Camillo
Posted: Fri May 09, 2008 5:35 am Post subject: Z13/8, max. E-bus and self-excitation |
Hi. I read all the book, surfed the forum and still have a couple of questions regarding to the Z13/8 architecture I want to use for my RV9A.
1) Is there any reason why I cannot put almost every load on E-bus and then switch what's not necessary off via breakers? I mean, if battery contactor fails, I could not use all loads on main bus. If main alternator/battery contactor fails, I can select what I need to remain under 8/10 amp. (maybe I didn't understand the book, but if I use only CB and not fuses [so I can place everything on the E-bus and switch unnecessary off], would be OK to leave only "start" circuit [and switch] on the main bus? Is the high current for a start the main reason for placing the main bus after the "battery relay" and not per the E-bus way [being controlled by a switch and not by a relay?)
2) Is Z25 self excitation mode utility needed in case of a battery short?
Edit: I found a post in which Bob said it is only needed in a cold start without a battery OR, as I can understand, if alternator will be "stalled" (under an overload). Is it right?
Thank-you.
Camillo
RV9A
nuckolls.bob(at)cox.net Guest
Posted: Fri May 09, 2008 7:26 am Post subject: Z13/8, max. E-bus and self-excitation |
At 06:35 AM 5/9/2008 -0700, you wrote:
questions.
under 8/10 amp.
Sure . . . you can do that. Why would you want to?
The point of the e-bus is to maximize utilization of a
limited resource of energy (battery) during alternator
out operations with a minimum of pilot work load (minimum
risk of doing something undesirable under stressful
conditions) and dual feedpaths for power.
Obviously, there are countless combinations of architecture,
bus loading and "plans-b" one could craft for their
project. All combinations would function as designed.
The questions to be asked and answered is what
benefits are derived by departing from a repeatable
experiment where design goals have been debated and
refined for over a decade?
In other words, what shortcoming do you perceive in Z13/8
as published. What design goals do you have that are not
addressed by Z13/8? Perhaps Z12 is a better fit for
you.
| Quote: | 2) Is Z25 self excitation mode utility needed in case of a battery short?
No, in case the battery is not available . . . I.e. disconnected.
( -Thomas Paine 1776- )
Camillo
Posted: Fri May 09, 2008 9:48 am Post subject: Re: Z13/8, max. E-bus and self-excitation |
| Quote: | Sure . . . you can do that. Why would you want to?
conditions) and dual feedpaths for power. |
Among the others instruments, I'm planning a Dynon D10A, a GPS and an ADI, all with internal batteries and I would like to disconnect them from airplane power to lower aux. alternator load in case of primary alternator failure. But, I still would be able to use plane power for them, if necessary. I understand the pilot work stress came from switching each one off separately, but I plan to mark the three said breakers in yellow in the CB panel and to make a remind above the main alt. warning light (i.e.: in case of failure, switch off bks. x,y,z). In addition, I'm planning to do IFR and I would not like to have NAV/COMM off (for a mayday or a radar assistance to home). So, if I have to keep at least this things on the E-bus, I thought it would be better to have all on it.
| Quote: | Obviously, there are countless combinations of architecture,
you. |
I chose Z13/8 because I understood that in Z12 SD-20 would not work without a battery and adding a second battery would have not been a great idea, since an RV9 is not a Boeing (actually, the idea was to pass to Z-14, since the step would have been short...the Boeing relates to this). So, I thaught SD8, even if less powerful, would have been a better choice in terms of safety (cost and weight). Also, I can't say if Z12 could be adapted to receive SD-8. If yes, I anyway doubt it would be good choice: the battery contactor will take 1 amp. off!. In such event, will it work with SB-1 (great capability having it...) or shall it be activated manually as per Z13/8?
At the end of this, I may guess options are:
- Z13/8 as I said;
- Z12 (L40 + SD20) with Z35 to supply power to secondary alternator.
| Quote: | | No, in case the battery is not available . . . I.e. disconnected. |
Sorry...I may need a fourth reading of the book here. If battery is shorted I would have no alternative than using analogic instrument and internally powered electronics one. Isn't it?
Thank-you again.
mprather(at)spro.net Guest
Posted: Fri May 09, 2008 11:25 am Post subject: Z13/8, max. E-bus and self-excitation |
<ungaritrasatti(at)alice.it>
snip
| Quote: | Among the others instruments, I'm planning a Dynon D10A, a GPS and an ADI,
necessary.
I wonder how much power these items will draw when the main bus voltage
drops after an alternator failure. It might be slick if they'd switch to
internal battery if the bus voltage drops down to ~12V.. Not terribly
difficult to accomplish.
Matt-
