KEVLAR BRIDLE
frank-margie(at)worldnet.
PostPosted: Sat Mar 04, 2006 4:01 pm    Post subject: KEVLAR BRIDLE Reply with quote
He got a full canopy, but the kevlar bridal
>seperated when it came into contact with the sharp edge of the engine
>mount. Unfortunately, it was his last flight. Those two events
>happened 15 years ago. Mine in March and Aubrey's in May. BTW My
>parachute worked.
He did have the spades on his plane, but later we cut down the ailerons and
archived the same or better results.
That's right about the crash - except Aubrey had a "Second Chance" chute
with a "nylon"
bridal
Ref. John Hauck's above post:
John,
Does "nylon" mean they called it nylon, but it was actually kevlar?
If it was really kevlar, what does that say about the current BRS setup? What do you use for a bridle?
Frank Clyma
Possum
PostPosted: Sat Mar 04, 2006 6:00 pm    Post subject: KEVLAR BRIDLE Reply with quote
No... the 2nd chantz had a "nylon" bridal back then. The BRS had a
'steel" bridal
back then, but they have switched to "kevlar" now. I think they know what they
are doing, at least I hope they do. Your bridal may very well go thru your prop
and I think that is why they switched to kevlar. It will take lickin'
(even from a warp drive)
and keep on tickin'.
BTW - I sunk one of the KXP's in a local lake,( Pilot error - I'm
told) and left it
under water for for 24 hrs.
Pulled it up the next day. It had a six year old BRS unit. We let the
water drain out
of the canister and fired it off about a week later. I hooked the
chute around backwards
so the rocket would have to pull it out inflated. Worked great!
with a "nylon"
bridal
John,
Frank Clyma
pj.ladd(at)btinternet.com
PostPosted: Sun Mar 05, 2006 9:20 am    Post subject: KEVLAR BRIDLE Reply with quote
Your bridal may very well go thru your prop>>
Ouch ! my eyes water at the thought.
I do hope you mean bridle.
Cheers
Pat Smile
PostPosted: Sun Mar 05, 2006 6:27 pm    Post subject: KEVLAR BRIDLE Reply with quote
REFERENCE:
'steel" bridal
Thanks! I knew about the earlier steel bridle from BRS (I've still got one around somewhere from an Eagle, which I guess dates me a little----), but I didn't know what 2nd Chantz used, and Jonn's post made me wonder.
Frank Clyma
a58r(at)verizon.net
PostPosted: Sun Mar 05, 2006 6:41 pm    Post subject: KEVLAR BRIDLE Reply with quote
OK, follow me: bridle=a harness; bridel=marriage. Come to think of
it, dang near the same!
regards,
Bob N.
a58r(at)verizon.net
JetPilot
PostPosted: Sun Mar 05, 2006 7:22 pm    Post subject: Re: KEVLAR BRIDLE Reply with quote
That is something I had not really thought about, but seems very likely Shocked If I ever need to pop the chute I will make sure I throttle back first, or even shut down the engine if there is time...
Michael A. Bigelow
Kolb MK-III Xtra, 912-S
PostPosted: Mon Mar 06, 2006 6:08 am    Post subject: KEVLAR BRIDLE Reply with quote
OK, follow me: bridle=a harness; bridel=marriage. >>
Oh Bob,
such cynicism in one so young!
Cheers
Pat
rsanoa
PostPosted: Mon Mar 06, 2006 6:24 am    Post subject: KEVLAR BRIDLE Reply with quote
If possible , place your ignition switch close to the hand you will use to pop the chute. As close as possible to the chute activating handle. It's extremely important to kill the engine if at all possible before deploying. I know of two cases where the chute and harness entangled with a revolving prop. One was a good friend of mine who did'nt have time to kill the engine. Had a new BRS. I have a toggle switch mounted close to the throttle and activating handle so that I can sweep my hand back across the switch handle on it's way to the chute handle.
That is something I had not really thought about, but seems very likely [Shocked] If I ever need to pop the chute I will make sure I throttle back first, or even shut down the engine if there is time...
Michael A. Bigelow
NO FEAR - If you have no fear you did not go as fast as you could have !!!
http://forums.matronics.com/viewtopic.php?p=19822#19822
Bring photos to life! New PhotoMail makes sharing a breeze.
Ray S.Anderson
