wtb oildyne pump
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
pinkston(at)carolina.rr.c
PostPosted: Thu May 08, 2008 6:40 pm    Post subject: wtb oildyne pump Reply with quote
Need a oildyne pump for my super 2s rg glasair # 342-6363-007 or 108am19-bl-2vt or2vtt & still have this my kit for sale 99% glass work done! ser # 2311
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
Bruce(at)glasair.org
PostPosted: Thu May 08, 2008 10:17 pm    Post subject: wtb oildyne pump Reply with quote
Oildyne will overhaul your existing pump. New pumps are available from any authorized Oildyne dealer. Be advised that the hydraulic fluid reservoir canister is proprietary to Glasair Aviation and you will have to buy one from them if you purchase a new pump direct from Oildyne.
Bruce
www.Glasair.org
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
darnpilot(at)aol.com
PostPosted: Fri May 09, 2008 4:09 am    Post subject: wtb oildyne pump Reply with quote
Bruce:
I did not know that the hydraulic reservoir was proprietary. That said, why is the canister unique? When I serviced the pump on my Glasair III I found that the reservoir held a lot more fluid than the pickups could access, i.e., the pickup only went an inch or two down into a reservoir leaving about 4 inches inaccessible. Is there some logic behind this "proprietary" design? Why cannot a non-proprietary canister/reservoir work as well? It is not a question of cost, more of why?
Thanks.
Jeff
PostPosted: Fri May 09, 2008 7:22 am    Post subject: wtb oildyne pump Reply with quote
The ports on the canister are installed by Glasair Aviation. The left over portion at the bottom of the can is the fluid reserve used by the emergency gear extension system.
Bruce
www.Glasair.org
PostPosted: Fri May 09, 2008 7:40 am    Post subject: wtb oildyne pump Reply with quote
That may be the way the system works on an airplane with the separate hydraulic down cylinders for the emergency extension, but not on the others. In my plane the hand pump and release valve is the "emergency system". The way the system is plumbed, there is no way to access all the fluid below the pump pickup in the canister, and in my case, its quite a lot. Are you saying the plumbing is different, i.e., different pickups from the pump canister for the emergency down system?
Just trying to understand.
Jeff
PostPosted: Fri May 09, 2008 7:58 am    Post subject: wtb oildyne pump Reply with quote
There are 2 ports on the canister. The top one is the fluid return, when you open the dump valve, this is where the fluid goes. The bottom one is the pickup for the emergency hand pump. Yours should be plumbed this way. If it's not then it's wrong. The separate cylinders for the emergency down system were only in the latest iteration of the gear system. Prior to this, the system used the normal cylinders for emergency extension. With the latest gear the output of the hand pump was redirected to the new emergency down cylinders via independent lines. The return line and pickup point of the hand pump to the canister did not change.
Bruce
www.Glasair.org
PostPosted: Fri May 09, 2008 8:25 am    Post subject: wtb oildyne pump Reply with quote
Ah, thank you Bruce. A light went off when you explained the differences. Mine is (I think) correct. See photo. So the bottom fitting is for the emergency pump. Now I see the logic. If the electric pump fails or loses fluid, the emergency system can use all that extra fluid in the canister to pump down the gear. Clever.
Jeff
[img]http://links.pictures.aol.com/pic?id=4ab0Csr-zxngtxXIflvcoRcFjut6LlpD5KRzv4xQp5Fd3Ig=&size=m[/img] View full size
PostPosted: Sat May 10, 2008 7:05 am    Post subject: wtb oildyne pump Reply with quote
Careful attention should be placed on testing the emergency down pump/system when the aircraft is on jacks. If you didn't know, the GIII has mechanical uplocks on all 3 gear legs and if hydraulic pressure is lost, they WILL NOT free fall. The nose gear uplock is held in place, against spring pressure, by hydraulic pressure. When up pressure is lost by a leak or turning the dump valve, a spring pulls the uplock open and the nose gear will drop. Hydraulic pressure in the down cylinders from the hand pump is required to unlock the mains.
In the older system, without the separate down cylinders, there were some failure modes that left you with no way to lower the mains. Some builders went so far as to install CO2 blowdown systems or run a manual cable from the uplock lever to the cockpit to allow manual release.
These issues were resolved in the latest gear system, where the only commonality with the normal extension system is the reserve canister.
Bruce
www.Glasair.org
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
