel sender units |
Having problems installing the fuel sender units in the QB wings. The folks who built the wing didn't leave enough room between the fuel vent line and the wing stiffner to allow the float to go easily all the way up to the skin. In other words there is no clearance on either side. In addition it is hard, at least for me, to see inside very well even with using a mirror thru the finger strainer hole and a lite thru the drain hole. Could I cut down the length of the float by 1/4 to 1/2 inch (which would provide clearance) and still have it function properly? Or any other advice? Thank
Jay Rowe 40301
Deems Davis
Posted: Sat Mar 04, 2006 11:27 am Post subject: fuel sender units |
Jay, I don't know if this will help but, I found that the way the fuel
sender units are mfg leaves room for variances between units. In my case
I had a (at)#$(at) of a time getting the things to clear the stiffeners , what
I found was that the angle with which they were assembled (riveted
together) there was no way it would ever work (the other unit was OK), I
was able to adjust the angle of the sender unit and the float in
relation to the mounting bracket and the problem disappeared. The units
are put together with a single large rivet between them and in my case I
was able to make the adjustment.
Deems Davis # 406
Fuse
http://deemsrv10.com/
Jay Rowe wrote:
Quote: | Having problems installing the fuel sender units in the QB wings. The
Jay Rowe 40301
LarryRosen
Posted: Sat Mar 04, 2006 8:51 pm Post subject: fuel sender units |
Jay,
Getting the fuel level floats to there full travel in the quickbuild
wings is a tedious task. I have a write up on my web page that explains
how I installed them. You can find it here
<http://lrosen.nerv10.com/Construct/Log/Wings/FuelLevel/index.html>
Larry Rosen
Jay Rowe 40301
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
ddddsp1(at)juno.com Guest
Posted: Sat Mar 04, 2006 11:36 pm Post subject: fuel sender units |
Jay,
I followed the info on Larry Rosen's website and it worker great. I had a friend use a piece of wood to stick in the sender hole and nudge the vent line over to make enough space for the float to clear all the way to the top of the tank. I also rotate the float 90 degrees to make it narrower.
DEAN
40449
________________________________________________________________________
Try Juno Platinum for Free! Then, only $9.95/month!
Unlimited Internet Access with 1GB of Email Storage.
Visit http://www.juno.com/value to sign up today!
rvreynolds(at)macs.net Guest
Posted: Sun Mar 05, 2006 5:36 am Post subject: fuel sender units |
Larry,
The text on your web page is light brown on a dark brow background.
It is not readable. Is me or my mac?
Richard Reynolds
On Mar 4, 2006, at 11:44 PM, Larry Rosen wrote:
Quote: |
Jay,
quickbuild wings is a tedious task. I have a write up on my web
page that explains how I installed them. You can find it here
Larry Rosen
> other advice? Thank
> Jay Rowe 40301
www.matronics.com/Navigator?RV10-List
rv10es(at)earthlink.net Guest
Posted: Sun Mar 05, 2006 12:55 pm Post subject: fuel sender units |
Highlight the text and you can see it. I had the same problem.
do not archive.
rob kermanj
On Mar 5, 2006, at 8:30 AM, Richard Reynolds wrote:
Quote: |
<rvreynolds(at)macs.net>
Larry,
Richard Reynolds
> Jay,
> Larry Rosen
>> Jay Rowe 40301
